Montage computer board on Seat Leon 1
Seguidores: bucanero
Notapor criss_b el 22 Ago 2007, 13:20
Hello!
I wish to montage Computer board on Seat Leon 1 engine 1.4L 16V 75Cp AXP model 2001-2002.I made some tests with Vag-Com (a don't see any errors and real consumptions in Instruments block).
Please send me any sugestion at cris_boboc@yahoo.com
criss_b
Notapor elGersonFr el 22 Ago 2007, 13:54
Hello.
You need change the dashboard of your car by one that if has computer board.
greetings ¡¡
Pd: Si alguien del foro sabe ingles en condiciones que se lo explique con mas detalle si puede¡¡
elGersonFr
Agradecido: 33 veces
Notapor bucanero el 22 Ago 2007, 13:58
First of all, welcome to our club. I´d read your post and there are something that I hadn´t understood:
* You have already mount the onboard computer or you´ll mount it and you need some instructions.?
If you need some instructions try this manual http://www.fullcustom.es/data/car_leon_manuales/interior_cambio_cuadro_ordenador_abordo.pdf the manual is in spanish but I hope it will be usefull to you.
If you had already mount the board computer and need some help with VagCom errors maybe someone here can help you.
Regards
P.s: Sorry if my english is not so good.
Última edición por bucanero el 22 Ago 2007, 14:30, editado 1 vez en total
bucanero
Notapor elGersonFr el 22 Ago 2007, 14:14
thanks bucanero ¡¡ my english is lamenteibol and catastrofic ... jejeje
:fumeta:
elGersonFr
Notapor bucanero el 22 Ago 2007, 14:17
elGersonFr escribió:thanks bucanero ¡¡ my english is lamenteibol and catastrofic ... jejeje
:fumeta:
don´t worry be happy :troncharse2:
bucanero
Notapor ChiLL el 22 Ago 2007, 14:28
bucanero escribió:P.s: Sorru if my english is not so good.
Sorru?? lo pones todo bien y la cagas en lo mas facil??! :maruja:
ChiLL
Coche: Leon MK2 1.9 TDI 90cv
Notapor bucanero el 22 Ago 2007, 14:34
:oops: sorry my friend prometo que lo he revisado antes de postearlo y me he dado cuenta de ese y de un par mas los he corregido pero ese se lo ha pasado por el forro jejeje. :troncharse2:
bucanero
Usuarios navegando por este Foro: Anthropic y 64 invitados
