alguien me echa una mano con el texto del vag? gracias!
Notapor alex_leon_110 el 03 Mar 2010, 21:39
Hola compys!! hoy e quedado zwartin y me ha echo unas cosillas con el vag... os lo recomiedo es buen chaval :D yo de vag no tengo ni idea asy que aqui os dejo una cosa que a salido de hacerle un chequeo de esos y haber que me decis jeje gracias compys un saludo!!
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 FK
Component: 1,9l R4 EDC 0000SG 3357
Coding: 00002
Shop #: WSC 06441
VSSZZZ1MZ2R000819 SEZ7Z0A1200752
2 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
No fault code found.
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 D
Component: 1M-CLIMATRON
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1M0 920 802 D
Component: KOMBI+WEGFAHRSP VDO V01
Coding: 05122
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 F
Component: 3K Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
3 Faults Found:
01331 - Door Control Module: Driver Side (J386)
49-10 - No Communications - Intermittent
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
End -------------------------------------------------------
Sino vienes para servir!! No sirves para venir!! GOES.......
http://www.youtube.com/watch?v=uQZqWEK0MQ8
alex_leon_110
Re: alguien me echa una mano con el texto del vag? gracias!
Notapor dani injeccion el 06 Mar 2010, 13:59
Saludos, los fallos que te salen son los controles de las puertas del conductor, saca el panel de mandos desconectalo y limpia las clavijas con un residuo0 y vuelve a conectar y le pasas el vag :ok:
El 17965-regulacion de la presion de sobrealimentacion limite de regulacion sobrepasado.
El 18062-Por favor, dar salida de lectura del instrumento combinado.
Espero haverte ayudado compañero, haver si algun guru te puede especificar los dos siguientes fallos porque a mi solo me sale esto :ok:
Un saludo y suerte :ok:
'' Leonero hasta la medula''
''NOEL hermano mi mas sentido pesame nunka en la vida te voy a olvidar, ADIOS HERMANO''
frmaniatiko MI GALERIA viewtopic.php?f=13&t=57789
http://img169.imageshack.us/img169/2223/545624.png
C:\Users\Dani\Pictures\Mi gorditoooo
dani injeccion
Notapor alex_leon_110 el 07 Mar 2010, 23:39
mil gracias tio lo de la puerta del conductor es una movida por que me falla el centralizado de la puera del conductor alguna vez aunque desde que quite el seguro dela puerta del conductor casi no falla, gracia tio mañana hare lo que dices un saludo
alex_leon_110
Notapor dani injeccion el 07 Mar 2010, 23:59
A ti compañero :ok: , suerte.
Un saludo... :ok:
dani injeccion
Usuarios navegando por este Foro: Anthropic, Google [Bot] y 4 invitados
