El hilo de VAGCOM y opciones/mods para MK3
Seguidores: sarge, dsorribes, Elpuma7788, fonsi008, genialsoft, Mario1307, P.carrizo.leonstfr, trumangs, robereto, rikirpa, champinet, Miguelespino14, Besaygf, El3ndil, gogua, Pitufo_fr, crisFR, hectorcanu, Budoka, janfri, ixorreta, josele887, Jorge75016, jjimene89, cstrol, volkov, easyridergs, jmofcb, crcrodrigo, TeteFR, Dandy_gsi, Marc.22, Youkiler, iMonje, delko, dUeNdEr, Aegnorazo, marlop, pttzarzadilla, Platanot, berserk, Canary_280, La_jungla, davidbj, vigimuertos, Osky1983, chemacrown77, juanmaroger, sadanyac, Lionxp, coxmox, maxinew, nhaxo, Hecson.27, Valerofr150, Arcangel_89, edumachuca, daniel_44, JoseCa, kadettero, pablomus85, Mate, Albino, chuki_gcg, trekam, Ribers, FranGonzalez, Txutxiysilvia, César C., odelot, loeches, LeoST, jmfcoto, msmdraven, antelo85, kurbak, JPeraza, Diegokero, Robert_gti, chichopaco, Unaited, J.COSTA, jbaste, ertate, Javigt, Iosu21, Raul_22_, Daruma, kijute, LuichiFR, TITO CORUÑA, golf_1990, pitc3c14, lazandury_sur, iazofra, khris, Peje, Digon, car212121, Charly24Fr, Rasekfighter, aigort, Vasmurcia, Trivi83, Jeii90, MORKAS, Cantona, picard14, fbmxx, Zenobya, pirulo79, IRO, dookky, alonsodsg, carrasco13, Edu1589, elbirlo.dmm, bailyibz, Aluisdr26, aironsam14, franrx, Joseibz, elluna, hectordrums, chetelopez, llobet112, Kikote8, zenkun, Tomcat7733, djcastle, STFR, Sdocid, jninomo, albertpg, neraka, joke2joke, Miguelpfdez94, Kete32, chisyelamos, molvi_mabad, alejandro_javier, borgio, carlosgzlez, Frekiyo, manupuente92, garrafa2, papo-182, pipaxy, joelsm, morpheusgt, leonfrsaha, joscasaster, bronce702, Dconnect, Agobo, DBS83, Luko, Leon pucelano, davics07, naikon_paul, Juanquique, abollao, Hovig, teltronik, oldaqgonzalez04, ivanmonty, jasoriab, undernok, Mramos1985, braulioT, JoseDel, DiegoR, KoToRRo, Gsclosada, Tunnig, João Ramos, cristian_l.m, ilargiman, Gus_Fring, jluis, francisco.gamiz, sisma_eltrigo, VapaV, csabafr2013, guille771, cocorolito, artur.bp, sergi303, portela84, barret, Alba Morales, davidalba, JDCLEONFR, Luiggi7, dukaty, Maikermx, nitro_g4074, Senuto, yoflipo, damsolu, Mobi2004@gmail.com, josutdm, xexpir, cucci, Xabaco, fexposru, DJGrincho, chifli, MartinLeon, sgnwill, trazas, davidap13, ncx, Thor, ivanvidal, LordNelson, David_GT, vicius, javigomezserrano, josemag, iNFeCTeD, sistrax, manu5, galelir, Juanmidv, Chrohu, alex1, davidvilao, yurkli, carlo13, carloslmfr, lopezm0, jose.a.llamas, Gisbigas, Drovniak, diepecu2, JaquetónST, alrodri, ginyu 83, Ivanbustelo, Def89, Fisio, SantiPMI, Lata8, estudiante2003, talanito, wilsugar, perikolu, pedrorossello92, AlvaroRamlo, ebcuatro
Re: El hilo de VAGCOM y opciones/mods para MK3
Notapor cvillajos el 20 Mar 2016, 12:11
tevaadarelsol escribió:Buenas,
¿Alguien ha conseguido poner el modo carbono en la pantalla central en un MY16 con el navegador normal? Según el primer post hay que hacer esto:
1. 5F-Information Electr
2. Coding - 07
3. Seleccionar el Byte 17
4. Deseleccionar el Bit 0 y Seleccionar el Bit 1.
5. Salimos del programa y quitamos el cable.
Pero en mi caso ya vienen el bit 0 deseleccionado y el bit 1 seleccionado de serie, aunque no tengo el modo carbono.
¿A alguien mas le pasa?
@tevaadarelsol , a otro compi le pasaba lo mismo. Seguramente, al ser MY'16 con MIB gen2 los bits/bytes de las centralitas son distintos (igual que los adapmaps) y sin las labels oportunas no sepamos qué bits están involucrados.
Quizá alguien con un Golf VII y MIB gen2 que disfrute de las labels del 5f pueda echar una mano con las descripciones de los bits del LongCoding.
En este mensaje, cvillajos ha recibido un agradecimiento de:
tevaadarelsol (20 Mar 2016, 12:12)
cvillajos
Agradecido: 3572 veces
Notapor tevaadarelsol el 20 Mar 2016, 12:13
2. Coding - 07
Gracias @cvillajos, te debo ya un barril de cerveza
En este mensaje, tevaadarelsol ha recibido un agradecimiento de:
cvillajos (20 Mar 2016, 12:16)
tevaadarelsol
Agradecido: 199 veces
Notapor moucho el 20 Mar 2016, 12:26
Chicos gracias a vosotros llevo toda la mañana haciendo el capullo codificando cosas en el coche....
