León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor Tomy61 el 14 Ene 2017, 19:32
Os hago una consulta porque me estoy volviendo loco con el tema. desde hace 15 dias o asi tanto usando un a3 como usando un xperia z1 me desconecta constantemente del coche ,mas con el xperia el cual es casi imposible, con el a3 me dura igual 1 hora que 2 minutos, puede ser por que hay que actualizar???. como ya puse el darle a menu unos segundos me sugiere que actualice a la misma version que tengo pero con -2. si es por la acutualizacion puedo meter directamente la 330 y luego la 346 o espero a ver que es eso de ....-2?
si a alguno os ha pasado agradecezco que mme digais que hicisteis.
un saludo y gracias a todos por las ayudas que nos dais
Tomy61
Agradecido: 15 veces
Notapor BhEaN el 15 Ene 2017, 00:17
Buenas!
Por favor, @fermr , no hace falta citar todo el post enorme para hacer una pregunta tan concreta... al final se hace muy incómodo leer los posts si hay citas de otros posts tan grandes
:ok:
Gracias!
Agradecido: 1581 veces
Notapor CarlosTSi el 15 Ene 2017, 11:40
Yo no tengo ni vagcom ni obdeleven, puedo actualizarlo sin que haya fallos, tendré algún problema?
Cupra R 300 DSG
CarlosTSi
Agradecido: 938 veces
Notapor Valerofr150 el 15 Ene 2017, 11:44
CarlosTSi escribió:Yo no tengo ni vagcom ni obdeleven, puedo actualizarlo sin que haya fallos, tendré algún problema?
Poder puedes, pero necesitas vagcom o obdeleven para activar el codigo de la pantalla
Valerofr150
Notapor CarlosTSi el 15 Ene 2017, 11:48
Entonces me quedo con las ganas @Valerofr150 .....
Cupra R 300 DSG
CarlosTSi
Notapor cvillajos el 15 Ene 2017, 12:21
Lo que no sé es cómo no te has comprado una interfaz OBD II ya @CarlosTSi
cvillajos
Agradecido: 3613 veces
Notapor CarlosTSi el 15 Ene 2017, 13:24
Por que no puedo aun @cvillajos
Enviado desde mi SM-A510F mediante Tapatalk
Cupra R 300 DSG
CarlosTSi
Notapor lafu1988 el 15 Ene 2017, 14:42
Pero puedes actualizar, yo actualicé y todo perfecto sin tener ninguno de los dos dispositivos, no sale ningún error en el infotaiment y es 100% funcional. Cuando el compré el obdeleven y lo conecté si me salió el error 1555 pero se solventa en 1 min.
Yo si actualizaría en tu caso.
Eso también es verdad... no se como no lo tienes es un indispensable post compra jejejeje
lafu1988
Agradecido: 218 veces
Notapor CarlosTSi el 15 Ene 2017, 22:30
@lafu1988 sí yo quito tener el vagcom original (paso de piratas) y poder hacer cosas :mrgreen:
Cupra R 300 DSG
CarlosTSi
Notapor cvillajos el 16 Ene 2017, 07:06
El OBDeleven PRO lo tienes por 55€.
cvillajos
Notapor miyobe el 16 Ene 2017, 08:13
El error 1555 no sale en Fis ni vehículo, solo al conectar OBDELEVEN (imprescindible) o Vagcom y escanear. Así que puedes actualizar como dice @Lafu1988.
Enviado desde mi Redmi 3 mediante Tapatalk
miyobe
Agradecido: 31 veces
Notapor CarlosTSi el 16 Ene 2017, 10:21
Ya y un vagcom pirata por 40€ @cvillajos , aunque prefiero el OBDeleven por ser original al vagcom pirata
Cupra R 300 DSG
CarlosTSi
Notapor stewei el 16 Ene 2017, 12:34
@CarlosTSi 40€ un vagcom pirata? pos si que los compras caros....... los hay por 20€ en ali ehh.....
Yo desde que utilizo el OBDEleven me he olvidado del vagcom....
Un saludo :ok:
P.D: Perdón por el offtopic......
stewei
Agradecido: 465 veces
Notapor CarlosTSi el 16 Ene 2017, 13:33
stewei escribió:@CarlosTSi 40€ un vagcom pirata? pos si que los compras caros....... los hay por 20€ en ali ehh.....
Un saludo :ok:
Es un decir @stewei
Cupra R 300 DSG
CarlosTSi
Notapor ATA-RACING el 17 Ene 2017, 17:53
Un saludo :ok:
Es un decir @stewei
@CarlosTSi mira yo compre el 12.12.0 y me lo tengo que comer con papas,prefiero el obdeleven que llevo tiempo siguiendo el hilo a @miceor @cvillajos y ect y viendo los videos de youtube,con la funcionalidad de obdeleven y te aseguro que es,lo primero mas comodo,puedes cargar el movil mientras lo utilizas,el portatil es un engorro total y como tengas jodida la bateria como es mi caso,apañao voy,hoy mismo pido el obdeleven desde la pajina web y antes de utilizar,con el post en la mente,para no meter el pescuezo,cuando lo tenga actualizare el infotaiment y borrare el error 1555 hasta que no lo tenga en mi poder,nada de complicarme con el vcds 12.12.lo que sea.
te dejo una fotillo por que la aplicacion ya me la descargado e incluso ya me registrado y le colocao una foto de mi leoncete para ir abriendo boca se que el vim se piuede desbloquear con los creditos diarios 100 cuesta no es mala idea.
SEAT LEON FR-1.4-TSI-ACT 150CV 5 PUERTAS :rey:
si te gusta conducir,conduce un seat leon mk3 A-TUMBA-ABIERTA. :comediante: :cuñao:
ATA-RACING
Agradecido: 375 veces
Usuarios navegando por este Foro: Anthropic, Twinwaves y 5 invitados
