wenas compañeros pues me e decidido a utilizar el vag com soy principiante en ello y le e hecho a mi polillo un scaneado de errores y me a dado lo siguiente me gustaria que gente que entienda de vag com me interpretara los fallos.
Friday,14,October,2011,14:23:23:10074
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 6N - VW Polo
Scan: 01 02 03 08 15 17 19 25 41 45 46 55 56
Mileage: 167630km/104160miles
Address 17: Instruments Labels: 6N0-919-xxx-17.lbl
Part No: 6N0 919 861
Component: KOMBIINSTRUMENT MMO V07
Coding: 00111
Shop #: WSC 03187
VCID: F6E762EBF857
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 25: Immobilizer Labels: 6H0-953-257.lbl
Part No: 6H0 953 257
Component: IMMO VWZ3Z0V7034810 V64
Coding: 02400
Shop #: WSC 03159
VCID: EDD54D878D01
No fault code found.
Address 41: Diesel Pump Labels: 028-906-125.lbl
Part No: 028 906 125 B
Component: Saugdiesel FIA V01
VCID: 1321BB7F4BE5
3 Faults Found:
01168 - Idle Speed Boost Valve (N177)
31-10 - Open or Short to Ground - Intermittent
01050 - Glow Plug Monitoring
01204 - Engine Temperature Sensor (G27)
End ---------------------------------------------------------------------
Friday,14,October,2011,14:26:24:10074
VCDS Release 10.6.4: SRI Reset
Control Module Part Number: 6N0 919 861 Labels: 6N0-919-xxx-17.lbl
Component:KOMBIINSTRUMENT MMO V07, Coding:00111
Operation: Please select an operation
Channel Description Unit Current val. New val.
02 Service Reminder Status 3 ---
05 Maximum Distance to Oil Service (OEL) km x1000 15 ---
06 Maximum Distance to Inspection (IN1) km x1000 30 ---
07 Maximum Time to Inspection (IN2) Month 12 ---
10 Distance to Oil Service (OEL) km x100 0 ---
11 Distance to Inspection (IN1) km x100 0 ---
12 Time to Inspection (IN2) Days 0 ---
gracias de antemano
saludos.
codigos de error polo 6n 1.9d
3 mensajes
- Vistas: 946
soniatdi90 - Primeros Pasos
Re: codigos de error polo 6n 1.9d
nadie puede decirme nada? esque soy muy muy nuevo en esto jajajaja!
saludos.
saludos.
Mira esos fallos son intermitentes, seguramente cuando los borres y le pases otra vez el scaneo no te salgan, suelen memorizarse fallos. De todos modos yo tengo un archivo Pdf, que te vienen los fallos traducidos, asique si quieres pasame un privado con tu correo y te mando el archivo.
Un saludete
Un saludete
ledsandpower
3 mensajes
Tipos de Bombillas para Leon MK3 Style & Reference Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: TehKromen Respuestas: 43 |
Pedidos a fábrica. A la espera de nuestro nuevo León MK4!! Foro: General Autor: pca1414 Respuestas: 3476 |
sobre señales de trafico en Fis MK3 Foro: Informática / Interfaces / Diagnosis Autor: rojas Respuestas: 1085 |
León MK3 Actualización de mapas MIB2 SEAT/VW/Skoda Mayo 2022 Foro: AudioCar y MultimediaCar Autor: Warelio Respuestas: 62 |
Recopilación de Bricos Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: Juun Respuestas: 285 |
Usuarios navegando por este Foro: AhrefsBot, AmazonBot, Anthropic, Majestic-12 [Bot] y 2 invitados
