El hilo de VAGCOM y opciones/mods para MK3
Favoritos: El-Santo, J@VY, neraka, comodisimo, nhaxo, guirimg, Maestro, José R, JorgeAnteloC, gark81, Monilloxd, LeonST, josele887, Guitarrero18, Garfu, pttzarzadilla, reyes83, jicarriches, Raulin87, Leon pucelano, pocososinos, pintalberto, dani90, Mario1307, Albert87, genialsoft, Javigt, crcrodrigo, blankiblau, trekam, lobezno13, Morientes, Josito3, jorgee76, jliriz, Albino, seat leon fr 46, francesito, khris, Agonza86, clavelstreet, ocsido, acidheart, Korath, JPeraza, marcosgumiel, Josele., itsAdriaan96, cvillajos, ertate, LU1S3N_LE, Ludovicum, migcc, Vasmurcia, Charly24Fr, Jerjeskan, Javata, adrinek8, Paliciu, Samueleitor, Sdocid, Tomcat7733, ismacom, KaZaK, m170280, GaiteFRmklll, Mate, kijute, Kete32, los, javieret69, Alberto85, dranaco, joelsm, fre_19, Koltrix, franandas, Alleya, Juanquique, AiramTuning, chetelopez, little bastard, fur, mk3CAT, Juantxu, voxyman, Peje, javimacuo, JDCLEONFR, barrosdepor, steve_mad, Matias92, LordNelson, Elpuma7788, Revi, lopezm0, tuthankamenn, Miguelespino14, rock_ero, jordy, FranXP, albertolop91
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, Aaron7Abad, champinet, Ivan99rr, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jezZu, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, eyebee, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor trekam el 31 Ene 2015, 20:26
guajarenho escribió:¡Hola @trekam!
Intenta resetear el EasyConnect... mantén pulsado el boton de encendido durante unos segundos hasta que escuches un "bop"
lo he intentado varias veces... con la radio encendida mantengo pulsado la rueda-boton de encendido de la radio durante 10 seg y hasta mas de 10seg. y la radio sigue encendida sin hacer nada... cuando suelto el boton se apaga la radio y se vuelve a encender pero en ningun momento hace ese "bop"... asi que no se que hacer ya...
pero no hay manera de que me reconozca ningun usb... llevo toda la tarde probando distintos usb y formateandolos previamente y nada de nada...
y todo ha sido despues de intentar hacer el mod del carbono en la radio... porque antes iba perfectamente..
Lo unico que no va.. el usb... porque si pongo una tarjeta de memoria SD....la reconoce y lee perfectamente los mp3 que hay en ella
asi que no se que mas probar .. ni como poder arreglarlo para que me reconozca el usb.. :enfurecido:
trekam
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 10 veces
Notapor Jorge75016 el 31 Ene 2015, 20:28
Pero sigue sin verse el fondo no?
Inténtalo de nuevo compi, igual son más de 10 segundos, que es un requisito para que te funcione el fondo
Jorge75016
Coche: Leon MK3 1.4 TSI 140cv
Agradecido: 31 veces
Notapor rojas el 31 Ene 2015, 20:41
Jorge75016 escribió:No se si será válido, pero invoco al granmaestro @rojas, a ver si puede dar un poco de luz y si es verdad esto que he encontrado.
"For the purpose of this sample we will use a made up serial number of : 331CE098765432
The digit order shows what order the number of the serial number will be put in for the security code. i.e. 1 is the first digit 3 would be the 3rd digit of the security code. There are 2 possible codes which is why there are 2 separate combinations shown
Login code #1
Digit order: XXXXX1xxx35X24
Login code #2 (alternative code)
Digit order: XXXXX1xxx234X5
Code #1 = 03625
331CE098765432
XXXXX1xxx35X24
Code #2 =06542
331CE098765432
XXXXX1xxx234X5"
Viene a decir que con el numero de serie podemos sacar el codigo de seguridad, y el orden en el que hay que poner los numeros.
con el numero de serie331CE098765432 hay dos posibles codigos:
orden 1 para sacar los numeros: XXXXX1xxx35X24 luego el código será 03625
orden 2 para sacar los numeros: XXXXX1xxx234X5 luego el codigo sera 06542
Espero haber podido explicar, al menos lo que yo he entendido.
A ver si alguien puede decir si realmente es asi.
Un saludo compis!!!
rojas
Agradecido: 1889 veces
Notapor trekam el 31 Ene 2015, 20:47
Jorge75016 escribió:Pero sigue sin verse el fondo no?
ni fondo ni me reconoce ningu usb..
ya he aguantado el boton mas de 10seg. y mas de 20...y como si lo aguanto 30... hace lo mismo.. osea nada...
no hace el "bop" y lo unico que consigo es cuando suelto el boton se paga la radio y se vuelve a encender... pero solo si suelto el boton...
si lo mantengo pulsado.. el tiempo que sea... no hace nada.. se sigue encendida como si nada
y lo que mas me fastidia.. no es el fondo.. si no lo puedo poner el fondo... pues nada...porque antes tampoco lo tenia
lo que relamente me preocupa es que no me funcione el usb... que es aun peor
trekam
Notapor arlot el 31 Ene 2015, 20:50
FDT escribió:
txato70 escribió:Hola.esta mañana he puesto el modo dynamic y la verdad no noto nada es el 1.6 105 cv,noto mucha brusquedad y el embrague mas duro? O es cosa mía a ver si alguien a notado lo del embrague y ya digo de mas potencia o respuesta poco o nada.otra cosa si como decís en bajas acelera mas morirá antes en altas?.gracias.
