El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor Agonza86 el 21 Feb 2017, 19:44
cvillajos escribió:
Agonza86 escribió:Estoy buscándolo pero ahora no lo encuentro y creo haberlo leído por ahí en algún otro hilo, pero bueno éste tampoco es malo lugar para publicarlo entiendo....
Ese modo de varios tipos de ESC lo que hace es facilitar un control desde el menú para seleccionar entre esos varios modos???
Saludos!!!
@Agonza86 ,
Ya tienes un menú en "Menú > CAR > Ajustes" pero solo con dos opciones. Lo que hace el MOD es jugar con una tercera opción (hay variantes de MOD en función de la codificación que pongas).
Esas dos opciones creo que son simplemente Activado o Desactivado, no?? Digamos que si sigo el mod del primer post lo que hago es "visualizar" y hacer accesible desde la pantalla a esa opción digamos intermedia, verdad?
Gracias y saludos!!
Agonza86
Agradecido: 409 veces
Notapor cvillajos el 21 Feb 2017, 20:08
Saludos!!!
@Agonza86 ,
Gracias y saludos!!
Ahora mismo lo que tienes es "Activado y ASR off", en este MOD consigues, en función de la codificación:
> 09 > Aktiviert/ASR OFF/ESP Sport
> 06 > Aktiviert/ESP Sport/ESP OFF
> 07 > Aktiviert/ASR OFF/ESP OFF
Yo tengo la 09, el resto no las he probado.
cvillajos
Agradecido: 3613 veces
Notapor Mario1307 el 21 Feb 2017, 20:24
Muchisimas gracias !!!! Funcionando sin problema!!!
Valerofr150 escribió:
Mario1307 escribió:Hola gente, a ver si alguien me puede ayudar....
Esta tarde intente hacer el siguiente mod:
Carbono en pantalla central
1. 5F – Information Electr.
2. Coding – 07
3. Long coding helper (puede que te salga un error de ECU, no te preocupes)
4. En apartado 3) seleccionar el byte 17
5. En apartado 4) Deseleccionar el Bit 0 y seleccionar el Bit 1
6. Exit (arriba a la izquierda)
7. Do it!
8. Para poder verlo hay que mantener apretado el boton de encendido de la radio durante 10 segs. Hasta que se oiga un Plof.
Pero en mi coche, que es de Dic del 16 ya viene seleccionado el bit 1 y deseleccionado el bit 0 :shock: ...alguien sabe que tengo que hacer???
Para las pantallas 5,8" hay que seleccionar como dice el brico, el bit 1.
Para las pantallas de 6,5" hay que seleccionar el bit 0 y 1. Ambos han de estar seleccionados. Reinicia la pantalla (da igual si se oye un plof o no, en el mio no se oye nada).
Seat Leon FR ST 1.4 TSI 150cv ACT
:cafe:
Mario1307
Notapor Agonza86 el 21 Feb 2017, 20:38
El valor que dices @cvillajos que pones en tu caso 09 es el del propio byte, donde tengo el cursor en la foto??
Edito, ya lo tengo activado.
Ahora al ir a ver simplemente los modos para los que no tenemos el Seat Drive Profile,dos preguntas:
qué canal se debería seleccionar? En el mod pone "New Value" pero a mi me sale esa pantalla al acceder a él ¿?
Y la otra pregunta es, entiendo que sería otra manera de "visualizarlos y poder seleccionarlos en la pantalla al igual que hemos hecho con los modos ESC??
