Seguidores: golf_1990, josusanchez5b, Jastur, r11ourense, MerioE, davidddgt, jose.a.llamas, gato125, Pkt, byChule, Hovig, SorianoFco, jygalvan, CubanPitbull, corderazo, israher, iDavid9669, nyro, pirulo79, Edu1589, ramargo75, javi.ferrer, kikelin, aleejandroogm, Trimmer, car212121, LeoST, Besaygf, kinipc, Rasekfighter, Romera, MartinLeon, camamaleon, Aceroinox1a, jramis, Juanquique, josele77, marlop, Peje, Pedrost, bailyibz, wiki88, teltronik, gogua, sirkez, carlosgzlez, mcecho, genialsoft, aironsam14, JoseCa, Dandy_gsi, vanscampa, Joseibz, trekam, La_jungla, jorgecrackets, aigort, msmdraven, IRO, Jorge75016, alejandro_javier, ivan0909, jmfcoto, viktor_ct_95, maxxg2, olgalberto1, danifusi, Josepo79, er_trompe, miyobe, jande, Petri, itz18, jagman, serguey79, rafapadilla93, Mate, undernok, lead, lead, csabafr2013, jluis, olmeras, LeidenSpain, osjamil, Valerofr150, flope63, Herrdoktor, pocososinos, carrasco13, pichonclv, C.reina, Daner84, inamarlo, aguscalderon, BaZZ, yujakantabro, Fonek, LARABA, juanmaroger, juanmac, Kipu, IvanMc2, garrafa2, Linker89, mihai G, Igor, bronce702, creasy1977, Gsclosada, lebowski, jaro_84, charly425, leonfr76, DBS83, joseanvazquez501, M3rs, borgio, NOCIVOX, FcoJ.M.N., VillaSB, t4alberto, lytry32.hc, david_gz, Kasky, diegol147, jasoriab, jninomo, jmiturbe, chetelopez, utopia95, Dreziel, jonatan1988, xsoldadito, Illan, Fernandoestrada, jd_zuri, Juande667, xjuliox, Bettor, solanomor01, Chinyero, volkov, braulioT, Maikermx, iNowack, D83, MORKAS, dRoXe, JaviMarquez, danitre, Davi_TGI, DiegoR, ertate, cuenka16, nicotzioras, Spok68, urbion, linxes, kukikukarron, Talnoseque, Hyperr, VapaV, jfermar, Moigijon, slyjay73, DuckToy, nachomart, Iosu21, sbarri, sebasresa, Beiró, Llisus, agus_piscis10, Action SVG, Alc16, Trivi83, eyebee, riclanico, Per3zo, Qore, lolorm, abollao, Alvi, sergi303, Xilenos, barret, Gus_Fring, malloc, TomH30, jmofcb, paco_22_22, luigi323, Chelazo, dani10s, victor david, Yeiem93, Luiggi7, Guillen222, yoflipo, nenazojuanma, nitro_g4074, Senuto, gabivvamesia, javichu312, richard_11, Yery, Ivensound, El_pelos44, rvicario76, Mr.Chuflas, subaru_3, eruizm, Gomez89, barubita, Nicoplas, javibmw, el_noi_80, kapi21, satoo, barrosdepor, camaon99, craken, Flow-Rider, Castro87, Kikedecefe, xexpir, Cristian2014mx, _Juansp, jornefra, cucci, Pablitofr, Pablitofr, Rober_SR, kevinhtbs, chocoleitos, RamonLaC, cesarsl, drnrd, conquepoquico, hectordrums, Neuw84, bertoco, dondani96, cupralex, Octacon, pablomus85, josean-opc, davidap13, Raaz, erlanz, canijo82, MarcosRG86, Alianma, SinName, mSx, evomaoleon, BertopenST, a.cuadros71, Lumara, Gendos22, borjayadri2, litllevill, Jandrew, galelir, Josep20, borjiguez, THC77, di360, Juanjocantabria, grijan 2.0, copii92, JDMG, Morales92, nadiia.bcn93, yo_javi89, yurkli, Atajunen, carlo13, Desertcuervo, floppy666, amg129, manjerico, Franr50, iNFeCTeD, Rotemburgero, Link, kivamz, dj_ferrix, manu5, Vagabundo, aaronfdez, Manzi, Perilla, juanaco, pepetgi, pistoleromtb, cp_jj, diepecu2, Freddy169, Welmonk, JaquetónST, alrodri, LuisNM, Rekoba, bizu, ginyu 83, ephreon, rr7mo, Def89, CrisFRST5F, Mohoska, gilen44, ayl, SantiPMI, Jesús Peinado, 05kar, Lata8, Adrián pcg, Warelio, carlosVACA, trazas, barris31, danieleon, enriquevalera, antonioagui95, tito68, Sarge86, victorvOrtiz, bigpicha, ericoperico, JulinM, AlvaroRamlo, josermancol, Davidv, flotter, V de Viana, zainao, LeónST, rubiotuning, RacingSport
