Mi lista de fault codes!
Seguidores: Sergio_VK, eftuning, enriquedopico, evola_200
Notapor eftuning el 17 Nov 2008, 23:02
Hola no suelo postear mucho por aqui pero después de 2 dias poniendome en serio con mi lista de errores e logrado entenderlos y la mayoría eliminar los....otro en particular me da un poco de dolor de cabeza...
primer scaneo
casi me da un soponcio pero al final no fue pa tanto ... :P
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 FK
Component: 1,9l R4 EDC G500SG 3357
Coding: 00002
Shop #: WSC 06402
VSSZZZ1MZ3R084486 SEZ7Z0B1868404
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 00043
Shop #: WSC 03329
1 Fault Found:
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J5 920 826 C
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 07102
Shop #: WSC 00000
WVWZZZ1JZ3W184303
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01336 - Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
00476 - Control Module for Fuel Pump (J538)
49-00 - No Communications
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01271
3 Faults Found:
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 9V Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
End -------------------------------------------------------
No es pa tanto .....primer error
he deducido este error a mi cuadro golf /bora sport jajajajaja
no es coña en verdad el error esta en que le puse q me pitara el cinturon de seguridad y de hay el problema ...me esta diciendo que revise el cuadro ya q hay fallos...y dentro de ese error al mismo tiempo sale el error intermitente del cinturon....
P1672 - 35-00 - -
El segundo error el del ventilador ese me dio yuyu ya q es del motoventilador del radiador... si no me equivoco es un cortocircuito,pero este lo elimine y ya no me aparece.....de todas maneras ya estoy advertida.
Coding: 00043
Shop #: WSC 03329
1 Fault Found:
Este es el q mas por saco da es sobre el climatizador ya q es su modulo.jajaja y lo traducido de este fallo es:
SEÑAL PARA EL ESPACIO DE TIEMPO CON EL ENCENDIDO DESCONECTADO
Pues ahora ademas de no comunicarse bien este modulo con el vag....me dice esto....
Control Module Part Number: 1M0 820 043 E
Component and/or Version: 1M-CLIMATRONIC X0702
Software Coding: 00043
Work Shop Code: WSC 03329
No Faults Found
or DTCs not supported by controller
a communication error ocurred
y hoy me dice ademassssssssssssssss de eso ya se ha rayado y el error ya no sale y dice.....:)
Coding: 00043
Shop #: WSC 03329
Note: Excessive Comm Errors
Que mono a que si! lo bueno es q el clima funciona asi que no se a que es devido......
Bueno pasamos al modulo 17
aqui hay 3 errores !
El primero....01314 - Engine Control Module
fallo de comunicación.....no habia logueado
El segundo! Este lo he ido arrastrando desde hace casi un año....al final lo he podido borrar!!!
Este lo cause yo sin querer cuando cablee el cuadro al conector famoso marron de la centralita para q lea las puertas o sea hice masa o algo por el estilo y se ha resistidoooooo!!!!
El tercero!!!!juasss
Este es un error curioso! este es q el cuadro no encuentra el inyector bomba o sea no se comunica con el jajajajja mi coche es un TDI110cv
Como se nota q el cuadro era de un 130 cv ....mi coye no es inyector bomba.
El siguiente modulo es lo mismo!!!
Bueno pues ahora se ha kdao de lo mas mono!!!
Este es el scaneo de hoy!!!
Coding: 00002
Shop #: WSC 06402
1 Fault Found:
Readiness: N/A
Coding: 0021505
Shop #: WSC 00001
Coding: 07102
Shop #: WSC 00000
WVWZZZ1JZ3W184303
1 Fault Found:
Coding: 00006
Shop #: WSC 01271
1 Fault Found:
Coding: 00258
Shop #: WSC 06402
El modulo 8 del clima es el q me asusta.....alguna solución???
Leon rojo flash sport asv 2003 ...despues vino el leon 1m fr rojo emocion especial edition en el 2013 y ahora CUPRA 2018
BY ELENA.
eftuning
Agradecido: 20 veces
Notapor eftuning el 17 Nov 2008, 23:48
He estado pensando y si que es relacionable el fallo del motoventilador con el modulo del clima......
voy a llorar! :(
BY ELENA.
eftuning
Notapor eltitoxusmi el 18 Nov 2008, 00:16
Has probado a borrar todos y darte una vuelta a ver cuantos te salen?
alguien escribió:Aclárate las neuronas pardillo. ¿Crees que luchamos por la libertad? Esto es una matanza. Y si me van a reventar las pelotas por una palabra... mi palabra es PUTADA.
eltitoxusmi
Notapor eftuning el 18 Nov 2008, 00:36
jajajaj no me digas nada q estoy empezando a estar acojonada ya q desde hace 1 hora estoy sacando conclusiones y pa mi q me esta petando la centralita confort
porq estoy asociando mis problemas de arranque raros con lo q habeces se me raya la apertura de puertas cuando saco la llave del clausor y hace cosas raritas a estos fallos q me ha dado!
ahhhhhhhhhhhhhhh ahora si qvoy a llorar!
