Fallos al activar bola de remolque [MK3]
NotaPublicado: 04 May 2015, 22:01
por setate0
Hola estos son los fallos al activar la bola de remolque en st fr
Ademas de fallo en el start stop y en el modo profile
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 69
VIN: VSSZZZ5FZER103861
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (J623-CRBC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 7544
Revision: 83H22---
Coding: 11190012043401080000
Shop #: WSC 00049 770 00125
ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
ROD: EV_ECM20TDI01104L906021CP_SE37.rod
VCID: 79F90B6FF82C89D6D3D-802C
1 Fault Found:
4863 - Invalid Data from Towing System Control Module (J345)
U1004 00 [047] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Mileage: 21107 km
Date: 2015.04.23
Time: 20:42:54
Readiness: 0 0 0 0 0
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001747429
Coding: 000000000000000000000000010000000000000000000000000000000000
Shop #: WSC 00070 000 00000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_AU37.rod
VCID: 3F8DA577A68867E6AD9-806A
2 Faults Found:
67072 - Local Databus
U1125 00 [009] - Additional Installations Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 187
Reset counter: 250
Mileage: 21107 km
Date: 2015.04.23
Time: 21:01:18
0769 - Analog Measuring Input
C1155 31 [009] - No Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 244
Mileage: 21107 km
Date: 2015.04.23
Time: 21:01:18
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5F0 035 846 A HW: 5F0 035 846 A
Component: MU-S-N-ER 040 0425
Serial number: E1F01303140248
Coding: 04730301FF0A000021110001000800002F0101040100010046
ASAM Dataset: EV_MUStd6C3PASE 002029
ROD: EV_MUStd6C3PASE_SE37.rod
VCID: 264310135912D62ECEF-8073
Media Player Position 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H51 0022
Serial number: SEZ8Z9PL4011F7
Engine Control Module 2:
Subsystem 2 - Part No SW: 5F0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
5 Faults Found:
6935 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 21107 km
Date: 2015.04.23
Time: 21:01:22
6951 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 21107 km
Date: 2015.04.23
Time: 21:01:21
7191 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 21107 km
Date: 2015.04.23
Time: 21:01:25
7203 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 21107 km
Date: 2015.04.23
Time: 21:02:09
7207 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 244
Mileage: 21107 km
Date: 2015.04.23
Time: 21:01:24
Address 69: Trailer (J345ñªJ34) Labels: 5Q0-907-383.clb
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anhaenger H14 0137
Revision: 8C001003ñ~6A0 Serial number: 0350032834ñŒ000
Coding: 010000020000000006000100000000000000
ASAM Dataset: EV_ 001001ñ¢001
ROD: N/A
VCID: F4E7BA5B5F4E74BE00B-80A1
No ASAM data for: "EV_" (SE37)
1 Fault Found:
170242 - ROD - Unknown Error Code
- 00 [020]
Intermittent - Not Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Status: 00010100
Fault Priority: 11
Fault Frequency: 9
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
End ---------------------------------------------------------------------
Re: Fallos al activar bola de remolque [MK3]
NotaPublicado: 07 May 2015, 21:58
por aprietatuercas1974
has instalado el original,o uno compatible con el coche,te puedo mirar en etka si tienes la referencia imprimir el catalogo de montaje y pone donde se debe codificar
si tienes alguna pregunta mp y te explico
