El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor LEON2014 el 08 Ago 2016, 00:43
Vilo escribió:Tengo el 15.7.4 y tube problemas hasta que hable con mundodiagnosis y me comento que conectase el cable a traves de un hub al portatil y ya funciona perecto...salvo los .rods que dice que le falta, pero eso es otra historia
probaré a ver....
gracias.
LEON2014
Agradecido: 37 veces
Notapor stewei el 08 Ago 2016, 18:21
Sanz escribió:Alguien sabe si es posible activar la funcion aparcar y maniobrar para los que solo llevamos los sensores traseros?
@Sanz Yo lo active hace un par de meses aprox con el OBDeleven Pro, pero supongo que con el VCDS tambien lo puedes hacer. Eso si, si no tienes la version 15.7.4, yo ni lo intentaria, porque lo que hay que tocar es la unidad 5F, y ya se sabe que puede pasar...
Aqui te dejo el enlace del post donde lo publique:
viewtopic.php?f=8&t=116700&start=540#p1894780
Un saludo :ok:
stewei
Agradecido: 465 veces
Notapor Sanz el 08 Ago 2016, 18:31
Un saludo :ok:
Ostras muchas gracias, tengo hora para dejarlo en la seat para ver si me lo pueden activar a ver que me dicen, igualmente le hechare un ojo a tu enlace, por cierto no se que puede pasar si no tienes esa version de vcds, se puede estropear algo?
Enviado desde mi iPhone 6s utilizando Tapatalk
Sanz
Agradecido: 65 veces
Notapor cvillajos el 08 Ago 2016, 18:43
Un saludo :ok:
Sí, muchas funciones de la 5F se pueden ir "al garete" y más tratándose de los canales que @stewei comenta (fallo asegurado).
cvillajos
Agradecido: 3610 veces
Notapor gesnazo el 08 Ago 2016, 20:28
Hola, quiero comprar el vag com para un león mk3 de mayo 2015.
Es my15 justo antes de que saliera el my16 y con pantalla pequeña, de 5 creo, la que venía en acabado style.
Ese lío del módulo 5F me afectaría si compro el 15.7.1 de aliexpress?
gesnazo
Notapor txato70 el 08 Ago 2016, 22:36
Hola.que cosa mas rara no?.yo active la vision esquematica (ops) solo porque lo de cambiar tonos y demas ya me venia de serie.
txato70
Agradecido: 56 veces
Notapor iglmk3 el 08 Ago 2016, 23:29
Veo que hay bastantes problemas con ese dichoso modulito :( :( hay diferencia significativa entre el 15.7.1 y el 15.7.4 ? Estoy por pillarme el primero y no se si merece mas la pena pillarme el segundo (mi coche es de primeros/mediados del 2014).
iglmk3
Coche: Leon MK3 1.5 TGI 130cv
Notapor Sanz el 09 Ago 2016, 08:04
txato70 escribió:Hola.que cosa mas rara no?.yo active la vision esquematica (ops) solo porque lo de cambiar tonos y demas ya me venia de serie.
Por lo que he podido averiguar, 2 proietarios con my15 si que le sale ese ajuste, y somos unos 4-5 con my16 que no nos sale
Sanz
Notapor LEON2014 el 09 Ago 2016, 08:57
sabéis si el módulo 5f tiene que ver algo con las luces led de las puertas, el modo conducción etc?
Lo tengo desactivado y no puedo cambiar por el vag.com las luces de las puertas y el botón mode no sale los modos de conducción.
Tengo la radio S160, pero antes si que funcionaba.
saludos.
LEON2014
Notapor cvillajos el 09 Ago 2016, 09:51
Las luces Led de las puertas creo que se controlan en la 09, pero el menú de selección de los modos de conducción está en la 5F (canales *Charisma*).
cvillajos
Notapor txato70 el 09 Ago 2016, 20:52
Hola @sanz.la verdad que mi leon es de octubre 2013 sera por eso entonces.saludos.
txato70
Notapor alexdaoe el 10 Ago 2016, 00:00
Hola, mirando el tema del OBeleven he visto varios mods que no estan en este tema,
Alguien ha probado el mod para ver el nivel de aceite en el fis?
Alguien ha probado el de salida mas deportiva? Habeis notado alguna diferencia?
Habeis probado el de la dureza de la direción asistida?
alexdaoe
Agradecido: 48 veces
Notapor Agonza86 el 10 Ago 2016, 00:11
alexdaoe escribió:Alguien ha probado el mod para ver el nivel de aceite en el fis?
Nivel de aceite? Con el motor parado supongo que será, no? Permanezco atento.. si de verdad funciona, es una pijadita curiosa jeje
Agonza86
Agradecido: 409 veces
Notapor ertate el 10 Ago 2016, 00:29
Buenas
como se traduciria ese mod para hacerlo con el vagcom????
ertate
Agradecido: 128 veces
Notapor cvillajos el 10 Ago 2016, 09:38
Buenas
Esos canales ya los hemos intentado activar varios sin éxito (al menos para las MIB gen1). No aparece ninguna pantalla nueva ni en el EasyConnect, ni en el FIS, ni en ningún lugar para activarla desde algún menú...
cvillajos
