Ayuda para interpretar error VAG COM
Seguidores: karrotto
Notapor karrotto el 23 Oct 2014, 21:10
Buenas a todos,
Me he hecho de un VAG COM 12.12.0 y al hacer un test me sale la siguiente información:
VCDS Version: Release 12.12.0
Data version: 20130910
Thursday,23,October,2014,20:25:22:62939
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ1PZ6R095112 Mileage: 180220km/111983miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LL HW: 03G 906 021 LL
Component: R4 2,0L EDC G000SG 9185
Revision: --H02--- Serial number: SEZ7Z0F3389686
Coding: 0050072
Shop #: WSC 06441 785 00200
VCID: 74E73A5B174EF4BE80B-8021
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0006786
VCID: 71E9334F685CC1966BD-8024
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 008 0303
Shop #: WSC 00000 000 00000
VCID: E9D9DB2FC08CB956A3D-80BC
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003979986
Coding: 81880F2F00041000001D00000000000000007F075C
VCID: 2B55E1278AF0EB46111-807E
Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE350 012 0403
Coding: 00056272
Shop #: WSC 06441
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R2 AIRBAG VW8 027 2521
Revision: 09027000 Serial number: 003A1P84BWFN
Coding: 0021042
Subsystem 1 - Serial number: 6332MSME0F103434
Subsystem 2 - Serial number: 6342MSME14754151
Subsystem 3 - Serial number: 6351HTS6OLLQ8K03
Subsystem 4 - Serial number: 6361HTS6TLL232U2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 634 0070
Coding: 0002042
VCID: 77FD0D5706389FA6A59-8022
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 001 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 823 F
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002101
Shop #: WSC 05408 001 13841
VCID: 2F6DF537BEE897663D9-807A
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001064058123
Coding: 3D3F0340070202
VCID: 2A5BE423850AF24EEA7-807F
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Shop #: WSC 03430 224 97000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2491
Coding: 0000176
VCID: 377DCD5746B85FA6659-8062
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3365F94752C0B386591-8066
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC090005054C4F863004CC
VCID: 79F90B6F302C89D6D3D-802C
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1T0 959 702 C
Coding: 0000176
VCID: 387FCE6B4BA650DE6C3-806D
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P1 035 186
Component: Radio BVX 0017
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 G
Component: Tuer-SG 021 2420
Coding: 0000144
VCID: 3467FA5B57CEB4BE40B-8061
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 G
Coding: 0000144
VCID: 3561C75F5CB4ADB6775-8060
End ---------------------------------------------------------------------
He visto que hay un fallo en Address 46: Central Conv. He estado viendo que es relativo a sensores internos. La cuestión es que he tenido problemas y he cambiado EGR, mariposa de admisión y turbo, últimamente también me daba problemas con la medición de la presión de caudal de entrada, ¿es el mismo error?
Un saludo y gracias.
karrotto
Re: Ayuda para interpretar error VAG COM
Notapor karrotto el 24 Oct 2014, 07:48
Me autorespondo, no tiene nada que ver, el error es relativo a los sensores volumétricos. Para ver si el turbo y lo demás va bien le haré un log y sacaré las gráficas correspondientes.
karrotto
Usuarios navegando por este Foro: AmazonBot, Anthropic y 6 invitados
