León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor RuJe el 20 Ago 2015, 16:37
IvanMc2 escribió:
juanba escribió:Camara instalada y funcinando.lo unico el condnsador que utilice.que es de 4600uf y se ve alguna linea en la pantalla.por lo demas muchisimas gracias a @rojas y a todos los que habeis comentado por aqui.
Todos tenemos condensador asiq empiezo a pensar que lo de las lineas es por los metros de cable, que seran muchos para la poca potencia que tenga la camara
Yo no tengo condensador y no me salen líneas... eso si, yo tengo positivo de la luz de maletero y masa del tornillo del guarnecido del maletero... no debería influir, pero a mi se me ve bien!
RuJe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 27 veces
Notapor IvanMc2 el 21 Ago 2015, 06:16
Con que camara?
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2
Agradecido: 129 veces
Notapor IvanMc2 el 21 Ago 2015, 07:02
Con que camara?
IvanMc2
Notapor marlop el 21 Ago 2015, 11:16
RuJe escribió:Yo no tengo condensador y no me salen líneas... eso si, yo tengo positivo de la luz de maletero y masa del tornillo del guarnecido del maletero... no debería influir, pero a mi se me ve bien!
@Ruje, ¿cómo solucionaste el problema que tenías con la luz del maletero? Según he leído, dicha luz tampoco lleva 12v puro, de ahí el problema que tenías antes.
RuJe escribió:con la luz de marcha atrás (llevo LED y codificado para que ilumine más y no de fallo) y con la luz de maletero, no he sido capaz de hacerla funcionar.
marlop
Agradecido: 1080 veces
Notapor RuJe el 21 Ago 2015, 11:22
Con que camara?
Esta es mi cámara. De Dealxtreme china hay la misma, pero más barata. Pero exactamente esa es la que yo tengo.
http://eud.dx.com/product/eagleyes-ec-t ... dbtWBAaHqA
RuJe
Notapor RuJe el 21 Ago 2015, 11:28
@marlop
Pues como pongo anteriormente, positivo a luz de maletero y masa al tornillo que va en el guarnecido de plástico del maletero. Al principio lo puse como me dijo el compañero @IvanMc2 en el tornillo del cierre del maletero. Pero no me hacía mucha gracia tener los cables tan desperdigados (uno en la luz del maletero y la otra en el cierro del porton), así que decidí probar suerte a ver si ese tornillo atornillada en chapa o en plástico y efectivamente, va en chapa, así que me valía como masa. Si la luz de maletero es 12v puros o no, no lo se, la cuestión es que sin condensador y conectado tal como je explicado, me funciona bien. Eso sí, la cámara siempre que tengo el contacto dado permanece encendida, pero por el precio que tiene he pedido otra y si se fastidia pues la cambio por otra igual.
RuJe
Notapor juanba el 21 Ago 2015, 11:54
Esta es mi camara.es que no son lineas.es como si la imagen de la pantalla temblase un poco.http://es.aliexpress.com/store/product/ ... 48174.html
juanba
Agradecido: 54 veces
Notapor RuJe el 21 Ago 2015, 12:43
Pues... o es por el condensador o que señal de video no está llegando correctamente, es decir, o la masa no hace totalmente contacto (la del video) o la señal del vivo no llega correctamente
RuJe
Notapor marlop el 21 Ago 2015, 12:57
Gracias, @RuJe . Cada uno a su manera jeje.
marlop
Notapor tiklap el 21 Ago 2015, 16:47
Me uno a este brico,
tiklap
Agradecido: 17 veces
Notapor IvanMc2 el 21 Ago 2015, 21:06
RuJe escribió:Pues... o es por el condensador o que señal de video no está llegando correctamente, es decir, o la masa no hace totalmente contacto (la del video) o la señal del vivo no llega correctamente
Yo creo que es del rca por que la masa mia la tengo del piloto trasero
IvanMc2
Notapor Unaited el 21 Ago 2015, 21:40
Vuelvo a este tema con una duda que no se si me contestasteis anteriormente, si no tenemos centralita, se puede poner la camara?
SEAT LEON MK3 ITECH 1.6 TDI CR 105cv ==> viewtopic.php?t=109489
Unaited
Agradecido: 104 veces
Notapor Rasekfighter el 21 Ago 2015, 22:45
Unaited escribió:Vuelvo a este tema con una duda que no se si me contestasteis anteriormente, si no tenemos centralita, se puede poner la camara?
Insisto yo también... Los que tenemos la.de 5"? Más que nada es que no sabría donde comprobarlo o como probarlo,..
Rasekfighter
Agradecido: 64 veces
Notapor RuJe el 21 Ago 2015, 23:29
No se a que centralita te refieres, pero yo no tengo sensores de aparcamiento y tengo la cámara
RuJe
Notapor Vitydogo el 22 Ago 2015, 10:18
+1 Me uno
Vitydogo
