Fallos vagcom en mk3 [solucionado]
Buenas tardes a todos.
Estoy empezando con el vag com y despues de hacer un test me salen los siguientes fallos, a ver si me podeis ayudar y decirme de donde vienen que no entiendo ni papa.
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC X84 4944
Revision: 00X84H22
Coding: 01110012032401090000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM16TDI01104L906021M 002007
ROD: EV_ECM16TDI01104L906021M_SE37.rod
VCID: 2F740357271DB5FAB6BADD1-807A
2 Faults Found:
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
21125 - Invalid Data Received from Airbag Control Module
U0452 00 [032] - -
Freeze Frame:
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 A HW: 5Q0 907 379 A
Component: ESC H75 0333
Revision: 00000000 Serial number:
Coding: 20EE629220220A6F0078060001C5240446045000608024F200490020C0
Shop #: WSC 00049 770 00102
ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 3A622203EC5F6052112454D-806E
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 17
Reset counter: 143
Mileage: 49855 km
Date: 2017.01.28
Time: 18:31:54
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 HW: 5F0 907 044
Component: Climatronic H02 0503
Revision: 00001K05
Coding: 00000104202100011005004000101000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 63DCBF673B55419A6282911-8036
2 Faults Found:
328964 - Motor for Front Air Distribution Flap
B1091 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 164
Mileage: 50101 km
Date: 2017.02.03
Time: 16:31:10
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 50828 km
Date: 2017.02.06
Time: 22:17:18
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 N HW: 5Q0 937 084 N
Component: BCM MQBAB M H14 0106
Serial number: 00011302900965
Coding: 08000842C2C102FB4BE44000400403081008000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 439C5FE79B95219A42C2311-8016
Slave 1:
Subsystem 1 - Part No SW: 5F1 955 119 HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 121125 041 0574
Serial number: 121215040337
Coding: 0BC5FD
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21375281
Coding: 02006C
1 Fault Found:
0531 - Footwell Illimunation
B11FF 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 131
Mileage: 26983 km
Date: 2015.05.28
Time: 18:06:39
Antes de borrarlos por si es algo grave..
Gracias por adelantado.
Revision: 00X84H22
2 Faults Found:
U0428 00 [032] - -
Freeze Frame:
U0452 00 [032] - -
Freeze Frame:
1 Fault Found:
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 143
Mileage: 49855 km
Date: 2017.01.28
Time: 18:31:54
Revision: 00001K05
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 164
Mileage: 50101 km
Date: 2017.02.03
Time: 16:31:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 152
Mileage: 50828 km
Date: 2017.02.06
Time: 22:17:18
Slave 1:
Coding: 0BC5FD
Slave 2:
Coding: 02006C
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 131
Mileage: 26983 km
Date: 2015.05.28
Time: 18:06:39
