Le pasado a un amiguete el vag-com y le han salido estos errores... son importantes ? el coche funciona perfectamente.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000005666927
Coding: 81880F2F00041000431D00000000000000017F071E40000C000000000000
Shop #: WSC 01742 444 12345
Part No: 1P0 955 119 B
Component: Wischer 070508 022 0601
Coding: 00056208
Shop #: WSC 01742
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 251
Mileage: 45506 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F00068F0F60084F86507C80
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 01742
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 20
Reset counter: 10
Time Indication: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
1 Fault Found:
01273 - Fresh Air Blower (V2)
003 - Mechanical Failure - Intermitten
Errores vag-com... Son Graves ??
11 mensajes
Archer - Asidu@ en la selva
- Agradecido: 5 veces
Re: Errores vag-com... Son Graves ??
Has hecho un borrado?
Son intermitentes no tienen importancia
Un V6 con tracción integral
hugofr - Mi Leon me tiene miedo
- Agradecido: 29 veces
muy buenas!!
eh comprado un cable vag com, 11.2 a nekora, y no tengo mucha idea aun, y encima estando en ingles menos... y he hechado un vistazo en post y no encuentro nada, y para ver si me hechais una mano o si alguno de vosotros lo tiene perfect. Como puedo conectary hacerun barrido para ver los posibles fallosque tenga el coche??? saludos y muchas gracias de antemano
ALEX_20vt
Conectar, con el encendido o motor arrancado, das al botón Auto Scan buscas en el listado el Leon 1M y das a Start
y es posible que no salga nada nada nada?? esque noto algunos tirones en alguna marcha y pense que me podia decir algo el vag... o presion del turbo como puedo mirarlo??
ALEX_20vt
Es posible que salga limpio el Scan pero si no lo haces no se sabe
Enviado desde iPhone, chúpate esa Android
abre un tema mejor en otro apartado que esto no es lo mismo...
Archer escribió:abre un tema mejor en otro apartado que esto no es lo mismo...
OK, mejor no desviar eltema, ya abrire un post, saludos y eso esta bien que este sano al 100% la fiera jejej
ALEX_20vt
Por favor no esbieis los temas y por otro lado tanto para el autor del hilo como Para alex 20vt usar el buscador antes de preguntar seguro que si esta encontráis respuesta rápidamente.
- Agradecido: 219 veces
@archer la consultando es mecánica por lo que debe ir en vag com, lo muevo.
ArkikomTdi escribió:@archer la consultando es mecánica por lo que debe ir en vag com, lo muevo.
gracias haber si hay suerte !!!
11 mensajes
El Vag Com no me reconoce las Labels del Modulo 1 Engine Foro: Informática / Interfaces / Diagnosis Autor: bigkin Respuestas: 11 |
Usuarios con VAG-COM / OBD Eleven y otros por provincia Foro: Informática / Interfaces / Diagnosis Autor: XoXe Respuestas: 787 |
Mis primeros errores de VagCom Foro: Informática / Interfaces / Diagnosis Autor: pabloafp Respuestas: 18 |
Vagcom errores ayuda porfavor Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: jorjito39 Respuestas: 0 |
activar y registrar Vag-com 409.1 Foro: Informática / Interfaces / Diagnosis Autor: fran_tobarra Respuestas: 78 |