Yo el embrague lo noto exactamente igual y la potencia tambien, para mi es la agresividad que da ahora que sube de vueltas con mucha mas rapidez dando la sensacion de tener mucho mas empuje pero para nada noto el coche brusco ni forzado, al igual que la direccion que al hacer giros rapidos en curvas pequeñas y juntas se endurece mucho mas que antes.
Supongo que tendra que ver que no exista el fr en el motor TDI de 105cv ya que nosotros (los que tenemos el 150) compartimos el mismo motor que el FR 150cv.
Espera a que rojas cuente sus impresiones cuando lo pruebe el que tambien monta el 1.6 105.
Yo coincido totalmente con @arlot y tambien montamos los 2 el 2.0 150cv.
Coincido con @FDT el 105cv no está en versión FR, y de ahí que no tenga efecto ninguno el cambiar de modo. El 150cv al ser exactamente el mismo en versión Style y FR, si que tiene efecto, y al menos para mi, a mejor.
Yo más que la dirección dura, he notado que sube mucho más rápido de vueltas y la estirada es más prograsiva. Antes, en la zona baja y media era algo "perezoso", la urva viene a ser mas lineal y progresiva, y empujando en todo momento. ¿Que consume más? me da igual.
Como anecdota, mi mujer ha cogido el coche hoy, y cuando ha vuelto me suelta: "oye el coche tiene un pronto que antes no tenia" :rey: a lo que le he respondido que al llevar tanta electronica debia ser el gosoil, que habrá puesto el prenium y es muy sensible; se ha quedado como diciendo que vale :comediante:
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor guajarenho el 31 Ene 2015, 20:55
Login code #1
Code #1 = 03625
331CE098765432
XXXXX1xxx35X24
Code #2 =06542
331CE098765432
XXXXX1xxx234X5"
Un saludo compis!!!
No os sigo... ¿para que es ese código?
Si todo está bajo control es que no vas lo suficientemente rápido
R135
_246
guajarenho
Coche: Leon MK3 1.2 TSI 110cv
Agradecido: 36 veces
Notapor Jorge75016 el 31 Ene 2015, 21:06
Es para descifrar el código de acceso a las centralitas en función del número de serie, pero por lo que he mirado, no es válido para el león
Jorge75016
Notapor Jorge75016 el 31 Ene 2015, 21:08
@trekam, en la carpeta de vcds, hay un archivo txt con los códigos antes y después de las modificaciones, revierte la configuración del fondo carbono y prueba el usb.
Espero que te funcione
Jorge75016
Notapor XoXe el 31 Ene 2015, 21:08
Lo de activar las señales en FIS sirve si tengo camara tambien?
Supongo que ponga las del navegador
XoXe
Agradecido: 59 veces
Notapor Jorge75016 el 31 Ene 2015, 21:10
Ese pone las del navegador, pero si que hay uno específico para los que tenéis cámara, lo que ahora no tengo acceso a buscarlo.
Parte de los puestos arriba están sacados de un foro de skoda
Jorge75016
Notapor alvaro leon fr st el 31 Ene 2015, 21:52
Una pregunta, el coche pone las señales que trae el gps? Pero puedes ponerle otro aparte de reconocimiento de señales?
alvaro leon fr st
Agradecido: 16 veces
Notapor rojas el 31 Ene 2015, 22:03
no ha salido nada en el post anterior , hace tiempo abri un post con una recopilacion de los codigos de acceso de cada centralita .
rojas
Notapor pirly el 31 Ene 2015, 22:12
@rojas tu tienes el 105 y has probado lo de los modos de conducción, hace algo o no hace nada?
pirly
Agradecido: 304 veces
Notapor rojas el 31 Ene 2015, 22:17
pirly escribió:@rojas tu tienes el 105 y has probado lo de los modos de conducción, hace algo o no hace nada?
@pirly eso mismo iba a poner ahora , despues de probarlo ... no me convence ... la direccion se ha endurecido pero la respuesta del acelerador no he notao diferencia ni el comportamiento del motor , como dice @arlot ... quizas sea perceptible para los 150cv
cambio motor 105 x 150 cv ... :si: :si:
interesados ...
jejejej
rojas
Notapor rojas el 31 Ene 2015, 22:20
XoXe escribió:Lo de activar las señales en FIS sirve si tengo camara tambien?
@XoXe si tienes camara ... no es logico hacer el mod del reconocimiento de señales para los que no tienen camara ... la de camara identifica las señales y las del navi estan predefinidas en la cartografia ... no hay color ! , si le quieres hacer te paso el mod para hacerlo
rojas
Liquido de refrigeración G12 Evo!!!
Autor: Fernix72
Respuestas: 906
Hilo del León mkIV e-hybrid
Foro: General
Autor: vkr84
Respuestas: 666
Nuevo en el foro
Foro: Presentaciones
Autor: Achuguayo
Respuestas: 0
Leds legales a partir del 1 de noviembre
Foro: General
Autor: arjleon90
Respuestas: 130
Correa distribución leon mk3
Autor: noxon
Respuestas: 106
