fallos vag
hola amigos le pasado el cable al ibiza de mi hermana porque vibra muchisimo el coche y le sale el pilotito del motor haber que podria ser gracias de antemano... digo no abria forma de ponerlo en español??? gracias y aqui dejo el scan:
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 03E 906 033 D
Component: 1,2l/4V SIMOS3 00HS4342
Coding: 00061
Shop #: WSC 06402
VSSZZZ6LZ2R018887 SEZ7Z0A1480328
1 Fault Found:
16686 - Cylinder 2 Misfire Detected
P0302 - 35-00 - -
Readiness: 1110 0101
Address 08 -------------------------------------------------------
Controller: 6L0 820 045
Component: Klimaanlage X0840
6 Faults Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-00 - Open or Short to B+
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to B+ - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
28-10 - Short to B+ - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 16412
Shop #: WSC 06402
2 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
00907 - Intervention load Management
35-00 - -
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6L0 920 801
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 00137
Shop #: WSC 00000
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0909901
Component: Gateway K<->CAN 1S31
Coding: 00012
Shop #: WSC 06402
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 L
Component: LenkhilfeKYO V710
Coding: 00111
Shop #: WSC 06402
Controller: 6Q0 959 433 E
Component: 59 Komfortgerát 0001
Coding: 00067
Shop #: WSC 06402
1 Fault Found:
01179 - Incorrect Key Programming
35-00 - -
Address 56 -------------------------------------------------------
Controller: 6L0 035 152
Component: seat s04 GRO 0 67
Coding: 00201
Shop #: WSC 06402
End -------------------------------------------------------
Coding: 00061
Shop #: WSC 06402
1 Fault Found:
P0302 - 35-00 - -
6 Faults Found:
Coding: 16412
Shop #: WSC 06402
2 Faults Found:
35-00 - -
Coding: 00137
Shop #: WSC 00000
Coding: 00012
Shop #: WSC 06402
Coding: 00111
Shop #: WSC 06402
Coding: 00067
Shop #: WSC 06402
1 Fault Found:
35-00 - -
Coding: 00201
Shop #: WSC 06402
