ayuda test
Seguidores: BhEaN
ayuda test
Notapor bananaramirez el 03 Feb 2013, 17:53
le he hecho un test a mi leon, me podiais ayudar con el resultado?
gracias.
VAG-COM Version: Release 311.2-N
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 HE
Component: 1,9l R4 EDC G700SG 4924
Coding: 00002
Shop #: WSC 06402
VSSZZZ1MZ4R121515 SEZ7Z0D2479076
No fault code found.
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001025
Shop #: WSC 00001
Address 08 -------------------------------------------------------
Controller: 1M0 820 043 E
Component: 1M-CLIMATRONIC X0702
Coding: 01028
Shop #: WSC 01800
Address 15 -------------------------------------------------------
Controller: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
Address 17 -------------------------------------------------------
Controller: 1M0 920 822 E
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 06102
Shop #: WSC 00000
VSSZZZ1MZ5R050057
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 E
Component: 99 Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 00000
3 Faults Found:
01331 - Door Control Module: Driver Side (J386)
37-00 - Faulty
00930 - Locking Module for Central Locking: Rear Left (F222)
27-10 - Implausible Signal - Intermittent
00931 - Locking Module for Central Locking: Rear Right (F223)
27-00 - Implausible Signal
End -------------------------------------------------------
bananaramirez
Re: ayuda test
Notapor Krixtian69 el 03 Feb 2013, 22:03
Te falla alguna cerradura del coche?
SEAT LEON 1.9 TDI 110cv SPORT
Para ver mi GALERIA --> http://www.clubseatleon.net/viewtopic.php?f=13&t=89645
Krixtian69
Agradecido: 105 veces
Re: ayuda test
Notapor bananaramirez el 04 Feb 2013, 13:40
Krixtian69 escribió:Te falla alguna cerradura del coche?
Si ka de detras izquierda a veces no abre, tengo que darle otra vez al mando para que abra
bananaramirez
Re: ayuda test
Notapor hanmatadoakenny el 04 Feb 2013, 21:19
has borrado los fallos y te han vuelto ha salir ? o no? lo digo por que pone que son intermitentes , igual te ha dado un dia el fallo y se ha quedado memorizado el fallo de las puertas :pensando:
hanmatadoakenny
Coche: Otro modelo no SEAT
Agradecido: 63 veces
Re: ayuda test
Notapor Krixtian69 el 04 Feb 2013, 23:07
Esque pone como que fallan las 2 cerraduras de atras..
Krixtian69
Re: ayuda test
Notapor kun34 el 30 May 2013, 20:19
a mi me pasa lo mismo, pero solo es la puerta de la izquierda. la solucion seria cambiar esa cerradura? o es problema de alguna centralita? nadie ha solucionado este problema?
kun34
Re: ayuda test
Notapor BhEaN el 31 May 2013, 12:06
@bananaramirez , muevo el post a [Informatica / Vagcom]...
Agradecido: 1580 veces
Re: ayuda test
Notapor TeteFR el 01 Jun 2013, 00:21
@bananaramirez , edita el título y ponlo más explícito como indican las normas por favor.
TeteFR
Agradecido: 245 veces
