errores scan MK2 vag com. Ayuda
NotaPublicado: 18 Jul 2015, 23:12
por juanba
pues os pongo los errores que me dio al pasar el vag com al loncete.a ver si podeis decirme que son.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: Malfunction 0010
Component: Climatronic H03 0705
Revision: 00001K07
Coding: 00000114202100011005000000101000
Shop #: WSC 00049 770 00107
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 275B8DC75E6FC626FA7-8072
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
6 Faults Found:
327943 - Position Sensor for Left Temperature Flap Motor
B1094 15 [008] - Open or Short to Plus
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
329991 - Position Sensor for Defrost Flap Motor
B1098 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
328967 - Position Sensor for Front Air Distribution Flap Motor
B1099 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 89
196866 - Temperature Sensor for Footwell Vent
B1085 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 89
197890 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 89
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002475760
Coding: 030100F40B087300FF0002E8080F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear_SE37.rod
VCID: 428D3C53D50D030ECD9-8017
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A0296170714
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 4046434303
1 Fault Found:
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 89
Mileage: 15089 km
Date: 2015.07.06
Time: 16:22:05
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5F0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140624200520
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: EADD34F30DFDBB4EA59-80BF
1 Fault Found:
0006 - Actuator for Structural Accoustics
P193A 00 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 196
Reset counter: 57
Mileage: 12679 km
Date: 2015.05.15
Time: 10:24:35
End ---------------------------------------------------------------------
Re: errores scan vag com.ayuda
NotaPublicado: 19 Ago 2015, 16:55
por MORKAS
Guarda el log..y borra a ver si te vuelven a salir despues de andar con el coche...no se qu emas..puede ser...saludos
NotaPublicado: 19 Ago 2015, 23:14
por stewei
esos errores parece como si hubieras desmontado algo y quitado cables o le hubieras desconectado la bateria, no?
NotaPublicado: 19 Ago 2015, 23:38
por juanba
stewei escribió:esos errores parece como si hubieras desmontado algo y quitado cables o le hubieras desconectado la bateria, no?
Solo desmonte la consola central para vinilar.sera eso?