Agonza86
Notapor cvillajos el 21 Feb 2017, 21:53
Entiendo que te refieres al MOD de aceleración directa... En de caso, antes del "New Value" tienes que seleccionar del desplegable el canal "Driving profile switchover"
Y no, sin el "Driving Select Profile" de serie NO se puede activar menú alguno en el infotainment con estos métodos. Coge el PDF de @XaGiCo y busca el retrofit para activarlo pasando por caja con código SWAP.
cvillajos
Notapor Agonza86 el 21 Feb 2017, 22:34
cvillajos escribió:Entiendo que te refieres al MOD de aceleración directa... En de caso, antes del "New Value" tienes que seleccionar del desplegable el canal "Driving profile switchover"
Ok....Entonces nada... Creí que se podría sacar algo parecido a ésto de los modos de ESC. La aceleración directa en el mío no creo que sea apreciable, un Ecomotive con las marchas tan largas y que deja de empujar a las 3mil rpm da para lo que da....Y por lo que he leído, no hay un consenso claro de hasta qué punto es "la caña", hay quienes dicen que lo notan una barbaridad en la "linealidad" del empuje sin un lag tan acusado, y quienes no aprecian nada.
Gracias por tu tiempo y tus aclaraciones @cvillajos!!!
Saludos!!
Agonza86
Notapor stewei el 22 Feb 2017, 09:38
Saludos!!
@Agonza86 Te voy a dar mi humilde opinión: para mi es la caña, y eso que llevaba mucho tiempo pensando si lo notaría o no, y ya lo creo que lo noto. No pierdes nada por activarlo y probarlo unos días, pero ya te aseguro que te gustará, sobre todo si estabas acostumbrado en tus anteriores coches cuando pisabas el acelerador a "tanto piso, tanto empuja". Y eso que el amigo @javigody no paró de darme el coñazo de que lo activara: al final tuve que "pasar por la piedra" :si:
Ya he hecho un viaje a Marbella este fin de semana y la media de consumo que he sacado es la misma, o incluso mejor, que antes (puedo achacarlo también a que el coche esta mas rodado y por eso consume algo menos). Y si también lo notan aquellos que tienen un TSI, pues blanco y en botella, porque por norma general ellos tienen menos par motor que los TDI, con lo cual nosotros si lo notaremos en mayor medida.
Resumen: actívalo y lo pruebas 1000km, por ejemplo, o una semana, y si no te convence, pues lo dejas como estaba y listo.
Un saludo :ok:
stewei
Agradecido: 465 veces
Notapor Agonza86 el 22 Feb 2017, 09:48
Saludos!!
Un saludo :ok:
Anoche después de escribir este post estuve leyendo y releyendo el del mod en un 1.4 TSI, que al final acababa mezclando la aceleración directa y el dinamique. El dinamique, descartado, me gusta la dirección del coche. A pesar de que estoy acostumbrado a jugar con coches ratoneros, para los tramos en los que me suelo desgogar sé que mi León nunca va a ser tan ratonero como era mi Ibiza 6L (del cual estaba enamorado en temas de dinamismo). El de la aceleración directa sí que barajó probarlo al menos. Entiendo que en tu coche sí que se note más, pues el empuje en bajas de un 2.0 nunca puede ser comparable al de un 1.6, además del amplísimo margen de mejora que tienes. Por eso digo que en un 1.6 por mucho que mejore la respuesta en bajas, no sé hasta qué punto lo notaría. Lo que comentan del lag...al principio sí que lo noté, que hasta que daba la patada el coche iba muerto. Ahora ya lo sé, y ya entro en esas situaciones de tráfico en las que preveo que eso me pase más alegre. Ahora mismo no uso empuje en bajas, pues he suplido esa necesidad con la vista lejana, anticiparme a la situación previsiblemente y zumbarle un doble embrague para que entre una marcha menos ya lanzada a buen régimen de par...y no es que vuele pero he aprendido a que no me deje tirado..jajaja
No sé, es una posibilidad que barajo. Como suelo funcionar a calentones, según vea igual se lo hago esta tarde y lo pruebo una temporada a ver como caza la perra jeje...
Agonza86
Notapor javigody el 22 Feb 2017, 09:53
Saludos!!
Un saludo :ok:
Yo te voy a decir lo mismo que le dije a @stewei, activalo que no te vas a arrepentir.
