El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor genialsoft el 05 Nov 2014, 20:25
pirly escribió:
genialsoft escribió:Por cierto a alguien le ha salido esto al intentar el mod del fondo carbono de la radio?
En teoría el vds es el 12.12, ahora eso si el león tiene 2 semanas.
A mi me ha salido , pero le he dado a Aceptar y ha funcionado
Ok. Es que como no salen las opciones me ha dado un pogo de cague, mañana lo pruebo.
(edito) no he podido resistirme. Funcionando.
genialsoft
Agradecido: 346 veces
Notapor intel_9999 el 06 Nov 2014, 01:59
intel_9999 escribió:He intentado modificar las 2 pantallas para poner el fondo carbono y no me lo permite, según he podido leer el mío como es de mayo 2013 viene diferente y no se si se puede cambiar, la pantalla es la grande de 5,8". Aparte también he intentado activar lo de que se cierre techo y ventanillas y no he sido capaz. Si alguien pudiera poner paso a paso para activar ambas opciones se lo agradecería.
Cerrar espejos al cerrar el coche
1.Seleccione STG 09 (energía del vehículo)
2.Autorización de acceso STG -> Función 16
3.Introduzca el código de desbloqueo 31347
4.Ajuste STG -> Función 10
5.Seleccione Control (22) Access Control 2-Funk Spiegelanklappung Modus
- El paso 5 es el que te hace dudar porque el primer (22) que aparece no es el que te indico, sigue para abajo y saldrá otro (22) que pone lo que te indico. Así te funcionará (solo el plegado de los espejos)
6.Ajuste el valor correspondiente al deseado valor por defecto: por conveniencia operativa a través de la llave a distancia = FFB se debe empujar durante mucho tiempo para hacer plegar en el ala refleja Alternativa: Buscar por comando a través de la llave a distancia = FFB se debe pulsar brevemente lo que permite doblarla en los espejos retrovisores"
Fondo del FIS Carbono
1. STG 17 (Schalttafeleinsatz) auswählen
2. STG Anpassung -> Funktion 10
3. Kanal Displaydarstellung auswählen (En ingles pone algo así como display modo o parecido)
4. ändern auf "Variante 2"
Gracias compañero por tu aporte, pero no me expliqué bien, quería decir el cierre de ventanillas y techo en caso de lluvia con el sensor de agua, tampoco tengo espejos con recogida electrónica.
Referente al FIS ya me trae por defecto la variante 2, en mi caso tiene 3 Variantes, y según he podido leer le pasa a los fabricados como el mío marzo-junio....
Haber si hay alguna solución jeje
intel_9999
Notapor pirly el 06 Nov 2014, 10:14
Jeje, yo tampoco pude resistirme me llego el cable y fui volando a probarlo.
pirly
Agradecido: 304 veces
Notapor jorgeflozano el 06 Nov 2014, 13:35
Tengo un problema la al hacer el modelo de atenuación de luces diurnas al dar el intermitente.
Si qué lo hace pero no progresivamente, sino de golpe.¿alguno sabe xq?
Lo he activado tal y como pone en el foro.
Un saludo a todos
jorgeflozano
Coche: Leon MK3 1.4 TSI 140cv
jorgeflozano
Coche: Leon MK3 1.4 TSI 122cv
Notapor dasi658 el 06 Nov 2014, 16:30
jorgeflozano escribió:Tengo un problema la al hacer el modelo de atenuación de luces diurnas al dar el intermitente.
Un saludo a todos
jorgeflozano
Hola yo lo active pero creo que no me hace nada o no lo aprecio no se. Lo comprobe en el vag a ver si estaba todo bien y lo tengo todo como pone aquí pero no veo que me atenúe la diurna al poner el intermitente. Saludos
dasi658
Agradecido: 37 veces
Notapor rojas el 06 Nov 2014, 17:26
a mi me vino de serie , nunca lo he codificado y lo hace 05/14
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1887 veces
Notapor Kampedtre el 06 Nov 2014, 18:22
rojas escribió:a mi me vino de serie , nunca lo he codificado y lo hace 05/14
Que raro, el mío es del viernes pasado y se atenúan de golpe...
Kampedtre
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 28 veces
Notapor norchugo el 06 Nov 2014, 18:27
Yo no puedo activar lo del fondo de carbono... El mio es de junio del 2013, la cosa es que me salen las 3 variantes pero no cambia nada.
Seat leon mk3 1.8 fsi dsg
norchugo
Agradecido: 54 veces
Notapor rojas el 06 Nov 2014, 20:37
norchugo escribió:Yo no puedo activar lo del fondo de carbono... El mio es de junio del 2013, la cosa es que me salen las 3 variantes pero no cambia nada.
has probado hacer un reset? , pulsa el boton de encendido hasta oir un plof.
rojas
Notapor rojas el 06 Nov 2014, 20:39
a mi tb de golpe , aunq juraria que depende de la luz ambiente tienen como unas escalas de intensidad , estare pendiente
rojas
Notapor norchugo el 06 Nov 2014, 20:51
Sí, lo he hecho, pero sigue igual, la cosa es que mi vagcom es en inglés, pero juraría que lo hago bien, mañana pongo unas fotos
norchugo
Notapor marlop el 07 Nov 2014, 00:29
dasi658 escribió:Hola yo lo active pero creo que no me hace nada o no lo aprecio no se. Lo comprobe en el vag a ver si estaba todo bien y lo tengo todo como pone aquí pero no veo que me atenúe la diurna al poner el intermitente.
Es importante tener en cuenta que las luces de día pasan a ser luces de posición (menos intensas) al encenderse las luces de cruce. Así que para probar este tema, solo deben estar encendidas las de día ;-)
marlop
Agradecido: 1080 veces
Notapor jorgeflozano el 08 Nov 2014, 00:58
Solucionado. Hay 2 opciones casi iguales y la buena esta al final del menu.
funciona perfectamente
jorgeflozano
Notapor galaico el 09 Nov 2014, 01:03
Muy buenas, hay alguien en Vigo o alrededores con VAGCOM? O sabéis de algún sitio? Gracias.
galaico
Notapor arlot el 09 Nov 2014, 15:38
He querido cambiar de 3 a 5 intermitencias, y el valor si que me lo reconoce, pero luego sigue haciendo los 3, y eso que cuando vuelvo a entrar en el VAG me pone el valor 5.
Que es lo que hago mal? alguna idea?
Sigo estos pasos: http://ankk-vagcom.com/leon-5f-clignotants-confort/
Última edición por arlot el 10 Nov 2014, 13:08, editado 1 vez en total
Vamoooooooooooooos
arlot
Agradecido: 977 veces
