e echo un analisis a mi leon que me estafaron con los kilometros una barbaridad pero el coche va divino
aver si me podeis decir que fallos me da en el test de diagnosis gracias compis
Thursday,22,May,2014,20:40:28:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: VSSZZZ1PZ8R021747 License Plate: VICTOR LEON
Mileage: 140180km-87103mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ8R021747 Mileage: 140180km/87103miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9249
Revision: --H07--- Serial number: SEZ7Z0G3905698
Coding: 0050071
Shop #: WSC 04941 785 00200
VCID: 73E539471240F386991-8026
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004737
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 B
Component: ClimatronicPQ35 011 0602
Shop #: WSC 00000 000 00000
VCID: 2B55E1278AF0EB46111-807E
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000004979966
Coding: 81880F2F00041000431D00000000000000017F075C400000000000000000
Shop #: WSC 18434 020 328969
VCID: 71E9334F685CC1966BD-8024
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 050707 022 0601
Coding: 00056208
Shop #: WSC 18434
3 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 9
Reset counter: 239
Mileage: 136799 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
ON
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 254
Mileage: 139634 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.70 V
OFF
ON
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 139765 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.75 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R2 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0PCSAYQK
Coding: 0021042
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Serial number: 6332MSME19767B18
Subsystem 2 - Serial number: 6342MSME19767C6F
Subsystem 3 - Serial number: 6351HTS618L449N6
Subsystem 4 - Serial number: 6361HTS6D3K0IJ37
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 8109E38FD8FC51161BD-80D4
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
9 Faults Found:
02413 - Switch for Selector Lever Position P Lock (F319)
008 - Implausible Signal
007 - Short to Ground
00194 - Ignition Key Removal Lock
009 - Open or Short to Ground
014 - Defective
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
010 - Open or Short to Plus
003 - Mechanical Failure - Intermittent
008 - Implausible Signal - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 840 C
Component: KOMBIINSTRUMENT VO3 0724
Coding: 0002101
Shop #: WSC 00001 001 00001
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K076250732
Coding: E9807F060006020202
VCID: 306FF64BA3D6889E243-8065
3 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 109129 km
Time Indication: 0
Date: 2000.00.00
Time: 07:17:45
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 254
Mileage: 139634 km
Time Indication: 0
Date: 2000.00.00
Time: 00:11:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 239
Mileage: 139765 km
Time Indication: 0
Date: 2000.00.00
Time: 23:46:28
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0724
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1129
Revision: 31008001 Serial number: 00000062178528
Coding: 0000176
VCID: 3B75D1677A907BC6811-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.077 H08 1901
VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv. Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1129
Revision: 31008001 Serial number: 00000018678508
Coding: 0000176
VCID: 3C77D27B7F9E7CFE88B-8069
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000001879956
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000001898297
Coding: 0000144
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H23 0110
Revision: 00000001 Serial number: 00000000595532
Coding: 0000555
VCID: 326BFC43ADDABA8E527-8067
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 223
Mileage: 109129 km
Time Indication: 0
Date: 2000.00.00
Time: 07:18:54
End ---------------------------------------------------------------------
aver que me podeis decir test analisis
5 mensajes
Última edición por leoncioalaejos el 25 May 2014, 14:05, editado 2 veces en total
leoncioalaejos - Nuev@ por aqui
Re: aver que me podeis decir test analisis
Pon la lista de fallos sinos poco te podremos decir jajaj no te preocupes demasiado por los kilómetros que lo que mas importa es que este bien cuidado. Un saludo
[Valencia / Alcoi] Reprogamacion de centralitas diesel.
viewtopic.php?f=23&t=117048
kits de maneta y cableado tempomat mk1 35e envio incluido.
viewtopic.php?f=4&t=119123
vendo vagcom 16.8. 35 euros envio 24h incluido.
viewtopic.php?f=4&t=121551
jesuscifre - Primeros Pasos
- Agradecido: 11 veces
hay lo e copiado aver sime podeis decir algo gracias saludoss
Cuando acabes de leer los fallos borralos date una vuelta y vuelvelos a leer porque la mayoría desaparecerán. En principio yo no e visto nada fuera de lo normal asique no te preocupes de todas formas que te de su opinión otro para confirmarlo. Un saludo
Por cierto no entiendo mucho pero dice que no tiene conexión con la radio, es la de casa? Alguien que nos diga porque puede pasar eso? Aparte de por un cable cortado claro... Jajaj
5 mensajes
No se que decir, estoy sin palabras Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: chorche_1980 Respuestas: 6 |
Como quito fallo 01486 ABS(sistem funccion test) Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: david_leon2 Respuestas: 11 |
Me podéis confirmar cuál es el fusible de la radio del león Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: mebarak2027 Respuestas: 2 |
Reset / Test flaps climatizador Foro: Informática / Interfaces / Diagnosis Autor: juanmontequinto Respuestas: 1 |
hola, me podeis decir esto que es... Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Alexary Respuestas: 2 |
