León Mk3 - BRICO - Como instalar la cámara de parking
- Seguidores: 136
- Favoritos: 46
- Vistas: 595.741
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Yo tengo la camara, pero la verdad es que se me estan quitando las ganas de hacerlo, demasiado treje maneje de cables
Vamoooooooooooooos
arlot - Gurú de los leones
- Agradecido: 977 veces
arlot escribió:Yo tengo la camara, pero la verdad es que se me estan quitando las ganas de hacerlo, demasiado treje maneje de cables
Haz como yo, por fases. Como aun no tengo los pins ni las herramientas he instalado la cámara ya como luz de matricula y funcionando. Cuando tenga un momento le daré corriente a la cámara y Cuando tenga los pins pondré el cable en la guantera y pasare el cable.
genialsoft - Leoner@ mayor del reino
- Agradecido: 346 veces
@arlot tu trankilo que te doy asistencia tecnica !!
esta chupao camarada !
si te gusta ... agradece el post !!
rojas - Gurú de los leones
- Agradecido: 1887 veces
@rojas sabrias si en el mk2 restyling se haria igual o si seria parecido? Un saludo
Nanox23 - Aun con la L
- Agradecido: 8 veces
Nanox23 escribió:@rojas sabrias si en el mk2 restyling se haria igual o si seria parecido? Un saludo
Exactamente igual
rojas escribió:Nanox23 escribió:@rojas sabrias si en el mk2 restyling se haria igual o si seria parecido? Un saludo
Exactamente igual
De acuerdo gracias.
Buenas....
Bueno, yo ya he comprado los faston del quadlock y las llaves de extracción del modulo de sonido, solo me queda decidirme por la cámara que quiero instalar, aunque queda perfectamente integrada en coche la que estáis comprando a mi no me termina de convencer por el tipo de iluminación que lleva y estoy viendo la opción de integrar yo una cámara en el plafón led original conservando así la instalación y los conectores originales del vehículo en el plafón, os lo explico mejor con una foto.
la idea de camara que tengo seria algo así
http://www.ebay.es/itm/Camara-aparcamiento-trasera-marcha-atras-para-coche-impermeable-CMOS-170/371075778919?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140620091323%26meid%3D7208b68f1e1b4e748c7f50ea6675f923%26pid%3D100005%26prg%3D20140620091323%26rk%3D2%26rkt%3D6%26mehot%3Dag%26sd%3D281177516715&rt=nc
Esta tendría que cortar la rosca puesto que por el otro lado del plafón tengo el conector casi pegado.
y lo haria con el plafón derecho puesto que los plafones no son simétricos y con el derecho la cámara queda mas centrada.
Creo que ahora me entendeis mejor.
Por otro lado esta el tema del cableado, si al final tomo corriente de la luz de marcha atrás intentare tomarla del conector del plafón intentando pasarlos cables por el fuelle y todo el portón hasta el piloto (con paciencia así será) no me fío mucho de tomar la corriente de la parte del fuelle.
Referente al cable de señal mi idea es pasar el cable tal y como dice rojas pero yo tirare el cable desde el quadlock hasta el maletero/parachoques y allí pondré un rca hembra para conectar directamente con la cámara y poder desconectar desde el hueco del plafón junto con el conector de iluminación y otro conector que pondré para la alimentación.
Esta seria una muy buena opción para instalar justo en el centro, entre los dos plafones, me olvidaría de hacer la adaptación de la cámara en el plafón , pero tengo que hacer un buen taladro
http://www.ebay.es/itm/Mini-camara-marcha-atras-estacionamiento-parking-vision-nocturna-Coche-SEGURO-/390788866033?pt=LH_DefaultDomain_186&hash=item5afcd4dff1
Si pudiera cortar la parte que va embutida seria la perfecta para el plafón (quizás sea cuestión que arriesgar unos 15€ y meterle la dremel o una hoja de sierra con mucho cariño
Si me hecha un poco para atrás el tema de la garantía, pero si quiero hacerlo de tal manera que pueda desmontar en un momento y poniendo un plafón nuevo sin la cámara (28€ plafón led original que compraría) de tal manera que los de la seat no lo vean a no ser que tengan que desmontar parachoques o desmontar el equipo de sonido (esto ultimo si se hace bien tampoco se darán cuenta del cable añadido al conector quadlock).
