El hilo de VAGCOM y opciones/mods para MK3
- Seguidores: 255
- Favoritos: 102
- Vistas: 1.123.202
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Hola @miceor, intentó meter los para metros que me has pasado para activar el cornering y me dice que error en el canal!!
Vanerova - Nuev@ por aqui
- Agradecido: 9 veces
Reinicia tu VagCom y vuelve a intentarlo.
No tiene ningún misterio, debería dejarte hacerlo sin problemas.
SAludos
SAludos
miceor - Leoner@ mayor del reino
- Agradecido: 1259 veces
Gracias miceor lo mirare
Oskar2965 - Aun con la L
- Agradecido: 12 veces
Oskar2965 escribió:Gracias miceor lo mirare
Recuerda que si no tienes sensor ni palanca en auto creo recordar que tienes que dar un toque a las largas para que te haga el leaving home.
- Agradecido: 3613 veces
Vanerova escribió:Hola @miceor, intentó meter los para metros que me has pasado para activar el cornering y me dice que error en el canal!!
Revisa bien los canales y sus valores que la 09 (muy en alemán) es muy dada a que cometamos errores a seleccionarlos.
Vanerova escribió:Buenas, alguien sabe porque al activar función cornering con vag con se me quedan los antinieblas encendidos todo el rato??
Este es un fallo habitual, hay 2 valores muy muy parecidos en alemán, uno es el valor correcto y el otro las deja encendidas fijas como te pasa. Fíjate muy bien en el valor que pones y en el que debes de poner...
Sent from my Nexus 5 using Tapatalk
tevaadarelsol - Aqui + que con la novi@
- Agradecido: 200 veces
A mi me pasó también pero a al hacer otro mod, activé las antinieblas al dar ráfagas de largas, pero era incompatible con el cornering y al activar una cosa, me desaparecía la otra. Volví a desactivar las antinieblas con ráfaga para dejar el cornering y me pasó lo mismo. Hay un hilo que dice la opción que es, busca bien porque fue lo que a mi me dio la tecla adecuada y como te dicen, son dos palabras casi idénticas.
Saludos!!
Edito:
@Vanerova pásate por la página 206, ahí sale mi caso
- Agradecido: 409 veces
@cvillajos @Xagico quiero preguntaros por los canales de consumidores de confort.
Al trastear con el cable antiguo se me desconfiguró y ahora en el menu/car/consumidores me sale en la pantalla del navegador y fix.pero me pone funcion no disponible en este momento.
Sabeis que y cuales canales e de activar?
Paranohia - Leoner@ habitual
- Agradecido: 6 veces
Paranohia escribió:@cvillajos @Xagico quiero preguntaros por los canales de consumidores de confort.
Entiendo que has activado los canales relativos a:
- Car_Function_Adaptations_Gen2-menu_display_BCmE *
¿Pero también los?:
- Car_Function_List_BAP_Gen2-BCmE_0x23
En la 5F
Adaptacion
- Car Function Adaptations Gen 2
------ Menu display BCmE -- OPCIONES: (Activado)
------ Menu display BCmE over threshold -- OPCIONES: (Activado)
- Car Function List Bap Gen 2
------ BCmE 0x023 -- OPCIONES (Activado)
------ BCmE 0x023 msg bus -- OPCIONES (Bus datos confort)
@cvillajos te me has adelantado por 3 milesimas
Adaptacion
Sois unos cracks, tema solucionado.......
este mod para que sirve chicos??
@miceor @cvillajos
Visualizar Menú ACC - Control de Crucero Adaptativo
1 - Módulo 5F - Electrónica de información 1. Code (20103)
2 - Adaptación
3 - Seleccionar - Car Function Adaptations Gen 2
4 - Buscar submenú - Menu display ACC (ACTIVADO)
5 - Buscar submenú - Menu display ACC over threshold high (ACTIVADO)
6 - Seleccionar - Car Function List Bap Gen 2
7 - Buscar submenú - ACC 0x05 (ACTIVADO)
8 - Buscar submenú - ACC 0x05 msg bus (Bus datos confort)
@miceor @cvillajos
2 - Adaptación
Ese menu es el Control de Crucero Adaptativo.
miceor escribió:Ese menu es el Control de Crucero Adaptativo.
Se necesita radar o simplemente con la camara seria util ?
Valerofr150 - Asidu@ en la selva
- Agradecido: 14 veces
y si lo activo donde saldría?
Que enrreda estás hecho.
Se necesita radar.
!A ver si la vuelves a liar!
Se necesita radar.
OBDeleven - Dudas y Mods para León MK4 Foro: Informática / Interfaces / Diagnosis Autor: miceor Respuestas: 706 |
Pérdida de refrigerante Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: nachovp Respuestas: 0 |
Perdida potencia MK3 1.6 TDI 2014 Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: saso690 Respuestas: 9 |
Puedo montar llanta de chapa en 14"? Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Krixtian69 Respuestas: 1 |
Correa distribución leon mk3 Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: noxon Respuestas: 95 |
