León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor IvanMc2 el 16 Ago 2015, 02:08
RuJe escribió:
IvanMc2 escribió:
RuJe escribió:@IvanMc2 comprobado! Ayer fui al garaje y conecté el positivo del maletero y a la masa del tornillo y... ahí la tengo funcionando. Eso sí (antes de cambiar los cables también me pasaba), ¿se os ha quedado alguna vez negra) es decir, alguna que otra vez se me queda la imagen negra pero se intuyen las líneas "de aparcamiento" aunque no se ven con claridad.
Me imagino que será cuestión de ponerle el dichoso condensador, no?
Puede ser, a mi no me paso, pero yo tenia el condensador desde el principio, busca uno de 2200uf y (16v como minimo) y donde emplames los cables de corriente de la camara pon hay el condensador, una patilla va al + y la otra al -, ten cuidado que tiene polaridad, mira el pinout en google y suerte
Me he ido a auto - contestar esta tarde, pero al final se me ha ido la pinza. Parece estar solucionado. Era la masa del RCA de video, que no hacía bien contacto.
Por cierto, como masa de la alimentación de la cámara también vale el tornillo que va en el guarnecido de plástico del maletero
Si toca cualquier masa metalica del chasis si
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2
Agradecido: 129 veces
Notapor RuJe el 16 Ago 2015, 02:52
Si, por eso lo decía. Era una afirmación. Probé y funcionaba, así que lo dejé ahí (me gusta más ahí, queda más recogido que con el cable tirado hasta el cierre).
RuJe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 27 veces
Notapor juanba el 17 Ago 2015, 10:55
A los que ya hicisteis el bricom.como desencajasteis la goma del porton?? Por donde pasan los cables?? Esta durisimo y no hay manera.
juanba
Agradecido: 54 veces
Notapor IvanMc2 el 17 Ago 2015, 19:58
juanba escribió:A los que ya hicisteis el bricom.como desencajasteis la goma del porton?? Por donde pasan los cables?? Esta durisimo y no hay manera.
Yo no quite el paragolpes, utilize uno de los pasamuros de detras del plastico
IvanMc2
Notapor RuJe el 17 Ago 2015, 20:03
No, creo que se refiere al pasacables que va desde la parte trasera del techo hacia el maletero, para coger la toma de la luz de marcha atrás (si no me equivoco).
RuJe
Notapor IvanMc2 el 17 Ago 2015, 21:14
Empujas hacia fuera y haces un poquito de palanca con un plano, cuidado que parte el enganche, de todas formas esta explicado en brico @juanba
IvanMc2
Notapor juanba el 17 Ago 2015, 22:26
Ya consegui quitarlo.gracias.otro problema me viene ahora.al.quitar el teton de goma, por detras hay como una esponja dura y no tengo manera de quitarla.meto la guia por un huequito que hice pero se me va para el lado contrario al plafon de la matricula.
juanba
Notapor RuJe el 17 Ago 2015, 22:52
Yo lo hice a la contra. Pasé desde el plafón de la luz de matrícula hacia abajo (ayudándome quitando la tapa por el hueco del gancho para remolcar) y una vez ahí , tiré hacia arriba. He de decir que yo no lo hice por ese te tonillo que pone @rojas en el tito, si no que utilicé el mismo pasamuros que usan para pasar la luz de matrícula desde el interior al exterior. Ese pasamuros es más grande y caben video y alimentación por el mismo
RuJe
Notapor IvanMc2 el 19 Ago 2015, 00:03
Tambien hay un pasamuros en el fondo del maletero que da justo encima del deposito y hay hacia abajo y hacia arriba como hizo @ruje
IvanMc2
Notapor juanba el 19 Ago 2015, 14:49
Camara instalada y funcinando.lo unico el condnsador que utilice.que es de 4600uf y se ve alguna linea en la pantalla.por lo demas muchisimas gracias a @rojas y a todos los que habeis comentado por aqui.
juanba
Notapor MORKAS el 19 Ago 2015, 17:07
juanba escribió:Camara instalada y funcinando.lo unico el condnsador que utilice.que es de 4600uf y se ve alguna linea en la pantalla.por lo demas muchisimas gracias a @rojas y a todos los que habeis comentado por aqui.
A ver si el proximo soy yo..jejejej
MORKAS
Agradecido: 369 veces
Notapor rabazas el 19 Ago 2015, 17:14
Podéis pasar enlace de la cámara ? No se si poner la de plafón o la normal
rabazas
Coche: Leon MK2 2.0 Cupra 240cv
Agradecido: 40 veces
Notapor IvanMc2 el 20 Ago 2015, 09:27
Todos tenemos condensador asiq empiezo a pensar que lo de las lineas es por los metros de cable, que seran muchos para la poca potencia que tenga la camara
IvanMc2
Notapor tokedj1989 el 20 Ago 2015, 16:07
A mi no me salen lineas desde que puse el portafusibles ese en donde el mechero. Eso si mi camara es la mierda q se ve en blanco y negro por lo demas bien jajajaja
tokedj1989
Coche: Leon MK3 1.2 TSI 105cv
Agradecido: 25 veces
Notapor Rasekfighter el 20 Ago 2015, 16:15
Al final nadie sabe si se puede instalar en la de 5"?
Rasekfighter
Agradecido: 64 veces
