El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor LeidenSpain el 12 Nov 2016, 15:25
XaGiCo escribió:
LeidenSpain escribió:a mi la que me gustaría es poder encender y apagar la de los pies con las del techo.
No le veo sentido tener que ir conduciendo con los pies iluminados como un arbol de navidad....
miceor escribió:Puedes ponerlo a 0 (Desactivado) desde la pantalla del infotainment.
Aún poniendolo a cero, al abrir las puertas se iluminarán, luego ya conduciendo ls tendrás apagadas.
Tienes esta opción que solo iluminen al abrir puertas!
Muchas gracias
Voy a investigar si eso mismo se puede hacer por obdeleven, que es a lo que tengo acceso
LeidenSpain
Agradecido: 71 veces
Notapor miceor el 12 Nov 2016, 16:39
Es facil
1 - Modulo 9
2 - Leuchte30FR LC72
3 ------ Lichtfunktion A 30 -- Opciones (Fussraumlicht) Cambiar a Interior Light
miceor
Agradecido: 1259 veces
Notapor XaGiCo el 12 Nov 2016, 16:44
miceor escribió:Es facil
1 - Modulo 9
@miceor
Y la contraseña / password del módulo?
XaGiCo
Agradecido: 166 veces
Notapor miceor el 12 Nov 2016, 16:46
31347
miceor
Notapor LeidenSpain el 12 Nov 2016, 16:51
1 - Modulo 9
Muchas grácias
apuntado a la lista. Porque sigo sin entender si la luz del techo solo se enciende cuando abres las puertas, el panel se enciende cuando se encienden los faros... ¿porque las luces de los pies están siempre encendidas??
LeidenSpain
Notapor miceor el 12 Nov 2016, 16:59
A ver si me explico.
Las luces del techo se activan de dos maneras:
Por apertura de puertas.
Por interruptor o pulsador en los plafones.
El plafon delantero va conectado en paralelo con el trasero, por tanto funcionan a la par.
La luces de los pies se pueden activar mediante varias opciones seleccionables por programación.
Dependiendo de la programación pueden hacer varias cosas.
Fussraumlicht ---- Se encienden al máximo de brillo al abrir las puertas y están temporizadas para apagarse si no se enciende el contacto y se apagan al poner contacto.
Pero además se encienden con el sensor de luz en automatico y el brillo se puede regular en la pantalla e incluso desactivarlas.
Aunque las desactives en pantalla, al abrir las puertas siguen funcionando al maximo de brillo.
Interior Light ---- Solo hacen la primera función de la opción Fussraumlicht
miceor
Notapor LeidenSpain el 12 Nov 2016, 17:04
miceor escribió:A ver si me explico.
Madre, que complicado que lo hacen....
¿no sería más fácil y lógico que se encendieran a la vez que la luz del techo del conductor, que es cuando uno quiere iluminar el habitaculo?
Bueno, probaré a ver que se puede hacer
LeidenSpain
Notapor Valerofr150 el 12 Nov 2016, 17:06
Quizas sea porque es una luz de cortesia no una luz que realmente la necesites, es como las de las puertas de los fr... de cortesia y diseño, por suerte se pueden desactivar de la pantalla, tambien te digo que si no quieres luces le quitas la bombilla y apañao jajajajaja
Valerofr150
Notapor miceor el 12 Nov 2016, 17:15
Si las quitas te da error de bombilla fundida.
miceor
Notapor Valerofr150 el 12 Nov 2016, 17:19
miceor escribió:Si las quitas te da error de bombilla fundida.
A grandes problemas faciles soluciones, borras el error y solucionado
Valerofr150
Notapor LeidenSpain el 12 Nov 2016, 19:48
Quiero indicar públicamente mi error.
Hoy al subir al coche me he dado cuenta que las luces de los pies estaban encendidas, pero que al cerrar las puestas se atenuaba.
Así que he bajado al 10% su intensidad y es cuando me he dado cuenta que con las puertas abiertas lucen con toda la intensidad, y es luego con las puertas cerradas cuando usa la intensidad indicada en la configuración.
Así que se queda como está, entre otro motivos porque tampoco he entendido como funcionaba esta opción
LeidenSpain
Notapor Agonza86 el 12 Nov 2016, 22:06
O mi buscador va francamente mal o no he dado con la tecla correcta buscando. En mi caso por ejemplo tengo un 1.6 TDI Ecomotive, hay posibilidad de instalar en la botonera del clima el botón de desconexión del ESP y que cumpla su función original, la de desconexión de los controles? Se acerca el invierno y suelo circular por zonas en las que nieve acude con frecuencia.
Lo que querría hacer es eso, trasladar o añadir la opción del menú CAR > AJUSTES > Desconexión ESP al botón existente. Decir que mi botonera no lo tiene...
Saludos!!!
Agonza86
Agradecido: 409 veces
Notapor TSILimited el 13 Nov 2016, 00:42
LeidenSpain escribió:Quiero indicar públicamente mi error.
Lo que te comentaba el compañero es que, si en vez del 10% lo pones al 0%, la luz de los pies está apaga hasta que se abren las puertas.
- Entrando en el mundo SEAT -
!Para las rectas, motores; y para las curvas, cojones!
TSILimited
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 69 veces
Notapor TSILimited el 13 Nov 2016, 00:46
Agonza86 escribió:O mi buscador va francamente mal o no he dado con la tecla correcta buscando. En mi caso por ejemplo tengo un 1.6 TDI Ecomotive, hay posibilidad de instalar en la botonera del clima el botón de desconexión del ESP y que cumpla su función original, la de desconexión de los controles? Se acerca el invierno y suelo circular por zonas en las que nieve acude con frecuencia.
Saludos!!!
Creo recordar que había un hilo que explicaba un brico en el que se ponía el botón de ESP del Cupra, y no sé si era bastante complicado por el tema del testigo del airbag o toda esa botonera.
TSILimited
Notapor Rasekfighter el 13 Nov 2016, 00:56
Saludos!!!
Hay un hilo para poner la botonera, para usarla como mando de garaje, no para activar esa función en concreto. O eso creo
Rasekfighter
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 64 veces
