El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor cvillajos el 10 Ene 2018, 22:57
ToreteRS escribió:Buenas! Sabeis si la mod para poner el logo cupra y cambiar el tipo de coche es valida para un Cupra '17 con pantalla de 8"?
Y otra mas...tengo un vagcom antiguo, un 12.12 con VCD 14.10, con esto me valdria o necesito otro cable-vcd?
Gracias!
No te vale, no tendrá ni la mitad de centralitas que monta tu MY'17. Hay un hilo sobre "Qué VagCom comprar?" Que puede ayudarte en este sentido.
cvillajos
Agradecido: 3612 veces
Notapor ToreteRS el 10 Ene 2018, 23:46
Gracias!
Viendo el precio de un cable nuevo, creo que voy a gastar un poco mas y cojer el Obdeleven Pro, que tiene muy buena pinta. Ahora falta saber si esa mod es factible en mi modelo.
La verdad es que lo de los cables es una pena, por que el que tengo barato no salio, y total para hacerle 4 pijadillas al Audi A4 que tenia
ToreteRS
Agradecido: 22 veces
Notapor ozcho el 15 Ene 2018, 12:57
ozcho escribió:
cvillajos escribió:Tienes una opción en el menú de ajustes del Infotaiment que controla eso (puede que haya sido configuración tuya en lugar de causado por MOD).
En última instancia, te vas al histórico de cambios en "C:/Ross-Tech/VCDS/debug/CodingLog.TXT" y revisas o deshaces los cambios hasta que te vuelva a funcionar.
Desconocía la opcion!
esta tarde le chincho y os cuento.
Muchisimas gracias!
Siento haber tardado tanto en responder.
Os cuento lo que me pasó.
Tengo un cable de aliexpress 17.8 con la ultima version del programa.
Pude reconfigurar la puerta con los datos recuperados del coding log, aunque en la ultima version no viene en un txt, si no en un csv navegando un poco por las carpetas.
El problema estaba en que a la hora de escribir descuadraba todo y por eso lo desconfiguraba.
Me fijé que lo que descuadraba eran los dos primeros digitos del binario, es decir si queria escribir 00100320DE00040000001000 lo que escribia era 100320DE0004000000100000, con lo que me echaba todo dos posiciones a la izquierda (llenando con ceros lo que no encuentra, lo comprobé a caso hecho).
La solucion: colocar dos ceros delante 0000100320DE00040000001000. El vagcom me muestra un warning diciendo que es mas largo de la cuenta y que si quiero seguir, le digo que si y todo va como la seda.
A aquellos que les fallaba el cable, que comprueben esta solucion, porque a mi me ha ido bien.
ozcho
Coche: Leon MK3 1.2 TSI 105cv
Notapor Peje el 18 Ene 2018, 17:22
Hola, sabeis si con Vag Com se puede activar el VIM?
Osea que se puedan ver videos en movimiento...
Lo he buscado en la primera pagina pero no lo veo.
Gracias.
Un saludo...
Peje
Agradecido: 9 veces
Notapor cvillajos el 18 Ene 2018, 19:39
Peje escribió:Hola, sabeis si con Vag Com se puede activar el VIM?
Gracias.
No, no se puede. No hay método para VagCom conocido. Únicamente OBDeleven y VCP, o dongles específicos.
cvillajos
Notapor mams69 el 18 Ene 2018, 19:41
Gracias.
Con OBDeleven si se puede?.... poner algun link o tuto.
Gracias.
mams69
Notapor Valerofr150 el 18 Ene 2018, 19:42
Gracias.
Gracias.
Aparece en la primera pagina del hilo especifico de OBDeleven.
Enviado desde mi MI 6 mediante Tapatalk
Valerofr150
Notapor Angelito el 22 Ene 2018, 18:56
Hola buenas, tengo un leon fr 5f del 2015, el caso que despues de volverme muchas veces loco con mi vag-com 16.8 (la tecnologia y yo no somos buenos amigos) y de dejarlo parado, con el tiempo retomarlo y otra vez pararlo porque habia cosas que no me dejaba hacer, ayer con el vag-com 12,12 de otro amigo me dejo porfin hacer un par de cosas (no pude trastear mucho tiempo).
La cosa es que por ejemplo, tengo el chequeo de agujas hecho pero no siempre me hace el "barrido", sabeis algo? el cierre de espejos con un toque de mando por ejemplo a la primera lo consegui pero los parpadeos de intermitencia, he puesto para que me haga 5 y aceptado, todo correcto pero el coche no me los hace, ¿alguna idea?
Ante todo lo siento por mi ignorancia, ya os digo que no me llevo muy bien con la tecnologia y ante todo muchas gracias. :)
Angelito
Notapor genialsoft el 22 Ene 2018, 21:25
Angelito escribió:Hola buenas, tengo un leon fr 5f del 2015, el caso que despues de volverme muchas veces loco con mi vag-com 16.8 (la tecnologia y yo no somos buenos amigos) y de dejarlo parado, con el tiempo retomarlo y otra vez pararlo porque habia cosas que no me dejaba hacer, ayer con el vag-com 12,12 de otro amigo me dejo porfin hacer un par de cosas (no pude trastear mucho tiempo).
El barrido lo hace cuando quiere.
Para que se Active el cambio de los intermitentes pulsa 10 segundos el botón de la pantalla hasta que se apague y se oiga un plop
genialsoft
Agradecido: 346 veces
Notapor cvillajos el 22 Ene 2018, 21:26
Con la tecnología y con el buscadores tampoco :no:
Ambos temas ya están hablados:
viewtopic.php?f=8&t=97892&hilit=Agujas+contacto#p1625955
En este hilo varios comentarios indicando lo del test de agujas y como "mitigar" que no lo haga siempre.
Para los intermitentes reiniciar a fábrica los ajustes de iluminación desde el menú "Car > ajustes".
viewtopic.php?f=8&t=108591&p=2006742&hilit=Iluminacion+ajustes+fabrica#p2006742
cvillajos
Notapor Luisete86 el 23 Ene 2018, 09:26
He visto este vídeo con funciones desbloqueadas. Se sabe como? por Vag?
https://m.youtube.com/watch?v=5Wwr7JHyZ7I
Enviado desde mi SM-A300FU mediante Tapatalk
Luisete86
Agradecido: 34 veces
Notapor cvillajos el 23 Ene 2018, 10:51
Luisete86 escribió:He visto este vídeo con funciones desbloqueadas. Se sabe como? por Vag?
No. Con Hack de la unidad 5F.
cvillajos
Notapor Luisete86 el 23 Ene 2018, 14:16
Qué significa eso del Hack :roll:
Luisete86
Notapor cvillajos el 23 Ene 2018, 14:50
Unidad hackeada.
cvillajos
Notapor sparyrallye el 23 Ene 2018, 22:59
Alguien ha hecho el mod de poner mas colores en la luz ambiental?
Enviado desde mi SM-N9005 mediante Tapatalk
sparyrallye
Usuarios navegando por este Foro: Anthropic, Majestic-12 [Bot] y 5 invitados
