un monton de errores, una ayudita?SOLUCIONADO
Notapor alainayerbe el 08 Oct 2010, 20:12
hola
he comprado hoy el cable y le he hechonel autoscan y me han salido muchos errores.
haber si me podeis ayudar,sobre todo con el airbag que lo borro y vuelve a salir:
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000006028829
Coding: F38A0F2700041000001E00000100000000007F0B1400000C000000000000
Shop #: WSC 00000 000 00000
Part No: 5P0 955 119 B
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 00000
Part No: 1P0 955 559
Component: REGENLICHTSENSORH04 0090
Coding: 00137517
Shop #: WSC 00000
1 Fault Found:
01334 - Door Control Module; Rear Right (J398)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 66
Mileage: 38398 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: S7 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0NRVPQ
Coding: 0021303
Shop #: WSC 06402 785 00200
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 847 C
Component: KOMBIINSTRUMENT VO3 0750
Coding: 0006101
Shop #: WSC 12345 123 04163
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 3100106724854C
Coding: 7D3F07C007001202
Shop #: WSC 03530 843 04876
3 Faults Found:
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 110
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 38398 km
Time Indication: 0
Date: 2000.00.00
Time: 10:55:47
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 251
Mileage: 25619 km
Time Indication: 0
Date: 2000.00.00
Time: 18:05:30
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 198008005183CC7F0002050560084F86107C00
Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 06402
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
2 Faults Found:
00896 - Trunk Lock Unit (F256)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 5
Reset counter: 81
Mileage: 38312 km
Time Indication: 0
Date: 2000.00.00
Time: 10:18:04
00830 - Convertible Top Control Module (J256)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 194
Mileage: 31165 km
Time Indication: 0
Date: 2000.00.00
Time: 00:25:06
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H21 0060
Revision: 00000001 Serial number: 00000000511990
Coding: 0000555
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 251
Mileage: 37692 km
Time Indication: 0
Date: 2000.00.00
Time: 12:25:07
Última edición por alainayerbe el 10 Nov 2010, 15:31, editado 1 vez en total
alainayerbe
Re: un monton de errores, una ayudita?
Notapor evola_200 el 03 Nov 2010, 01:47
Joder tio, q coche tienes? cuantos años tiene?.
Yo no llevo mucho tiempo con vagcom tp pero a mi por ejemplo cuando lo hice la primera vez me salieron muchos errores, los borré y volví a empezar.
Yo creo que muchas veces sale cualqier tonteria, la arreglas y queda el fallo grabado, borra los fallos, date un voltio y vuelve a hacerle un chequeo de fallos, a ver que tal va.
Suerte!
evola_200
Usuario baneado
Agradecido: 82 veces