A ver arlot, llegado a este punto no te eches atrás, sabes que tienes la ayuda de los foreros.
La instalacion no es para nada complicada ni la parte mecanica ni la eléctrica, pero si tienes que tener todo bien claro antes de ponerte al lio, coge papel y lápiz y hazte tu propio esquema de conexionado frente al ordenador con el tutorial de @rojas y la modificación posterior con el rele, bajate al coche y dale unas cuantas vueltas y piensa por donde atacar primero y como bien dice @genialsoft y haría Jack el destripador ve por partes y sin prisas, si tienes todos los componentes lo puedes hacer en una mañana tranquilamente.
Suerte
Suerte
Viajar no es desplazarse, es sentir el camino
Maestro - Leoner@ habitual
- Agradecido: 25 veces
No me entero de todo lo que hace falta. Tengo un Seat Leon ST
Cámara trasera (recomendáis alguna?)
Cable RCA
Llaves de extracción modulo sonido
Cocodrilo?
Respecto a la configuración, ¿podéis explicarlo como si fuera para niños de 3 años?
Gracias y disculpad.
Cable RCA
Cocodrilo?
Seat Leon ST 184CV FR
halfy - Asidu@ en la selva
Ya tengo los pines, el canle rca y las llaves extractoras
No se que leches hice q me han llegado 8 llaves estractoras del easy...... Creo q pedio 2 unidades
Me falta lo de los fusibles, la camaras y los cocodrilos
Ami no me disgusta hacer un agujero en medio del parachokes
Como iria conectada como la que pone el compi rojas?
Sino me convence cuando este puesta compro la que ha puesto el otro compañero del taladro en medio del parachoques
- Agradecido: 35 veces
[quote="frestor"
[/quote]
si , exactamente igual ... lleva las mismas conexiones menos la del led , ya que esta no lo lleva , solo el rca y alimentacion de camara
[/quote]
Buenas...
Pues ya me llegaron los terminales del quadlock (no lo esperaba tan pronto), ahora falta por llegar las llaves extractoras y la cámara, al final me he decidido por estahttp://www.dx.com/es/p/eagleyes-ec-th1009-1-4-ccd-170-wide-angle-car-rearview-camera-w-night-vision-black-dc-12v-195193#.VJcfoDJAK0 aunque no quiere decir que sea la final, primero haré las pruebas de ubicación (no quiero taladrar en principio el parachoques), creo que soy capaz de alojarla en el plafón derecho de la matricula haciendo unas modificaciones al mismo, ya os contare.
Por cierto en el siguiente enlace instalan la cámara de marcha atrás del Scirocco a un Leon mk3 http://www.leon-concept.com/forum/viewtopic.php?f=175&t=91347&hilit=camera+de+recul&start=60 con todo el cableado original, la instalación se la ha currado y queda muy bien, ahora, eso si, el tio no desmonta mas el coche porque no puede, eso, mas el precio de los recambios originales que le sale por un buen pico mas las horas que hay que echarle a la instalación yo sigo con el tutorial de rojas, aunque no esta mal verlo para tomar alguna idea.
Que tal va esa cámara @rojas después de usarla durante unos días?, contento?, la cámara que le pusistes va bien?
Maestro escribió:Buenas...
hola , va genial !! , estoy muy contento , aqunque ya sabia como iba ya que es la misma que he usado en otros coches .
No hace falta hacer nada con el vagcom ni nada de eso? solo instalar la camara y se ve?
er_pinto - Nuev@ por aqui
er_pinto escribió:No hace falta hacer nada con el vagcom ni nada de eso? solo instalar la camara y se ve?
hay que codificar
Quien se apunta a montar la camara este sabado despues de comer?
Tengo todo menos los dos pines mini quadlock. Alguien que vaya el sabado tiene?
Hecson.27 - Nuev@ por aqui
OBDeleven - Dudas y Mods para León MK4 Foro: Informática / Interfaces / Diagnosis Autor: miceor Respuestas: 679 |
Encuesta - Que tipo de Gasoil utilizais Foro: General Autor: pirly Respuestas: 259 |
Verdad sobre problemas Seat león Mk4 Foro: General Autor: 130sport Respuestas: 6 |
mods obd virtual cockpit MK3 Foro: Informática / Interfaces / Diagnosis Autor: cuenxis Respuestas: 501 |
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 2 invitados
