Buenas tardes a todos.
Estoy empezando con el vag com y despues de hacer un test me salen los siguientes fallos, a ver si me podeis ayudar y decirme de donde vienen que no entiendo ni papa.
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC X84 4944
Revision: 00X84H22
Coding: 01110012032401090000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM16TDI01104L906021M 002007
ROD: EV_ECM16TDI01104L906021M_SE37.rod
VCID: 2F740357271DB5FAB6BADD1-807A
2 Faults Found:
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Freeze Frame:
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 A HW: 5Q0 907 379 A
Component: ESC H75 0333
Revision: 00000000 Serial number:
Coding: 20EE629220220A6F0078060001C5240446045000608024F200490020C0
Shop #: WSC 00049 770 00102
ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 3A622203EC5F6052112454D-806E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 17
Reset counter: 143
Mileage: 49855 km
Date: 2017.01.28
Time: 18:31:54
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 HW: 5F0 907 044
Component: Climatronic H02 0503
Revision: 00001K05
Coding: 00000104202100011005004000101000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 63DCBF673B55419A6282911-8036
2 Faults Found:
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 164
Mileage: 50101 km
Date: 2017.02.03
Time: 16:31:10
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 50828 km
Date: 2017.02.06
Time: 22:17:18
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011302900965
Coding: 08000842C2C102FB4BE44000400403081008000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 439C5FE79B95219A42C2311-8016
Slave 1:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 121125 041 0574
Serial number: 121215040337
Coding: 0BC5FD
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21375281
Coding: 02006C
1 Fault Found:
0531 - Footwell Illimunation
B11FF 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 131
Mileage: 26983 km
Date: 2015.05.28
Time: 18:06:39
Antes de borrarlos por si es algo grave..
Gracias por adelantado.
Fallos vagcom en mk3 [solucionado]
9 mensajes
- Vistas: 3.334
Aprende de tus errores, pero que no te frenen.
javisfr - Asidu@ en la selva
- Agradecido: 12 veces
Re: Fallos vagcom en mk3
pues yo creo que antes de darle importancia a ninguno de estos avisos los borraria si no has echo un borrado desde que lo tienes ,rueda con el coche un par de dias y vueve ha realizar una lectura ...y los que te salgan esos si son errores actuales porque sino se ha borrado desde que te lodieron pueden ser errores puntuales de la cadena de montaje o de la puesta a punto....
disfrutando de mi seat leon tsi act...
ROBERTO206 - Leoner@ avanzad@
- Agradecido: 184 veces
porcierto el ultimo error es porque as puesto lud led en los pies del habitaculo verdad?
tienes que codificar con vag com para decirle que llevas led en esos puntos de iluminacion
El de la 09 ya te lo ha comentado @ROBERTO206
Los de la 08 son intermitentes, prueba a borrarlos y ver si vuelven a salir. Si es así -> a la Seat.
El de la 03 es porque te ha saltado en algún momento el aviso de control de neumáticos.
Los del motor, ni idea, pero lo mismo, borra y revisa si vuelven a salir dándote una vuelta. Si salen -> a la Seat.
- Agradecido: 3612 veces
Primero gracias por contestar.
Si nunca he borrado ningún mensaje desde que lo tengo, así que probaré a lo que decís de borrarlos circular y a ver si vuelven a salir.
Si cambie todas las luces interiores por led, y hace poco me saltó el aviso de los neumáticos,
Probaré a borrarlos a ver si persisten.
Gracias por las respuestas.
Hice ajustes en la iluminación de los pies y borre todos, en principio todo OK.
GRACIAS
GRACIAS
javisfr escribió:Hice ajustes en la iluminación de los pies y borre todos, en principio todo OK.
GRACIAS
Hola muy buenas a ver si me podeis echar una mano. Tengo ese mismo fallo de iluminación que @javisfr porque cambié a leds. Donde hay que poner en el VCDS que llevas led en el reposapies? Que he buscado y no doy con ello en ninguna centralita
Gracias!!
Samueleitor - Nuev@ por aqui
- Agradecido: 8 veces
En el módulo 09
Leuchte30FR LC72 lasttyp 30
Cambiar valor a Led Kleinleistung - (Por defecto 2*5W)
javisfr escribió:En el módulo 09
Mil Gracias! Y yo dando vueltas jajaj
Un Saludo!
9 mensajes
Nuevo en el club Foro: Presentaciones Autor: Otsoa Respuestas: 2 |
Ruido en suspension Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: Terribleño Respuestas: 31 |
Error en repostaje ... cilindro 2 no comprime. Foro: Leon IV - Mecánica / Electricidad / Electrónica Autor: mcbogalep4 Respuestas: 3 |
velocidad control velocidad en FIS Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: jotica Respuestas: 0 |
