alguien me puede decir estos errores
Notapor pakorro20vt el 08 Oct 2009, 10:15
he hecho un autoescan y me ha dado esto alguien me puede decir q son y como se hace para borrar los fallos gracias
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 019 CF
Component: 1,9l R4 EDC 0000SG 1414
Coding: 00002
Shop #: WSC 02325
WAUZZZ4B72N073964 AUZ7Z0A1975458
3 Faults Found:
19464 - Camshaft Position Sensor (G40): Signal Out of Range
P3008 - 00-00 - -
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06255
Shop #: WSC 02325
No fault code found.
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 AA
Component: A6-Klimavollautomat 0105
Coding: 00103
Shop #: WSC 02325
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 920 933 M
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 00140
Shop #: WSC 00012
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 04686
Shop #: WSC 08017
7 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
61-10 - Won't De-Safe - Intermittent
01562 - Right Rear Door
Address 45 -------------------------------------------------------
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 56 -------------------------------------------------------
Controller: 4B0 035 152 C
Component: chorus II GRO 0007
Coding: 00002
Shop #: WSC 02325
End -------------------------------------------------------
pakorro20vt
Re: alguien me puede decir estos errores
Notapor knight12 el 17 Nov 2009, 09:19
Entra en los distintos módulos por separado. Lee los códigos de error y luego pincha en clear...se borraran todos. Vete a dar una vuelta con el coche y vuelvelo a pasar haber si se mantiene alguno. A partir de ahí, luego seguimos viendo. Saludos :ok:
knight12
Usuarios navegando por este Foro: AmazonBot, Anthropic y 3 invitados
