mis errores de vag com
NotaPublicado: 20 Abr 2017, 22:29
por lumgumdum
hola acabo se pasar el vag com por primera vez y me salen estos errores
5 Faults Found:
5642 - Bulb for Rear Left Turn Signal
B11E9 15 [008] - Open or Short to Plus
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.06
Time: 08:44:36
6154 - Bulb for Rear Right Turn Signal
B11EB 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.06
Time: 08:41:44
10506 - Bulb for Left Tail Light
B12BE 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.05
Time: 17:20:10
10762 - Bulb for Right Tail Light
B12BF 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.05
Time: 17:20:10
12298 - License Plate Light
B12CA 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.06
Time: 09:01:36
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617069
Coding: 0471051001
Shop #: WSC 00049 770 00103
ASAM Dataset: EV_EPHVA18AU3700000 009031
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 4A9CB96AED24491177-801E
1 Fault Found:
1080083 - Rear Parking Aid Sensor(s)
B107B 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.05
Time: 17:20:23
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.06
Time: 08:44:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.06
Time: 08:41:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.05
Time: 17:20:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.05
Time: 17:20:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.06
Time: 09:01:36
Coding: 0471051001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 41
Mileage: 4 km
Date: 2017.04.05
Time: 17:20:23
1 Fault Found:
5688 - Control Head for Mulimedia System
B13C9 F2 [008] - On/Off Switch
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 42
Mileage: 48 km
Date: 2017.04.07
Time: 11:56:01
Voltage terminal 30: 12.6 V
antes de borrarlos para ver si vuelven a aparecer quería ver si os parecen graves, no he hecho ninguna modificación
Re: mis errores de vag com
NotaPublicado: 20 Abr 2017, 22:59
por cvillajos
Algo estuviste tocando (o te estuvieron en el concesionario antes de entregar y luego no borraron fallos) en las conexiones o en los cables de la trasera los días 5 y 6 de abril... Todos menos el último son a las mismas horas +-, intermitentes, con una sola ocurrencia y 4km de kilometraje (pre-entrega, vamos). Los borraba sin miramientos.
El último tiene pinta de ser del botón de activación del park assist, pero exáctamente no sé lo que es... También lo borraría por ser del 7 de abril, intermitente y con una sola ocurrencia si has utilizado más veces el park assist sin problemas desde entonces.
NotaPublicado: 21 Abr 2017, 07:36
por lumgumdum
cvillajos escribió:Algo estuviste tocando (o te estuvieron en el concesionario antes de entregar y luego no borraron fallos) en las conexiones o en los cables de la trasera los días 5 y 6 de abril... Todos menos el último son a las mismas horas +-, intermitentes, con una sola ocurrencia y 4km de kilometraje (pre-entrega, vamos). Los borraba sin miramientos.
Gracias haré eso, los borrare