Pero no consigo quitar las diurnas me da fallo de out of range todo el rato......
Un saludo y gracias
Galiza terra de rallys
moucho
Coche: Leon MK1 1.6 16v 105cv
Agradecido: 9 veces
Notapor Danielo58 el 20 Mar 2016, 22:38
Buenas, ya he podido realizar los backups de varios modulos, a ver si veis algo, a simple vista parece que no hay practicamente modificaciones en el 5F, solo una opcion (67)-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
Hoy he activado lo siguiente sin fallos
-Plegado de espejos con un solo toque
- Cronometro en FIS
- Litros a repostar
- Aviso cambio de modo en FIS
- Mostrar velocidad de ventilador en AUTO
Y me da fallo
- 3 modos en ESP, he seleccionado el siguiente 09 Activo/ASR OFF/ESC Sport, al seleccionar cualquiera de las dos que no estan activados me da fallo en el FIS, me pone que no esta disponible el ACC y el Front assist, si te vas al FIS aparecen como activos, no he podido probarlo si funcionaban o no, ya que estuve haciendo los backups de los adpmaps y no me dio tiempo a probarlo
@cvillajos te dejo los enlaces de los viejos y los originales antes de hacer ninguna modificación. Solo he observado una gran diferencia en el A5 que el original tiene muchos menos valores.
ADPMAPS ORIGINALES
https://drive.google.com/folderview?id= ... sp=sharing
ADPMAPS MODIFICADOS CON ERROR
De momento no me atrevo a tocar lo del reconocimiento de las señales de trafico.
Danielo58
Agradecido: 23 veces
Notapor javigody el 20 Mar 2016, 22:45
Danielo58 escribió:Buenas, ya he podido realizar los backups de varios modulos, a ver si veis algo, a simple vista parece que no hay practicamente modificaciones en el 5F, solo una opcion (67)-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
- Cronometro en FIS
- Litros a repostar
Y me da fallo
ADPMAPS ORIGINALES
El reconocimiento de señales puedes activarlo sin tocar la 5f y funciona. En el post "sobre señales en el fis" ves como lo tengo.
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Notapor Danielo58 el 20 Mar 2016, 23:10
- Cronometro en FIS
- Litros a repostar
Y me da fallo
ADPMAPS ORIGINALES
@javigody Ya lo hice y me desaparecio el ESP y otras opciones, en los de MY2016 esta dando problemas, por eso no lo he activado de momento.
Danielo58
Notapor aironsam14 el 20 Mar 2016, 23:37
Hola una duda si activo con el vagcom el Seat driver profile.
Que se supone que cambia? Que tengo 3 mapas de conducción?
Algo más??
aironsam14
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 24 veces
Notapor javigody el 21 Mar 2016, 01:12
- Cronometro en FIS
- Litros a repostar
Y me da fallo
ADPMAPS ORIGINALES
El mio es un MY16 también, y se puede sin problemas. Sin tocar nada del modulo 5F y sin perder esos menús
javigody
Notapor arlot el 21 Mar 2016, 09:30
2. Coding - 07
@tevaadarelsol Los pasos son los correctos, pero te falta uno:
REINICIAR EL EASY CONNECT (mantener apretado el boton de encendido de la radio durante 10 segs, hasta que se oiga un Plof)
arlot
Agradecido: 975 veces
Notapor tevaadarelsol el 21 Mar 2016, 09:33
2. Coding - 07
@arlot también lo probé y nada, incluso reiniciando los ajustes de fábrica del easy. Lo raro es eso, que mi easy ya viene con esos bits así, si tuviésemos las malditas labels del 5F...
tevaadarelsol
Notapor arlot el 21 Mar 2016, 09:46
Entonces, siento no poderte ayudar más :(
En este mensaje, arlot ha recibido un agradecimiento de:
tevaadarelsol (21 Mar 2016, 10:15)
arlot
Notapor tevaadarelsol el 21 Mar 2016, 10:46
arlot escribió:Entonces, siento no poderte ayudar más :(
No te preocupes @arlot, gracias de todas formas :ok:
tevaadarelsol
Notapor Danielo58 el 21 Mar 2016, 18:42
- Cronometro en FIS
- Litros a repostar
Y me da fallo
ADPMAPS ORIGINALES
@javigody y que has tocado para no perder esos menús? Y activarlo???
Por cierto hoy he probado los 3 modos, al poner el del ESC SPORT se desactivan el acc y front assist para que puedas hacer el cabra y no te frene, lo del ASR OFF lo he probado y sigue saltando, así que de OFF nada de nada....
Danielo58
Notapor javigody el 21 Mar 2016, 19:37
@Danielo58
javigody escribió:
Confirmo que sin activar ninguna de estas opciones
(63) vehículo BAP traffic_sign_recognition_0x21, (justo al intentar activar esta me desapareció el ESP)
(151) Menú vehículo menu_display_road_sign_identification,
(153) menú de operación-menu_display_road_sign_identification_over_threshold_high
El reconocimiento de señales funciona. Además no se pierde ningún menú de la pantalla. Para muestra...
javigody
Notapor Danielo58 el 21 Mar 2016, 21:35
@javigody vamos que activas todo lo del módulo A5 pero nada del 5F no? El finde lo pruebo. Qué envidia del FIS a color!!
Danielo58
Usuarios navegando por este Foro: No hay usuarios registrados visitando el Foro y 8 invitados