BY ELENA.
eftuning
Re: Mi lista de fault codes!
Notapor Prometeo el 18 Nov 2008, 11:21
Elena, haz una cosa borra todos los eerores de todos los modulos y vete a dar una vuelta con el coche, despues vuelve a pegar los errores que te dan vale ? para saber cuales son fijos y cuales eran esporadicos.
Prometeo
Notapor eftuning el 18 Nov 2008, 13:02
Esta noche lo escaneare a ver que me dice....,pero primero quitare bateria y me metere en e can gateway ese (modulo 19) y are lo del recoding como tmb me han aconsejado....
Lo q estoy viendo q es fijo es el modulo 8 que tiene demasiados errores y no conecta con el .:(
BY ELENA.
eftuning
Notapor Prometeo el 18 Nov 2008, 13:31
Tu tranquila. REsetea bateria, haz lo que ha dicho madelgado del can-gateway y borrar todo, da una vuelta y escanea y peganos aqui lo que te dice ahora, que despues ya iremos buscando solucion :D.
Prometeo
Notapor Sergio_VK el 18 Nov 2008, 18:48
Prometeo tiene razón, tu haz caso a madelgado y si ves que sigue entonces ya buscar una solución. Si lo dice madelgado es bastante probable que sea la solución.
Sergio_VK
Notapor eftuning el 19 Nov 2008, 21:43
he intentado hacer lo de gateway ese y he puesto lo del recode y nada me sigue dando este fallo:
Coding: 00043
Shop #: WSC 03329
1 Fault Found:
Entro en el modulo pero se raya cuando le doy a faut codes para borrarlo ...hay empieza a pensar y al final no me dice los errores y me da un fallo de comunicacion o si vuelvo a escanear ya me dice demasiados com errore en ese modulo
voy a llorar!
mi mecanico me ha dicho q la centralita se me puede volver un poco loca por culpa de la bateria ...como la tengo medio cascada dice q puede dar errores cuando arranca por no llegar bien la luz....
Ahhh solo he podido hacer eso de recode en el modulo gateway porq con lo otr q me ha dicho no hay forma de aclararme....
he entrado en gateway le he dado a recode he apuntado el codigo otra vez (que era el mismo que me decia el modulo 00006 y le e dao a doit! con eso se supone q ya esta??
BY ELENA.
eftuning
Notapor enriquedopico el 26 Ene 2012, 11:45
Como ha quedado esto??? Lo del módulo 8, nos pasa a todos los que llevamos cuadro GOLF.
Peeeeeeero que ha pasado con este error???
Yo lo tengo en el 17, 19 y 46. Fue después de que se me acabara la batería, pero no sé si no sería a causa de arrancar con pinzas y quitarlas demasiado rápido una vez.
Si no es eso, serán los cables, y sino recodificar de nuevo la activación del can-bus con el VDS-PRO. Veo que tu pasaste sólo un cable, yo pasé los 2 trenzados de Can-HI y Can-LOW.
Todo me va perfecto pero es imposible borrarlos, ya hice el recode del 19 y del 17 y del 46, jeje. Pero sin soltar la batería, es lo 1º que voy a probar...
Saludos y gracias!!
enriquedopico
Notapor eftuning el 16 Feb 2012, 13:24
Yo no he podido quitar este fallo al parecer es una masa que me hace en el modulo confort algun cable....los repase todos ...pero tengo muchos jajajaja los del cuadro que si que los trenze, los de la alarma oem los del techo solar....
BY ELENA.
eftuning
Notapor evola_200 el 16 Feb 2012, 15:14
pos yo creo q eso va a ser del cuadro ese tan wapo q tienes sport edition... vas a tener que regalarmelo, verás como se te borran esos fallos :PPPPPP!!!!!!!
evola_200
Usuario baneado
Agradecido: 82 veces
Notapor eftuning el 24 Feb 2012, 02:50
evola_200 escribió:pos yo creo q eso va a ser del cuadro ese tan wapo q tienes sport edition... vas a tener que regalarmelo, verás como se te borran esos fallos :PPPPPP!!!!!!!
jajaja estoy tantos años con cuadros de golf que mi coche no sabe ir sin el jajajaja
En movimiento desde mi sgs2
BY ELENA.
eftuning
Notapor pirrol el 24 Feb 2012, 10:12
Controller: 1J5 920 826 C ?????
como te puede salir esto en el modulo 17 si es tuyo es fiss completo.... seria 846
pirrol
Agradecido: 163 veces
Notapor enriquedopico el 24 Feb 2012, 10:38
Será por ser 1J5 ????
yo tengo FIS completo 1J0 y es 846, a saber...
enriquedopico
Usuarios navegando por este Foro: AmazonBot, Anthropic y 4 invitados
