scan en mi seat leon.
Notapor juanan93 el 25 Ene 2012, 20:58
Buenas tardes foreros,os explico hoy me a llegado el vag 908 y lo e instalado y e echo mi primer scan... de momento a mas no llego jejeje el tema es que me a detectado estos fallos y no tengo ni idea que son.Si alguno entiende un poco mas que yo que con poco podra y me lo explica se lo agradezco un monton.
GRACIAS¡¡¡¡¡¡¡¡¡
VCDS Version: Release 908.0
Data version: 20090911
Wednesday,25,January,2012,18:17:08:13314
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ2R106674
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 034 DS
Component: MARELLI 4MV 4466
Coding: 00031
Shop #: WSC 06441
VSSZZZ1MZ2R106674 SEZ7Z0B1578247
2 Faults Found:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
17591 - Linear O2 Sensor; Reference Voltage: Short to Plus
P1183 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 00001 001 00001
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00040
Shop #: WSC 06441
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Coding: 12620
Shop #: WSC 06441
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: Redir Fail!
Part No: 1M0 920 802 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 04106
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: 3K Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 06441
Part No: 1C1959801A
Component: 3K Tõrsteuer.FS KLO 0004
Part No: 1C1959802A
Component: 3K Tõrsteuer.BF KLO 0004
Part No: 1C0959811A
Component: 3K Tõrsteuer.HL KLO 0004
Part No: 1C0959812A
Component: 3K Tõrsteuer.HR KLO 0004
3 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
01359 - Internal Central Locking Switch; Passenger Side (E198)
End ---------------------------------------------------------------------
juanan93
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 2 invitados