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Notapor Jemi el 22 Feb 2017, 10:09
Yo he probado esto unos días y, al menos en mi coche, da igual cambiarlo o no, no hay diferencia alguna... Por otro lado, no encuentro sentido a que un parámetro del sistema de dirección tenga algo que ver con la respuesta del motor.
Enviado desde mi E6853 mediante Tapatalk
Seat León SC cupra 280 P.P.
Jemi
Agradecido: 380 veces
Notapor Agonza86 el 22 Feb 2017, 13:54
Jemi escribió:Yo he probado esto unos días y, al menos en mi coche, da igual cambiarlo o no, no hay diferencia alguna... Por otro lado, no encuentro sentido a que un parámetro del sistema de dirección tenga algo que ver con la respuesta del motor.
Es que es eso, a parte de lo hagan los electroduendes, entiendo que no va a sacar más caballos. Que los gestione mejor en bajas quitando el lag? Podría valer como motivo suficiente para hacerlo... Lo cierto es que a día de hoy tampoco he leído en ningún sitio a nadie que diga exactamente qué hace (si enriquece mezcla a base de inyección en bajas, si lo hace por soplido (entiendo que lo haga por inyección, pues el soplido es el que es)...
Y tampoco sé si a muy largo plazo eso va a favorecer la aparición de exceso de carbonilla, o el cambio en las proporciones en los gases de escape (y llevamos FAP)...
Son muchas dudas que aún no he visto claras. No dudo de que funcione. Pero sin saber exactamente qué hace...Me muestro reticente y exceptico.....
También supongo que es algo que para que sea apreciable de manera notable debería ser complementado con por ejemplo el ESC Sport. Porque una cosa está clara, la electrónica de este coche (en mi caso un Style) es muy muy intrusiva pero de manera muy gradual....A mi parecer claro está. Lo que pasa es que lo hace de manera que si no vas atento no se nota, pero si escuchas al coche, interviene tal vez demasiado. Por eso digo que si se activa y no se alteran otros parámetros de tracción, va a ser siempre un coche con una reacción muy "civilizada"...
Agonza86
Notapor cvillajos el 22 Feb 2017, 14:54
No hace nada de eso de lo que comentas. Simplemente cambia la gestión de la presión que ejerces sobre el pedal del acelerador (así de simple).
Luego si tengo tiempo montó una gráfica para que lo entiendas, pero eso en el hilo de "Aceleración directa", que este lo estamos desviando mucho ya...
cvillajos
Notapor davera el 22 Feb 2017, 21:26
cvillajos escribió:
Saludos!!!
@Agonza86 ,
Gracias y saludos!!
Os recuerdo que en los FR, el manual del coche pone que el ESC Sport lo que hace es desactivar el ASR, por lo tanto ASR OFF y ESC Sport es la misma cosa... Por lo que los modos que realmente dan tres funciones diferentes son el 06 y el 07 :yea:
davera
Agradecido: 30 veces
Notapor morpheusgt el 22 Feb 2017, 21:35
davera escribió:
cvillajos escribió:
Saludos!!!
@Agonza86 ,
Gracias y saludos!!
El ESP Sport hace algo más que ASR Off. Se nota que te deja deslizar un poco más antes de entrar en acción.
Yo tengo activado, ESP Sport y ESP Off.
morpheusgt
Notapor cvillajos el 22 Feb 2017, 22:49
Quizá este tema también debiera tener su propio hilo (Tres modos de ESP), donde introducir las impresiones y configuraciones de cada uno tenga. También así independizarlo de un interface concreto, porque hasta ahora todos los post que hablan de él están esparcidos entre el hilo de VagCom y el hilo del OBDeleven.
cvillajos
Nuevo en el foro
Foro: Presentaciones
Autor: Achuguayo
Respuestas: 1
Liquido de refrigeración G12 Evo!!!
Autor: Fernix72
Respuestas: 909
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 666
Leds legales a partir del 1 de noviembre
Foro: General
Autor: arjleon90
Respuestas: 130
Correa distribución leon mk3
Autor: noxon
Respuestas: 106
