Errores no se a que se deben VAGCOM Diagnosis
NotaPublicado: 07 Sep 2020, 07:45
por el_pajaro
necesito ayuda para leer estos errores de VagCom que aparecen en mi coche, si alguien es tan amable de echarme un cable!
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ5PZ5R003763 Mileage: 145950km/90689miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010 (LA PUERTA ABRE Y CIERRA BIEN, no se a que se deberá.)
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010 (la radio tambien funciona bien, aunque hay que tener un cd metido dentro siempre.
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DH HW: 028 101 186 4
Component: R4 1,9L EDC 0000SG 6093
Revision: 12345678 Serial number: SEZ7Z0D2603872
Coding: 0050071
Shop #: WSC 06401 785 00200
VCID: 6CD7223B4F7E2C7E58B-8039
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 N
Component: ASR FRONT MK70 0103
Coding: 0017025
Shop #: WSC 06402 785 00200
VCID: 3D71DF7F648475F6BF5-8068
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 5P0 820 047 H
Component: Climatic PQ35 007 0201
Shop #: WSC 00000 000 00000
VCID: 326BFC43ADDABA8E527-8067
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 K HW: 1K0 937 049 K*
Component: Bordnetz-SG 1.0 H29 0701
Revision: 00029000 Serial number: 00000001175326
Coding: 00880F2700041000001E00000000000000
VCID: 377DCD5746B85FA6659-8062
Subsystem 1 - Part No: 5P0 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0401
Coding: 00056272
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 0H AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0DDYJV
Coding: 0012360
VCID: 2D51EF3FB4E4E5760F5-8078
Subsystem 1 - Serial number: 6332MSME5A457702
Subsystem 2 - Serial number: 6342MSME50193E03
Subsystem 3 - Serial number: 6351HSME590C6F02
Subsystem 4 - Serial number: 6361HSME0C086102
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 B HW: 1K0 953 549 B
Component: Lenksäulenmodul 013 0010
Coding: 0002002
VCID: 3169F34FA8DC81962BD-8064
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 802 G
Component: KOMBIINSTRUMENT VO3 1054
Coding: 0000101
Shop #: WSC 06403 785 00200
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 21001044302702
Coding: 3D3F0340078202
VCID: 275D1D179618CF26F59-8072
1 Fault Found:
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 16
Time Indication: 0
Date: 2000.00.00
Time: 17:30:25
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 1054
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0139
Coding: 0000016
VCID: 3561C75F5CB4ADB6775-8060
3 Faults Found:
00100 - Drivers Interior Locking Button (E308)
008 - Implausible Signal - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
012 - Electrical Fault in Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.13 1301
VCID: 2E53E833B9E29E6E36F-807B
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 C
Component: KSG 0201
Coding: 19C000BC090005054C4F0900
VCID: 306FF64BA3D6889E243-8065
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
VCID: 3663C05341B2A6AE7EF-8063
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0029
Coding: 0040400
VCID: E6C3D013D192962E8EF-80B3
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
VCID: 2F6DF537BEE897663D9-807A
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000016
End ---------------------------------------------------------------------
