que os parece este autoscan leon 2
Notapor pableras_16 el 10 Feb 2013, 21:37
pues esto lo e echo hoy y a lo ultimo e visto algo raro que entiendo algo de la puerta que os parece y el modulo 9 sin ningun fallo sale como si hubiese alguno un saludo
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Sunday,10,February,2013,20:49:06:37412
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb
Part No SW: 1P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH19--- Serial number:
Coding: 0303000C18070160
Shop #: WSC 06402 785 00200
VCID: 6BDFB6084A9EEF6
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 143B801209220000280E01EA901A0041350800
Shop #: WSC 04941 000 00000
VCID: 840D7DB4070080E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
Component: Climatronic H15 0702
Revision: 00001001
Coding: 0000000002
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_Climatronic A01006
ROD: EV_Climatronic_SE35.rod
VCID: 3D7B4850AC6AB16
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 H HW: 5K0 937 087 H
Component: BCM PQ35 H 011 0035
Revision: BE011001
Coding: 46180A3E902508C042080080950089C442559CA8627D8960008040000040
VCID: 3A71434CB54486E
Subsystem 1 - Part No: 1P0 955 119 C
Component: Wischer 08061 22 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5P0 919 475 C HW: 5P0 919 475 A
Component: PARKHILFE 8K H07 0005
Revision: -------- Serial number: 89041009603783
Coding: 100004
VCID: 3B7F4648BA7EBF6
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 H HW: 5N0 959 655 H
Component: J234__A0C VW10 HI 1916
Revision: 20013000 Serial number: 003E1P55KHMQ
Coding: 0012355
VCID: 42813BAC1D94CEE
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Component: LENKS.MODUL 009 0135
Revision: FF010036 Serial number: 20100611200695
Coding: 1082140002
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS_SE35.rod
VCID: 79F39C40F8C24D6
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D
Component: E221__MFL-TAP H02 0101
Coding: E20000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1P0 920 852 D HW: 1P0 920 852 D
Component: KOMBI H05 0404
Serial number: 00000000000000
Coding: 110E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 2F6762187606536
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 270510F2001111
Coding: E9A17F0640021200000202
VCID: EDDB3810F48A616
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0404
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
ROD: EV_Immo_UDS_VDD_RM09_SE35.rod
VCID: EAD1330C0D6476E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Component: SG EXT.PLAYER H13 0111
Revision: A1001003 Serial number: 7668126042
Coding: 010000
VCID: 27578A3856F60B6
Address 37: Navigation (J794) Labels: 3C0-035-270.clb
Part No SW: 5P0 035 191 D HW: 5P0 035 191 D
Component: RNS315 H03 0007
Serial number: SEZAZ2K9101004
Coding: 040004010402000000000000
ASAM Dataset: EV_RNS315SeatEUV1UDS A01005
ROD: EV_RNS315SeatEUV1UDS_SE35.rod
VCID: 2C5D7514471028E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
Component: TUER-SG FT 002 0311
Revision: 12101005 Serial number: 0000861060
Coding: 0010B0
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_SE35.rod
VCID: 7CFD8554F7F078E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S Labels: 3C0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004918610
Coding: 000090
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 142 3001
Revision: 00H17000
VCID: 31636460A832456
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
Component: TUER-SG BT 002 0311
Revision: 14101005 Serial number: 0000800610
Coding: 0010B0
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_SE35.rod
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S Labels: 3C0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004876932
Coding: 000090
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 2556933
VCID: 346D6D74572070E
Subsystem 1 - Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul l 0004
Coding: 00000039
Subsystem 2 - Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul r 0004
Coding: 00000039
Address 72: Door, Rear Right
Cannot be reached
End ---------------------------------------------------------------------
pableras_16
Coche: Leon MK2 2.0 FR 210cv
Re: que os parece este autoscan leon 2
Notapor andre_ru el 10 Feb 2013, 21:49
por lo que yo veo no tienes ningun error :S
andre_ru
Notapor pableras_16 el 10 Feb 2013, 22:18
lo que me mosquea es lo ultimo del modulo 72
pableras_16
Notapor andre_ru el 10 Feb 2013, 22:21
pableras_16 escribió:lo que me mosquea es lo ultimo del modulo 72
traducciendolo me dice esto Dirección 72: Puerta, Derecho De reverso no Puede ser alcanzado
andre_ru
Notapor Maximussurfr el 11 Mar 2013, 23:04
Saludos, mira yo tengo un Tiguan y un Leon, en el Tiguan me dice que las puertas están bien, y en mi Leon, sale lo mismo, la razón me parece que es por que en el tiguan cada una de las puertas ademas del botón o interruptor de los cristales/vidrios para subir y bajar, también lleva un interruptor para los seguros, el cual se ilumina cuando esta cerrado, y vía vagcom lo puedes desactivar para que siempre este en rojo, y no en amarillo, que es cuando se cierra, en el Leon, solo llevamos un botón o control de los seguros o cerraduras el cual va al centro del auto, cosa que me encanta. Entonces creo que no tiene nada que escanear o buscar en las puertas, claro es mi opinión y no estoy totalmente documentado, si alguien conoce mas, o me pude decir si estoy en un error se lo agradeceré y mucho.
Maximussurfr
Coche: Leon MK2 1.9 TDI 105cv
