El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor Xabaco el 07 Feb 2019, 23:01
cvillajos escribió:
Xabaco escribió:
cvillajos escribió:
Xabaco escribió:
cvillajos escribió:
Xabaco escribió:Tengo un problemilla con el vag con.
Cuando entro en los canales no me aparece los nombres de ningún tipo solo me aparecen números por ejemplo en el mod de el test de agujas tengo que buscar STARING y no aparece solo aparece los números. Eso a que es debido.
Enviado desde mi Redmi Note 5 mediante Tapatalk
Una captura de pantalla del desplegable ayudaría. No obstante, ciertas versiones de VCDS añaden al principio una serie de "prefijos" en las labels que no tienen que ser tenidos en consideración a la hora de seleccionar el canal indicado en el MOD.
Aver si se ve el videohttp://cloud.tapatalk.com/s/5c5b5fb7dd136/VID-20190206-WA0125.mp4
El fichero de la 17 (5F0 920 873 A) no parece estar bien en ese VCDS 18.9. Supongo que será un VagCom no original, por lo que puedes hacer dos cosas:
1.- Contactar con el vendedor a ver si tiene otra versión del software válida para tu cable (no sé qué soporte y si te lo ofrecerá o no)
2.- Probar a descargar la versión original de Ross-Tech, instalarla en otro ordenador y buscar el fichero de CLB/LBL oportuno y sustituirlo en tu instalación.
Y borrando el programa e instalando lo en inglés se puede solucionar??
Pone en lo de canal UKNOOOOOOOO SEGUIDO DE MAS NUMEROS
- Esa versión en inglés te viene con el CD del vendedor? -> Si, pruebalo.
- Esa versión en inglés te la has descargado o conseguido de otras fuentes que no sean el vendedor? -> Corres el riesgo de que no te funcione y si tu VagCom no tiene anti-bloqueo dejarlo inutilizado.
Si, viene en el CD mismo que instalé el español.
Desinstalar todo y
Probaré aver
Xabaco
Notapor Xabaco el 07 Feb 2019, 23:03
Esto aparece cvillajos en lo de el desplegableImagen
Xabaco
Notapor cvillajos el 08 Feb 2019, 07:00
Xabaco escribió:Esto aparece cvillajos en lo de el desplegable[ Imagen ]
También en la 19? Te ocurre entodas las unidades de control? Y en las descripciones de los bits en '07 - Coding' -> 'LongCoding Helper'?
Habla con el vendedor...
cvillajos
Agradecido: 3613 veces
Notapor Xabaco el 08 Feb 2019, 07:44
Aparece en todas, por eso decía de desinstalar e instalar en inglés.
Se arreglaría?? En los coding no. Entro y me deja tocar los bits y demás sólo me pasa en lo de seleccionar canal.
Xabaco
Notapor cvillajos el 08 Feb 2019, 07:56
No leíste mi post anterior? Te dige que si en inglés te venía con el propio CD del vendedor lo probaras.
Sobre el LongCoding no me refería a que te dejase tocar y cambisr bits, me refería a si te salia al lado de cada bit su texto descriptivo...
cvillajos
Notapor Xabaco el 08 Feb 2019, 08:02
Si, si lo leí solo quería aclararlo un poco, disculpa
En lo de los bits si me aparece lo de la descripción.
Seleccionó un bit y abajo me dice lo que cada uno de ellos.
Pero para hacer ciertos mods es necesario lo de los canales si no me equivoco.
Esta tarde reinstalare el programa..
Cómo me aconsejas desinstalar
Xabaco
Notapor cvillajos el 08 Feb 2019, 09:35
Lo del LongCoding Helper era para saber si las "labels" también estaban mal, no por relacionarlo con los MODs que necesitan de canales de adaptación.
Para desinstalar desinstala drivers y programa. Lo primero deberías tenerlo en el desinstalador de programas de Windows. El segundo bien ahí, o bien en la carpeta C:/Ross-Tech/VCDS
cvillajos
Notapor Xabaco el 08 Feb 2019, 18:24
Yo creo que ya se a arreglado lo e desinstalado y vuelto a instalar en inglés por cierto mucho más rápido.
Y entra en los canales bien.e podido hacer los mod de carbono, las nieblas en curvas..... Que es incompatible con el mod de las ráfagas.
Creo k está así bien. Corregirme si me equivocoImagen
Xabaco
Notapor Xabaco el 10 Feb 2019, 01:18
Una pregunta, tenemos la opcion de poner el modo off road, aceleracion directa, o diferentes modos de conducción con vag com????
Xabaco
Notapor cvillajos el 10 Feb 2019, 04:10
Xabaco escribió:Una pregunta, tenemos la opcion de poner el modo off road, aceleracion directa, o diferentes modos de conducción con vag com????
Si, si, no (ni con éste ni con ningún otro interface... Requiere codigo SWAP/FEC). Busca en éste hilo o en los hilos de detalle del MOD concreto en el subforo.
cvillajos
Notapor Xabaco el 10 Feb 2019, 17:50
Lo del off road hecho. En cuanto pueda subo como lo e hecho.Imagen
Xabaco
Notapor steve_mad el 17 Feb 2019, 15:38
Esperando nos hayamos
steve_mad
Agradecido: 16 veces
Notapor Lito69 el 19 Feb 2019, 17:39
Seguro que ya está respondido, pero con Odis se puede hacer lo mismo que con vag com? De la misma manera o distinta? Es que yo tengo el Odis y si me puedo ahorrar el vag com...
Lito69
Agradecido: 240 veces
Notapor cvillajos el 20 Feb 2019, 04:41
Lito69 escribió:Seguro que ya está respondido, pero con Odis se puede hacer lo mismo que con vag com? De la misma manera o distinta? Es que yo tengo el Odis y si me puedo ahorrar el vag com...
No tengo ODIS, pero si puedes cambiar codificación extendida y canales de adaptación puedes hacer los MODs con el interfaz que quieras.
cvillajos
Notapor ecolibra el 01 Mar 2019, 22:21
Tengo un problema… hace tiempo hice el mod de poner que el retrovisor derecho bajara con la marcha atras,el caso es que cambie las centralitas 42 y 52 para poder instalar espejos abatibles,y me funciona todo ok menos eso… he hecho lo habido y por haber y no ahi manera de que me funcione… alguna idea de lo que puede ser?
Enviado desde mi PRA-LX1 mediante Tapatalk
ecolibra
Coche: Leon MK2 1.6 TDI 105cv
Agradecido: 23 veces
Usuarios navegando por este Foro: Anthropic, Semrush y 6 invitados