Re: OBDeleven - Dudas y Mods para León MK3
Notapor MORKAS el 30 Sep 2020, 11:30
Cup_Racing escribió:
Mr.Chuflas escribió:
Cup_Racing escribió:Buenos días, hay alguna manera de cortar la regeneración de opf y que deje de hacerla? O decirle directamente que no la haga?
No me parece buena idea, primero porque las regeneraciones son para destaponar el fap y si las anulas, petará el fap que será bastante más costoso que aguantar las regeneraciones
No lo llevo, pero tampoco llevo electrónica de momento. Así que me daría igual.
Lo que quiero esque cuando me salte pararlo, por ha entrado en bucle. Pero no da ningún fallo en la unidad de motor, solo sale en el cuadro, sube las rpm, enciende ventiladores y sube el consumo casi 1.5 litros largos
Pues eso tendra que anularlo un reprogramador...supongo....digo yo...no creo que por obd11 se pueda...
MORKAS
Agradecido: 368 veces
Notapor Cup_Racing el 30 Sep 2020, 17:16
Si está claro, pero quiero saber si hay algún método para que deje de hacer la regeneración solamente hasta que reprograme
Cup_Racing
Agradecido: 19 veces
Notapor JMR9 el 30 Sep 2020, 18:23
Hola buenas haber si alguien me puede ayudar, voi a cambiar un cuadro analógico por otro Digital, y necesito codificar las llaves, y nose si con obdeleven se puede hacer, si es Asín aver si alguien me da una solución. Graciiias
JMR9
Notapor UnaitxoST el 04 Oct 2020, 12:52
Buenos dias:
Soléis dejar el OBDELEVEN siempre conectado o solo lo conectáis cuando vais a mirar algo?
Yo siempre lo llevo conectado y tengo el error u14600 ( corriente de regimen de reposo demasiado alta)
Si lo desconecto de la toma OBD nunca aparece el error, pero si lo dejo puesto tengo ese error en la gateway.
Puede ser por que detecta un consumo en la toma?
UnaitxoST
Coche: Leon MK4 1.4 e-HYBRID 204cv
Notapor cvillajos el 04 Oct 2020, 13:00
UnaitxoST escribió:Buenos dias:
El buscador es tu amigo viewtopic.php?f=8&t=116700&p=2123592&hilit=OBDeleven+siempre+conectado#p2123592
cvillajos
Agradecido: 3572 veces
Notapor Romera el 04 Oct 2020, 14:48
Hoy he conseguido activar cierre de cristales en caso de lluvia en un my17 con sensor de 2 puntos.
El proceso, el mismo. Prueba, tapar sensor de lluvia por 30 segundos.... Se cierran sin problema.
Por así decirlo, la diferencia es que no tiene modo confort de subida.... Pero en sí, si llueve las gotas están en la zona del sensor y terminan subiendo igualmente.
Enviado desde mi LG-G7 Thinq mediante Tapatalk
En este mensaje, Romera ha recibido 2 agradecimientos de:
Rotemburgero (04 Oct 2020, 16:33), Warelio (05 Oct 2020, 17:40)
Romera
Agradecido: 316 veces
Notapor Rotemburgero el 04 Oct 2020, 20:36
Romera escribió:Hoy he conseguido activar cierre de cristales en caso de lluvia en un my17 con sensor de 2 puntos.
