El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor MANU2LIN el 15 Nov 2017, 23:42
MANU2LIN escribió:
cvillajos escribió:
MANU2LIN escribió:Hola, si no le doy me da error, como pone en las indicaciones
Pero haces login (10-Security Access) con 25327 o 20103 en la centralita antes del cambio de bit/bytes?
No, eso como se hace, noticia nueva
Yo solo hago esto, como indica:
Litros a repostar
1. 17 – Instruments
2. Coding – 07
3. Long coding helper
4. En apartado 3) seleccionar la casilla 11 (byte 10)
5. Debajo, donde pone Binary, reemplazar lo que pone por 00111010 o bien “3A”en el byte 11 (Para los que llevan navegador hay que poner "7A" o 01111010).
6 Importante, hay que darle a ESC tras la modificación antes de exit, o te dara error al pulsar Do It!
7. Exit (arriba a la izquierda)
8. Do it!
9. Hay que activarlo en Car -> ajustes -> Indicador multifunción -> A repostar
MANU2LIN
Notapor cvillajos el 15 Nov 2017, 23:52
Litros a repostar
1. 17 – Instruments
2. Coding – 07
8. Do it!
Y qué te hace pensar que los pasos sean del todo correctos :no: (no son míos, por cierto, son heredados de cuando empecé a moderar el subforo y tengo tarea pendiente de Actualización...)
Botón "Security Access" antes de dar al botón "Coding". Ahí mete esos códigos indicados.
Si no es eso a lo mejor ese ESC lo que "quiere hacer" es que quites el cursor del teclado del campo binary... Cambia el byte 10, selecciona otra casilla (el byte 11, por ejemplo) y de ahí al exit.
cvillajos
Agradecido: 3613 veces
Notapor MANU2LIN el 15 Nov 2017, 23:57
Litros a repostar
1. 17 – Instruments
2. Coding – 07
8. Do it!
Muchas gracias, lo probare mañana.
MANU2LIN
Notapor Pequenio el 16 Nov 2017, 19:19
Alguno ha notado que él test de agujas lo hace cuando le sale de los coj****??
El mío lo hace cuando le da la gana :neutral:
Pequenio
Agradecido: 41 veces
Notapor ertate el 16 Nov 2017, 23:42
Pequenio escribió:Alguno ha notado que él test de agujas lo hace cuando le sale de los coj****??
pues si y creo que nos pasa a la mayoria ,yo he observado que dependiendo de la prisa con la que gire la llave lo hace o no, es decir di giro la llave con calma lo hace pero si la giro nada mas meterla no hace el test.
haz la prueba y ya nos cuentas.
ertate
Agradecido: 128 veces
Notapor Pequenio el 17 Nov 2017, 01:20
Probare! Gracias!
Pequenio
Notapor ozcho el 29 Nov 2017, 10:11
Buenas gente,
os cuento
He estado poniendo un par de mods y todo ha ido bien.
Lo unico es que he tocado algo que no se que es y he perdido la funcion que hace que todas las puertas se desbloqueen cuando abro alguna de ellas.
Es decir, si tengo el coche cerrado entero (dandole al boton de la puerta, por ejemplo) y abro la puerta del conductor, solo se desbloquea la puerta del conductor y el resto siguen cerradas, no he probado con el maletero, pero me juego algo a que tampoco se abre.
¿Podeis echarme un cablecillo plis?
Muchas gracias!
ozcho
Coche: Leon MK3 1.2 TSI 105cv
Notapor cvillajos el 29 Nov 2017, 14:53
ozcho escribió:Buenas gente,
os cuento
Muchas gracias!
Tienes una opción en el menú de ajustes del Infotaiment que controla eso (puede que haya sido configuración tuya en lugar de causado por MOD).
En última instancia, te vas al histórico de cambios en "C:/Ross-Tech/VCDS/debug/CodingLog.TXT" y revisas o deshaces los cambios hasta que te vuelva a funcionar.
cvillajos
Notapor ozcho el 29 Nov 2017, 18:13
cvillajos escribió:Tienes una opción en el menú de ajustes del Infotaiment que controla eso (puede que haya sido configuración tuya en lugar de causado por MOD).
Desconocía la opcion!
esta tarde le chincho y os cuento.
Muchisimas gracias!
ozcho
Notapor Kiralte el 06 Dic 2017, 16:39
He probado esto:
Cronometro en FIS
1. 17 – Instruments
2. Coding – 07
4. En apartado 3) seleccionar la segunda casilla (byte 1)
5. Activar bit 3 (Lap timer active)
6. Exit (arriba a la izquierda)
7. Do it!
Y al hacer el paso final me da el error ""Coding rejected. Error 3: Request out of range".
Me podéis ayudar? Para activar otras cosas no he tenido problemas y me he leído todo el post y no encuentro la solución.
Seat León MK3 Style Plus de julio de 2017 con cable 17.8.
Gracias.
Kiralte
Notapor cvillajos el 06 Dic 2017, 18:52
Kiralte escribió:Hola,
He probado esto:
Cronometro en FIS
1. 17 – Instruments
2. Coding – 07
7. Do it!
Gracias.
Es MY18, y los MODs de la primera página no están pensados para ellos (puede que cambien pasos, así que te recomiendo que pases por el ClubSeatAteca o por el hilo del OBDeleven, donde se han "matizado" los MODs). O Puede que te falte hacer Login en la centralita "20103 o 25327" antes de codificar.
cvillajos
Notapor mierescity el 06 Dic 2017, 20:24
He probado esto:
Cronometro en FIS
1. 17 – Instruments
2. Coding – 07
7. Do it!
Gracias.
te confirno que no se puede activar el cronometro en el fis en los my18 ni haciendo login,sale siempre "coding rejected"
mierescity
Coche: Leon MK2 2.0 FR 200cv
Notapor Kiralte el 06 Dic 2017, 20:30
He probado esto:
Cronometro en FIS
1. 17 – Instruments
2. Coding – 07
7. Do it!
Gracias.
Gracias por la ayuda, pero no ha servido de nada. Investigaré en la web que comentas.
Kiralte
Notapor Dani2025 el 14 Dic 2017, 01:31
Hola me gustaría saber si existe o hay alguna forma de poner esta modificación me parece interesante
https://youtu.be/QmUjeVZJ7wA
Dani2025
Notapor golf_1990 el 14 Dic 2017, 02:17
Dani2025 escribió:Hola me gustaría saber si existe o hay alguna forma de poner esta modificación me parece interesante
Por ahí anda un esquema de cómo hacerlo, me parece que tienes que instalar un modulador, que te lo puedes comprar en el AliExpress por 2 perras.
Enviado desde mi MI 5 mediante Tapatalk
golf_1990
Usuarios navegando por este Foro: AmazonBot, Anthropic y 6 invitados
