León Mk3 - BRICO - Como reequipar "Seat Sound System"
Favoritos: JupiJ79, saxisaac, rojas, dani90, xaacra, francesito, abelsfc, jelajasb, Carrl, itsAdriaan96, ertate, J-Frass, Jester, lokitovs, bronce702, OGT, tsi125, Alleya, maki26, ZXVolcane, jj_leon, espix, Martin VO
Seguidores: JOTTA, Rasekfighter, Josito3, sghezz, daniel_44, danieleon, leonfrrojito, LeoST, Dandy_gsi, pirly, davidbj, genialsoft, saxisaac, the-game-310, er_trompe, Jorge75016, Marc.22, Albino, crcrodrigo, xabidh, Abraham Morin, ivansf16, ivan0909, ruben88, iazofra, Stonemaker, Edu82, ocsido, arracho, davindu3, erizo-man, jande, aigort, Dconnect, osjamil, el_padrino, clarens, fermr, Vilo, Zarkis, MORKAS, Juanlu23, LuichiFR, Miguelpfdez94, Manu1986, aguscalderon, djcastle, yoflipo, Illan, tsi125, juanmik, VapaV, jose.jjg307, teltronik, jd_zuri, carrasco13, bronce702, Espartan23, conquepoquico, Senuto, victor david, Edu1589, freepassion, Maikermx, Brandenor, fxtra, fun_olivier, Rekoba, Chrohu, gymnos, JDMG, josermancol
Re: BRICO-Como Instalar el "Seat sound system " a posteriori
Notapor jasoriab el 29 Mar 2019, 13:22
Hola @TygerBeast
Ya hay un hilo abierto, acerca de los distintos cables a comprar, te remito a él a ver si algún compañero ha comprado alguno de lo que indicas:
viewtopic.php?f=8&t=118521
Este no es el hilo para tratar sobre compra de cables.
jasoriab
Agradecido: 2055 veces
Notapor fifi49 el 24 May 2019, 18:45
Hello,
I have replaced my MIB2 mirror link (with seat sound system) with an MIb2 full link. Everthing is almost ok (the seller code it for my car)
But with my new mib, i lost the settings of sound system (i think the seller forget this setting).
Is it difficult to add i and code it?
The seller have told me about VAs5054, VCP. I don't know what doing
Thanks
fifi49
Notapor Dav2k6 el 04 Jun 2019, 23:43
una pregunta.... a la hora de conectar el central?¿ tiene polaridad?
El pin 14 es positivo y 10 negativo igual para el sub?
Seat leon ST FR 150cv
Dav2k6
Notapor kikemon el 03 Sep 2019, 23:08
joracahi escribió:
marcos210492 escribió:Lo necesario para que este brico cobre sentido es que podamos activar el sistema con la codificación...
Alguien que colabore y nos ayude de forma desinteresada a cargar el ZDC, para activar el subwoofer en nuestro leon?
Muchas gracias a tod@s.
Hola, he estado investigando y mucho. Soy de México por cierto. Y me gustaría compartir puntos claves imprescindibles para este BRICO.
AL hacer el brico tu subwoofer emitira Sonido pero en todas las frecuencias, vaya como un altavoz, al hacer la codificacion la centralita solo mandara frecuencias bajas hacia el subwoofer cumpliendo asi su correcto funcionamiento, vaya lo que hace un crossover.
- Es obligatorio el uso del VCP "Vag Can Pro" - NO se puede por OBDEleven u otro modificador de central.
- El VCP cuesta oficialmente alrededor de 250 euros o 300 dolares + Envio.
- El VCP "Generico" aunque me pudo hacer conectar a mi central (mi auto es año 2018 FR) NO trae los ZDC actualizados, estos se descargan a través de su software.
- Parece ser, que modelos 2015 para atras si trae esos ZDC en el genérico pero no podría confirmar esto, aunque recuerdo haber visto varias carpetas con varios ZDC inclusive de VW.
- En la agencia la primera vez que fui me "codificaron" y lo unico que hicieron fue que apareciera en pantalla el subwoofer sin embargo lo hicieron a traves de VCDS, no conocen el VCP aca en Mexico.
- No he hecho pruebas y si alguien pudiera pasar un archivo ZDC y cargarlo con el "generico".
- Tambien otra opcion seria enviar la centralita a alguien que pudiera codificarlo y recibirla de regreso actualizada y solo enchufarla, seria quiza mas barato que comprar el VCP.
Recomendaciones: Buscar alguien que te haga la codificación, la inversion por el VCP se me hace demasiado para solo codificarlo, con ese dinero y un poco mas puedes meter un mejor sistema de audio si necesidad de codificar nada, cambiando altavoces, un amplificador, crossover incluso un DSP.
Hola
El mio es FR 2015 pantalla 5.6 MIB1, me van a pasar el sub para instalarlo
Aun no veo los pines de la guantera
Tienes el VCP que puedas configurarlo para que aparezca el menu del sub!?
Saludos compañero, soy de Guadalajara Mexico
kikemon
Coche: Leon MK3 1.4 TSI 122cv
Notapor Trosk el 10 Oct 2019, 03:55
Hace tiempo aztualice el infortaiment para poner la pantalla de 8, pero desde ese momento me desapareció el ajuste de la pantalla del subwoofer.
Sigue sonando pero no lo puedo regular.
También me da la impresión del q el seat sound system no está activado porque ahora noto q los tweters distorsionan porque intentan sonar como un altavoz normal.