Confirmado, nada más cerrar el coche si lo tapas completamente cierra todas las ventanas salvo el techo. Había algo especial para el techo?
Enviado desde mi VOG-L29 mediante Tapatalk
Rotemburgero
Agradecido: 23 veces
Notapor Romera el 04 Oct 2020, 20:42
Si, poner sensor de lluvia de 4 puntos.
Romera
Notapor Rotemburgero el 04 Oct 2020, 20:43
https://youtu.be/QNqKwEm9WlY
Rotemburgero
Notapor Rotemburgero el 05 Oct 2020, 09:18
Sobre el mod de cerrar automáticamente con Kessy al cerrar la puerta del conductor.
En el MY19 lo he encontrado aquí:
internal_passive_entry_exit_byte1
Lo que no se me cierran los retrovisores, debo modificar algo más?
Adjuntos
Rotemburgero
Notapor Fran22_9 el 08 Oct 2020, 01:38
Hola muy buenas!! Yo tengo un León ST 1.5 con 150cv automático. Pero habláis de my17, my18, my19... Pero yo no tengo ni la menor idea de cuál es el mío. Como podría saberlo o dónde mirarlo??gracias.
Fran22_9
Notapor cvillajos el 08 Oct 2020, 06:40
Fran22_9 escribió:Hola muy buenas!! Yo tengo un León ST 1.5 con 150cv automático. Pero habláis de my17, my18, my19... Pero yo no tengo ni la menor idea de cuál es el mío. Como podría saberlo o dónde mirarlo??gracias.
MY'XX es Model Year. El año de fabricación (no natural) del coche. Generalmente cambia el la semana W22 del año o algunas veces en la W45. Para saberlo: viewtopic.php?f=37&t=94087&hilit=Bastidor+posicion+fabricacion&start=15#p1967058
cvillajos
Notapor Gendos22 el 08 Oct 2020, 06:48
Rotemburgero escribió:Sobre el mod de cerrar automáticamente con Kessy al cerrar la puerta del conductor.
Cierre con un toque es lo que tienes que añadir creo recordar para que ce plieguen los retrovisores al cerrar la puerta
Отправлено с моего SM-N960F через Tapatalk
Gendos22
Agradecido: 82 veces
Notapor Agonza86 el 14 Oct 2020, 09:44
Hola chicos, no sé si alguien más probó estos mods:
"Cambiar fuerza del servofreno
*Aplicable a todos los modelos*
Según theoldboy, lo ha probado en su cupra y nos comenta lo siguiente:
Lo configuré para una mejor sensación y una fuerza de frenado agradable y firme.
Cuanto menor sea el valor, más firme será la sensación.
La sensación del pedal es mucho más firme y directa.
Se encenderán algunas luces del tablero y se apagarán cuando se ponga de nuevo contacto.
1 - Módulo 03 - Electrónica de los frenos - Code (40168/20103)
2 - Adaptación
3 - Servofreno -- (Cambiar valor al deseado - Por defecto 4)
Presión progresiva sobre la frenada
Según theoldboy, permite al conductor modular la presión del freno progresivamente. Evita que el coche active involuntariamente los abs.
2 - Adaptación
3 - Asistente hidráulico de frenada -- (Cambiar valor a No Activado )"
¿Alguien más los ha probado?
Para ir contrastando opiniones.
Saludos!!
Mi misil: viewtopic.php?f=43&t=112454
Life on the road, V8 POWER :bandit: :bandit: :bandit:
En este mensaje, Agonza86 ha recibido un agradecimiento de:
MORKAS (14 Oct 2020, 10:02)
Agonza86
Agradecido: 403 veces
Notapor MORKAS el 14 Oct 2020, 10:03
Agonza86 escribió:Hola chicos, no sé si alguien más probó estos mods:
2 - Adaptación
2 - Adaptación
Saludos!!
Yo no consigo el código de seguridad..ninguno me vale...he de probar uno a uno a ve si doy cual es
MORKAS
