El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor maxinew el 26 Dic 2014, 13:45
que buen trabajo del primer post. estoy deseando tener el cable
seat leon mk3 1.4 itech dsg 150cv
maxinew
Notapor TeteFR el 26 Dic 2014, 14:25
rojas escribió:
txato70 escribió:Hola tete saludos.pues me has dejado con los pies colgando con esta modo.jijiji vamos que no vale para nada no?.
para nosotros supongo que no , pero Audi lleva un dvd de navegacion en la unidad y con este mod evitas que te roben 300 eurazos :plas:
A parte de lo que comenta el compañero rojas, para un uso particular no creo que valga mucho la pena, pero por ejemplo para flotas de alquiler si que iria bien para así evitar el robo del CD/DVD.
TeteFR
Agradecido: 245 veces
Notapor txato70 el 26 Dic 2014, 16:02
Ok.aclarado gracias.sabéis si alguien a conseguido anular el filtro antipartículas?.y que consecuencias tendría?.gracias.
txato70
Agradecido: 56 veces
Notapor Grisesito el 27 Dic 2014, 23:04
Podéis ir poniendo con que centralitas los números para ir sabiendo con cuales van ?? Mil gracias y de mucha ayuda
Grisesito
Notapor maxinew el 28 Dic 2014, 18:22
hola mirando lo que se le puede hacer en el primer post.
hay dos opciones iguales para activar, los sensores de aparcamiento en la pantalla.
¿es para diferentes versiones?
gracias
maxinew
Notapor dUeNdEr el 29 Dic 2014, 01:56
Por favor, que el moderador modifique este mod, hay un detalle que es por el cual me daba error, es una chorrada pero hasta que te das cuenta...
Litros a repostar en FIS:
1. 17 – Instruments
2. Coding – 07
3. Long coding helper
4. En apartado 3) seleccionar la casilla 11 (byte 10)
5. Debajo, donde pone Binary, reemplazar lo que pone por 01111010 o bien “7A”en el byte 11.
6 Importante, hay que darle a ESC tras la modificación antes de exit, o te dara error al pulsar Do It!
7. Exit (arriba a la izquierda)
8. Do it!
9. Hay que activarlo en Car -> ajustes -> Indicador multifuncion -> A repostar
Dios bendiga los foros...y el conocimiento gratuito compartido de ellos. No exijas, colabora!!
www.yamahaxj6.es
dUeNdEr
Agradecido: 15 veces
Notapor dUeNdEr el 29 Dic 2014, 02:05
Otro MOD más probado por mi que funciona 100%:
Sensibilidad del asistente en pendiente de frenada
EL frenado automático del vehículo en pendiente se puede reducir, la sensibilidad al acelerar para que te lo suelte (no es el tiempo que es el mismo...5 segundos), poniendolo en modo EARLY te agarra el coche perfectamente pero no es necesario que el coche empuje mucho para que se suelten las pinzas de freno, a mi me va perfecto modificandolo a EARLY:
Seleccione 03-ABS Brakes (sistema de frenado electrónico)
Adaptation 10 -> Función 10
Seleccione Hill-start assistant
Por defecto: normal, hay que modificar a EARLY (más sensible) o a LATE (necesitas más potencia para soltar las pinzas)
Aquí el enlace que no hace buena traducción con el traductor:
http://www.stemei.de/pages/coding/seat- ... istent.php
www.yamahaxj6.es
dUeNdEr
Notapor TeteFR el 29 Dic 2014, 02:22
Actualizado el primer post con la corrección de la mod de litros a repostar y añadida la mod Sensibilidad del asistente de frenada en pendiente. Gracias @dUeNdEr por la corrección y por la nueva mod.
TeteFR
Notapor Rafaelin el 30 Dic 2014, 12:04
Espero esta informacion os sea de utilidad. Es la configuracion de Luces de VW y que comparte con nuestro modelo
Rafaelin
Coche: Leon MK3 1.4 TSI 122cv
Agradecido: 71 veces
Notapor arlot el 30 Dic 2014, 19:27
dUeNdEr escribió:Otro MOD más probado por mi que funciona 100%:
He seguido este mod y lo he probado, y la verdad que ahora me gusta mucho más el tacto en modo Early. ;)
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor castronight el 30 Dic 2014, 22:29
Escribí preguntado pero al no obtener respuesta vuelvo a preguntar. A ver si alguien me puede echar un cable.
Los cables ¿los compráis directamente a china? ¿Funcionan bien?
O por el contrario vais a lo seguro y compráis en tiendas Españolas.
Otra cosa, mezcláis por igual alemán e ingles, ¿así lo encontrare en el programa?
castronight
Notapor genialsoft el 30 Dic 2014, 22:45
castronight escribió:Buenas.
Directamente a China más barato pero tardan mas, si los compras por eBay a alguien de España más caros pero los tienes antes. Si miras por el foro hay alguien que los vende con lo cual mas fácil imposible.
El programa esta en inglés, pero muchas opciones están en alemán, pero siguiendo las indicaciones paso a paso no te equivocas.
genialsoft
Agradecido: 346 veces
Notapor arlot el 30 Dic 2014, 23:41
Yo lo compre en mundodiagnosis, algo mas caro pero llevan chip antibloqueo, algunos que venden los chinos se bloquean a losx usos.
El mio esta todo en ingles
Vamoooooooooooooos
arlot
Notapor rojas el 30 Dic 2014, 23:51
el mio tiene palabras en ingles y en la misma frase en aleman ... :shock: :shock:
a veces tengo que hacer malabarismos para la traduccion :no: :rayback:
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1888 veces
Notapor AlvaroFR el 31 Dic 2014, 02:27
rojas escribió:el mio tiene palabras en ingles y en la misma frase en aleman ... :shock: :shock:
Claro @rojas, sino pierde la magía el ir encontrando nuevas funciones jajaj no ahora fuera de coña es un lío si, yo lo tengo igual y resulta que en la página de stemei el vagcom es full alemán.... doble traducción vamos... xD
AlvaroFR
Agradecido: 33 veces
