Hoy me he decidido a meterle el vag-com al coche, y le he echo el primer scan y me ha dado este esto, creo ke me da algunos errores,pero como no entiendo nada de esto, y aki ahi muchas personas ke saben de lo ke habaln... pues a ver si me podeis decir ke errores son.
Tuesday,14,July,2009,10:53:42:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R049206 Mileage: 66530km/41339miles
Address 01: Engine Labels: 038-906-019-150.LBL
Part No: 038 906 019 FK
Component: 1,9l R4 EDC 0000SG 1429
Coding: 00002
Shop #: WSC 06441
VSSZZZ1MZ2R049206 SEZ7Z0A1386112
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.LBL
Part No: 1C0 907 379 G
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00001
3 Faults Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
008 - Implausible Signal - Intermittent
012 - Electrical Fault in Circuit
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Address 08: Auto HVAC Labels: None
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00043
Shop #: WSC 06441
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
4 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
06-10 - Signal too High - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
Address 17: Instruments Labels: None
Part No: 1M0 920 802 D
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 05124
Shop #: WSC 03594
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Part No: 1C0 959 799 F
Component: 3K Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
Part No: 1C0959801B
Component: 3K Tõrsteuer.FS KLO 0002
Part No: 1C0959802C
Component: 3K Tõrsteuer.BF KLO 0002
Part No: 1C0959811A
Component: 3K Tõrsteuer.HL KLO 0002
Part No: 1C0959812A
Component: 3K Tõrsteuer.HR KLO 0002
3 Faults Found:
01131 - Control Circuit for Turn Signals
25-10 - Unknown Switch Condition - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00935 - Electric Window Motor; Rear Right (V27)
End --------------------------------------------------------------------------------------------------
Tambien comentaros k he intentado kitar el chivato del airbag y me ha sido imposible, haciendo lo ke dice e manual.
Tuesday,14,July,2009,11:33:14:55371
Address 15: Airbags
Control Module Part Number: 1C0 909 605 A
Component and/or Version: 1L AIRBAG VW51 0A 0004
Software Coding: 12620
Work Shop Code: WSC 06441
4 Faults Found:
00-00 - -
-elGersonFr-Título editado por no ser suficientemente explícito.-
Errores al chequear en estreno vag-com
8 mensajes
Txelis - Leoner@ habitual
- Agradecido: 5 veces
Re: Errores al chequear en estreno vag-com
Hola.
El error del airbag no puedes eliminarlo hasta que no repares la averia que tiene.
Ese error suele ser el anillo del airvag que esta en el volante, cambiandolo deberia solucionarse.
Si no es eso posiblemente este cascada la centralita del airbag.
Con respecto al error que tienes en el modulo 01-motor esto es lo que tengo.
Error: 17664
Averia: Sensor de temperatura del refrigerante del motor-circuito abierto/cortocircuito a positivo.
Posible causa/Solución: Sensor de temperatura del refrigerante del motor(el situado en la botella del refrigerante),
circuito abierto/cortocircuito a positivo del cableado.
Con respecto a los errores que tiene en los modulos 46 y del abs parecen intermitentes.
Yo borraria los errores de todos los modulos electrónicos y los que vuelvan a salir son los que realmente necesitan una reparación al no tratarse de un simple error puntual.
Saludos ¡¡
Error: 17664
Saludos ¡¡
elGersonFr - Leoner@ mayor del reino
- Agradecido: 32 veces
elGersonFr escribió:El error del airbag no puedes eliminarlo hasta que no repares la averia que tiene.
Les comentare a los de la seat lo del anillo, cuando dices ke esta cascada la centralita a ke te refieres, al airbag o el airbag llevaalguna centralita??? es ke yo de mecanica 0.
elGersonFr escribió:Con respecto al error que tienes en el modulo 01-motor esto es lo que tengo.
Error: 17664
Esto es algo grabe o algo ke deba cmabiarse, por ke no se hasta ke punto es importante.
elGersonFr escribió:Con respecto a los errores que tiene en los modulos 46 y del abs parecen intermitentes.
Les comentare en la seat ke me miren los errores y a ver ke debo hacer.
Por lo general no veis nada importante ni grave, no???
Lo ke si a ver si consigo en manual de como poner lo intermitentes al abrir y cerrar, ke e estado mirando por la web los manuales y los enlaces estan rotos.
Hola.
El error 17664 generalmente se produce por estar cascado el sensor que se encuentra en la botella del refrigerante y cambiandolo deberia solucionarse.
Efectivamente el airbag tiene una centralita electrónica que es el que controla el sistema del airbag.
Y lo que te digo es que probablemente es el anillo del airbag o es la centralita lo que este cascado una de las dos.
Hombre lo del airbag pues si seria bueno que lo solucionaras los temas de seguridad mejor no escatimar.
Y lo del abs exactamente lo mismo ten en cuenta que te marca error en el sensor del angulo de giro y posiblemte dicho sensor tambien se encuentre en el anillo del airbag (que se encuentra en el volante).
Pues lo del ABS igual sera error de ahi, por ke probe con el vagcom para hacer lo del ABS y funcionaba.
Les comentare a los de la seat a ver ke me dicen, aunke de todas formas yo llevo el volante sin airbag, pero me interesa kitar el chivato del cuadro, por ke llevo siempre encendio el del airbag y el ESP y no consigo kitarlos ni con el vagcom.
Txelis escribió:Pues lo del ABS igual sera error de ahi, por ke probe con el vagcom para hacer lo del ABS y funcionaba.
Como as quedado con el error del ESP??
1 Fault Found
No Corro Con El Coche... Yo Vuelo Bajo...
sebasresa - Mi Leon me tiene miedo
- Agradecido: 35 veces
sebasresa escribió:Como as quedado con el error del ESP??
1 Fault Found
Pues al final en agosto me fui de vacaciones a avila... y alli en una seat me lo kitaron con la makina... se furon a dar una vuelta con el coche y la makina y en 5 min me lo habian kitado... pero no me digas lo ke hicieron.
8 mensajes
Aditivos para aumentar el rendimiento en TDI Foro: Preparaciones de motor / Racing Autor: GUMBALL Respuestas: 167 |
Poner Usb-c Carga rápida en salida trasera Aireadores Reposa Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: iron109 Respuestas: 2 |
Alarma antirrobo en Seat León mk1 Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Dancar Respuestas: 1 |
sobre señales de trafico en Fis MK3 Foro: Informática / Interfaces / Diagnosis Autor: rojas Respuestas: 1085 |
Se me ha destensado el tensor en motor BKD Foro: Leon II - Mecánica / Electricidad / Electrónica Autor: gabrielorellana377 Respuestas: 0 |
