El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor Peje el 08 Feb 2018, 20:00
1. Módulo B7 (entrada de interfaz y sistema de arranque)
2. Codificación extendida (modo texto)
3. Bloqueo anti-cierre de la puerta (pasarlo de "no activado" a "activado")
He sacado este mod, cierre automatico de puertas de obdeleven, y quisiera hacerlo con Vag Com, me lo podriais traducir alguno para hacerlo con Vag Com?
Muchas gracias...
Un saludo...
Peje
Agradecido: 9 veces
Notapor cvillajos el 08 Feb 2018, 23:39
Peje escribió:1. Módulo B7 (entrada de interfaz y sistema de arranque)
Muchas gracias...
Si la B7 tiene fichero de 'labels' (descripción de qué hace cada bit/byte del LongCoding) -> traduce al inglés "Bloqueo anti-cierre de la puerta" y busca dentro de los bytes de la B7 uno que diga lo mismo o algo parecido...
Activas dicho bit y listo.
cvillajos
Agradecido: 3613 veces
Notapor Peje el 09 Feb 2018, 08:01
Muchas gracias...
Ufff, aqui es donde se me complica el tema, el modulo B7 no lo encuentro, luego no se lo que es Labels ni LongCoding y el bite imagino que es buscar la descripcion del testo y cambiarlo a activado como otros modos no?... se me amontona, si podrias explicarte un poco mas o algun tuto que lo explique lo agradeceria mucho, mientras tanto sigo buscando info para seguir aprendiendo, muchas gracias por tus respuestas y tu atencion.
Un saludo...
Peje
Agradecido: 9 veces
Notapor cvillajos el 09 Feb 2018, 10:38
Muchas gracias...
El B7 lo tendrás si llevas kessy. Si no, este mod no lo puedes hacer.
Labels son las descripciones de cada bit en la centralita (por ejemplo, en la 17 tienes la explicación de lo que hace cada bit de cada byte en el cuadro de instrumentos)
LongCoding y LongCoding Helper es el lugar donde se cambian los bits/bytes.
Tuto tienes aquí (lo hubieras encontrado fácilmente usando el buscador) viewtopic.php?f=8&t=108591&hilit=Primeros+pasos&start=0#p1752069
cvillajos
Notapor levorg el 09 Feb 2018, 10:42
Muchas gracias...
Hola @Peje, para inspirarme de cómo hacerlo con OBD11, estuve buscando por la web y encontré cómo hacerlo con vagcom: http://www.golfmk7.com/forums/showpost. ... tcount=354
Lo que sí te digo es que el cierre no es como en otras marcas en las que el cierre actúa por proximidad. Aquí el cierre actúa nada más cerrar la puerta del conductor estando la llave fuera del coche.
levorg
Agradecido: 206 veces
Notapor mams69 el 09 Feb 2018, 11:05
Muchas gracias...
Querras decir con la llave fuera del contacto. No?
mams69
Notapor levorg el 09 Feb 2018, 11:14
Muchas gracias...
Estas codificaciones, tanto con OBD11 como con vagcom, sólo son válidas si tienes Kessy.
levorg
Notapor Peje el 11 Feb 2018, 14:45
Muchas gracias...
Ok, muchas gracias ese tuto es el que ya habia mirado, pero no me di cuenta q en la pagina 3 es donde venia bien explicado, q despiste...
Un saludo...
Peje
Agradecido: 9 veces
Notapor Peje el 11 Feb 2018, 14:48
levorg escribió:
Muchas gracias...
Ok, entonces segun el enlace que has puesto tengo que entrar en el modulo 05 y no en el B7 como pone en obdeleven no?
Es que el B7 no lo encontre y si queeso tengo kessy.
Muchs gracias por la info...
Un saludo...
Peje
Agradecido: 9 veces
Notapor levorg el 11 Feb 2018, 19:10
Peje escribió:
levorg escribió:
Muchas gracias...
Eso es, si tienes Kessy, sigues los pasos con vagcom del enlace que puse. La codificación original del módulo en el leon mk3 es 032C0C, y tal y como se ve en el enlace (eso es común con el golf mk7), el byte que cambia es el byte2 (en concreto, hay que activar el bit4), de modo que la codificación debe quedar como sigue: 032C1C.
levorg
Notapor Peje el 13 Feb 2018, 19:05
levorg escribió:
Peje escribió:
levorg escribió:
Muchas gracias...
Ok, ya hice lo que ponia elel enlace, pero hay un problema. Si cierro la puerta como bien dices se cierra, perfecto, pero cuando entro sin abrir con la llave, osea detectando la mano al entrar y cerrar se vuelve a cerrar el coche y me dice llave no detectada, no te deja poner contacto, que cague me entro... dandole a, abrir desde la llave si que va bien, eso se puede corregir?
Es que te puedes dejar la llave dentro y se cierra...
Gracias.
Un saludo...
Peje
Agradecido: 9 veces
Notapor JoseRD el 14 Feb 2018, 09:57
Hola chavales.
Soy usuario nuevo y queria compartir con vosotros un priblema que me ha surgido con las dichosas mosidicaciones que he hecho para poner algunas mods.
Después de conseguir el efecto carbono y el logo cupra en mi pantalla de 6.5, me ha desaparecido totalmente la opción de Bluetooth en las fuentes para escuchar música.
Es muy desconcertante ya que no logro solucionarlo y el cable vagcom no me deja de ninguna manera entrar en el modulo 77 donde está el Bluetooth.
Podéis ayudarme alguien por favor???
JoseRD
Notapor cvillajos el 14 Feb 2018, 21:44
JoseRD escribió:Hola chavales.
Tu problema con la desactivacion de bluetooth está descrito en este​ hilo: viewtopic.php?f=8&t=103527&hilit=Problema+bluetooth#p1693444 al intentar activar el fondo de carbono con ciertas versiones del cable. Revísalo y si no encuentras la solución continúa en el mismo.
Sobre el tema del módulo 77, el mk3 no tiene dicho módulo, se gestiona el bluetooth y sus funcionalidades desde la 5F del Infotaiment.
cvillajos
Notapor Llopis54 el 17 Feb 2018, 15:17
Hola chicos ! Hablando desde la ingnoracia total quería haceros una pregunta que es la siguiente
¿ se puede activar algo sin el vag com con los botones deicidio coche ?
Tengo un seat leon st fr advanced con line asist ,front asist asistente de luces largas y cortas ,cámara trasera y etc etc no pongo todo que os aburro y por saber si puedo poner el cuadro en carbono o activar alguna cosa chula el coche es nuevo con pantalla de 8 pulgadas y tampoco se como ver vídeos ni nada ... alguien que me guíe un poco sobre que puedo hacer y no que como digo ni idea soy de la zona de la sierra de Madrid ! Muchas gracias!!
Llopis54
Notapor cvillajos el 17 Feb 2018, 16:34
Llopis54 escribió:Hola chicos ! Hablando desde la ingnoracia total quería haceros una pregunta que es la siguiente
Todo lo que leas por aquí se hace con Interfaces (VagCom u otros) que acceden por OBDII a las centralitas​ y modifican sus configuraciones de serie. No, no hay prácticamente ningún MOD que puedas hacer con los botones que te ofrece el coche más allá de todo lo configurable que te indique el manual de instrucciones.
cvillajos