Lo mejor es que fui al concesionario se lo explique y me dijeron que me lo activan sin problema, pero cuando volvo a por el coche me dijeron que no podían hacer nada porque su programa les decía que esa versión de infortaiment era de otro modelo de coche y daba error
Alguien sabe algo?
:zoquete: :zoquete:
Trosk
Notapor BADS el 10 Oct 2019, 22:40
Si, en el concesionario no pueden hacer nada. la unica alternativa es configurar con VCP.
BADS
Agradecido: 17 veces
Notapor Pippoleon el 05 Nov 2019, 13:18
el_padrino escribió:Buenas noches,
En primer lugar, quisiera felicitar a Rojas por su gran labor didáctica para con el foro. Con gente como tú da gusto :)
No me hago responsable de las consecuencias de lo a continuación detallado.
Asi mismo me gustaría añadir una parte que creo que falta al post que es la que concierne a la codificación VCP. Paso a detallaros.
CODIFICACIÓN VCP
1º Dentro del menú Additional Functions, seleccionamos "Guided Functions"
2º En la columna de la derecha, abajo del todo, marcamos APPS y acto seguido en la columna del centro Select Procedure seleccionamos Upload Paremeter Data y hacemos click en Next.
3º Ponemos el contacto y presionamos Next
4º Se nos abre la venta de Config Data Uploader, hacemos click en Open ZDC File y seleccionamos el que corresponda con nuestro navy, en la lista de archivos es el que empieza por LEON............ZDC y hacemos clieck en OPEN
5º En la ventana superior derecha, en ECUs marcamos el modulo 5F y abajo seleccionamos Sound Parameters Hatchback* Soundsystem.
*Hatchback, Coupe o ST podremos elegir dependiendo de nuestro modelo de coche.
Subimos el fichero haciendo click en Upload Selected Data, se reinicia el MMI y ya lo tenemos cambiado.
Buongiorno a tutti, vi scrivo dall'italia, per prima cosa vi chiedo scusa se non scrivo in spagnolo, ho effettuato tutta la procedura con vcp 5.5, ma non riesco a trovare la voce "Hatchback". Come posso fare? Possibile che il mio vcp non trovi il medesimo software?
Pippoleon
Notapor Pippoleon el 06 Nov 2019, 12:19
Buongiorno nuovamente, mi è sorto un dubbio ma i pin 10 e 14 vanno uniti al pin 7 e il pin 10 va unito al pin 3 o vanno solo invertiti i cavi? Porrei avere delle informazioni in più a riguardo? Perche i connettori sono tutti occuppati.
Pippoleon
Notapor JOTTA el 06 Nov 2019, 15:39
Siento no poder ayudarte, con suerte habrá algún compañero que sepa idiomas
JOTTA
Agradecido: 55 veces
Notapor freepassion el 06 Nov 2019, 15:57
Cuales el idioma? No entiendo también
Envoyé de mon LYA-L29 en utilisant Tapatalk
freepassion
Notapor jasoriab el 06 Nov 2019, 16:06
Si os referís al idioma en el que escribe @Pippoleon es italiano.
Gracias a Google Translate, este sería el texto traducido a nuestro idioma:
Hola a todos, les escribo desde Italia, en primer lugar me disculpo si no escribo en español, he hecho todo el procedimiento con vcp 5.5, pero no puedo encontrar la entrada "Hatchback". Como puedo hacerlo ¿Es posible que mi vcp no encuentre el mismo software?
Buenos días nuevamente, ¿tenía alguna duda, pero los pines 10 y 14 deberían unirse al pin 7 y el pin 10 debería unirse al pin 3 o los cables solo deberían invertirse? ¿Me gustaría tener más información al respecto? Porque todos los conectores se usan.
A ver si alguno que controléis del tema le podéis ayudar.
jasoriab
Notapor BADS el 06 Nov 2019, 22:20
Pippoleon escribió:Buongiorno nuovamente, mi è sorto un dubbio ma i pin 10 e 14 vanno uniti al pin 7 e il pin 10 va unito al pin 3 o vanno solo invertiti i cavi? Porrei avere delle informazioni in più a riguardo? Perche i connettori sono tutti occuppati.
Il tuo VCP è originale? Qual è l'hw della tua unità?
Il pin 14 unirà il pin 3 e il pin 10 unirà il pin 7.
BADS
Notapor Pippoleon el 07 Nov 2019, 03:49
Buongiorno per le tempestive risposte ho risolto! :comediante:
Pippoleon
Notapor Pave el 15 Dic 2019, 14:19
Hi!
Again, sorry that I´m writing in English... :?
I also am thinking about installing those two more speakers in my car.
Originally my car has that 5" screen and 8 speakers (8RM)....
Now I am replaced that with hacked mib2 high unit and 8" screen....
I noticed that mib2 unit is parameterized for Seat Sound System (9VD) althought my car hasn´t it....
That´s weird because the seller parameterized / coded the unit among my car´s VIN....
And I don´t have VCP.... only Vcds so I can´t change the coding back to 8RM....
That´s why I´m thinking about that retforit could be best solution.
What I think is problem, is that my car´s wiring originally hasn´t any wires in pins 10,14, 9, 13....
So in the back of the mib2 unit, those pins are free for subwoofer and center speaker...
But I can´t splice / join any existing speaker cables which is needed I think... or at least I don´t know how...
So is it possible to retrofit SSS for that my system at all??
Pave
Coche: Leon MK3 1.4 TSI 140cv
Notapor BADS el 15 Dic 2019, 20:06
Hello friend,
Are you sure there is no wires in pin 14, 13, 10 and 9? what year is your car? This pins are usually used in 8rm configuration!
BADS
