León Mk3 - BRICO - Como reequipar "Seat Sound System"
Favoritos: JupiJ79, saxisaac, rojas, dani90, xaacra, francesito, abelsfc, jelajasb, Carrl, itsAdriaan96, ertate, J-Frass, Jester, lokitovs, bronce702, OGT, tsi125, Alleya, maki26, ZXVolcane, jj_leon, espix, Martin VO
Seguidores: JOTTA, Rasekfighter, Josito3, sghezz, daniel_44, danieleon, leonfrrojito, LeoST, Dandy_gsi, pirly, davidbj, genialsoft, saxisaac, the-game-310, er_trompe, Jorge75016, Marc.22, Albino, crcrodrigo, xabidh, Abraham Morin, ivansf16, ivan0909, ruben88, iazofra, Stonemaker, Edu82, ocsido, arracho, davindu3, erizo-man, jande, aigort, Dconnect, osjamil, el_padrino, clarens, fermr, Vilo, Zarkis, MORKAS, Juanlu23, LuichiFR, Miguelpfdez94, Manu1986, aguscalderon, djcastle, yoflipo, Illan, tsi125, juanmik, VapaV, jose.jjg307, teltronik, jd_zuri, carrasco13, bronce702, Espartan23, conquepoquico, Senuto, victor david, Edu1589, freepassion, Maikermx, Brandenor, fxtra, fun_olivier, Rekoba, Chrohu, gymnos, JDMG, josermancol
Re: BRICO-Como Instalar el "Seat sound system " a posteriori
Notapor Pave el 15 Dic 2019, 22:44
BADS escribió:Hello friend,
Are you sure there is no wires in pin 14, 13, 10 and 9? what year is your car? This pins are usually used in 8rm configuration!
Yep, I`m pretty sure.... :roll:
My car is 2013 Fr-model....
I think that original pathtetic 5" screen is reason for that...
That´s what I thought also.... but in my opinion there is only those 8 wires in that one connector which goes to speakers...
That makes wire splicing / joining pretty hard or even almost impossible...
Don´t know exactly how those wires are connected to speakers
I have to confirm that once again some day...
Pave
Coche: Leon MK3 1.4 TSI 140cv
Notapor BADS el 16 Dic 2019, 00:43
Ok ok i was thinking you had 5,8 screen... but if you had 8rm configuration before upgrade you can do the sss upgrade aswell. you just need the electric diagrams of your vehicle to guide you. i can provide you if you want.
edit: in fact you do not need to change any wires, just add the cental speaker and sub, i was checking the diagrams and your configuration is the same for 9vd.
Front speakers:
Back speakers:
BADS
Agradecido: 17 veces
Notapor Pave el 16 Dic 2019, 12:38
Front speakers:
Back speakers:
Wow!! :shock:
That can´t be true!!!
It sounds amazing :o
Now it seems that I have to find subwoofer and center speaker :)
Thanks in a million times!! :reverencia:
Pave
Notapor Frank68 el 17 Dic 2019, 17:06
Hola a todos, pero ¿es posible montar solo el panel de control?
Frank68
Notapor BADS el 17 Dic 2019, 17:45
:mad:
Front speakers:
Back speakers:
In order to install the subwoofer you need to get 5F0012109 spare wheel 18" or 5F0012109B the foam, if you don't have it already
BADS
Notapor Pave el 18 Dic 2019, 00:06
BADS escribió::mad:
Yes, I need that foam... I have puncture kit at the moment, so no spare wheel .... Finding that foam seems to be pretty hard.... I read that it costs there in Spain about 33€ + VAT.
Here in Finland it costs almost 100€ :o
And used ones are very hard to find....
Maybe I have to hire some agent there in Spain who try to find those parts in some scrapyard or private seller and send them to me :lol:
And subwoofer and center speaker are also under looking still... :)
By the way, I´m not pretty sure about those speaker connector pins which I need.... because some connectors comes without pins.
So what type / size pins do I need for center speaker connector (1J0971972) and what for subwoofer connector (4EO971942)??
And also what type of pins goes to quadlock / main unit to those pins 9, 10, 13, 14?
Thanks in advance!!
Pave
Notapor BADS el 18 Dic 2019, 01:10
Pave escribió:
BADS escribió::mad:
Thanks in advance!!
I got my wheel from ebay nice price!!!
For central speaker 1J0971972 - connector and 000979019e pins
For subwoorfer 4EO971942 - conector and 000979026e pins
Also you will need 000979021E pins to conect wires in the quadlock
The conections you can check at the diagrams above, its all there.
Última edición por BADS el 18 Dic 2019, 01:29, editado 1 vez en total
BADS
Notapor Pave el 18 Dic 2019, 01:23
BADS escribió:I got my wheel from ebay nice price!!!
For central speaker 1J0971972 - connector and 000979026e pins
Great, thanks for the info!!
I thought that subwoofer connector needs "bigger" pins, but those seems to be same.
What pins are those mentioned in first post (000979131EA)?
Part hunting continues :cool:
Pave
Notapor BADS el 18 Dic 2019, 01:59
i made a mistake in the post, pasted the same terminals both connectors but i fixed already. For central speaker 1J0971972 - connector and 000979019E pins
So, 000979019E is for 0.5mm2 cable and 000979131E for 1.0mm2 cable, basically they are identical but for different cable diameters. As the diagrams above shows, the cable for central speaker should be 0,5mm2.
BADS
Notapor Conn79 el 29 Dic 2019, 16:06
Buenas, llevo siguiendo el foro desde hace tiempo, y este post en especial, he montado el sss, pero me faltaría codificar con el vcp, tengo el vag com y el Odis, pero veo que hay que cargar unos archivos para que funcione, y con Odis y vag com no veo la opción.
Alguien por Barcelona que pudiera actualizar? Para que aparezca el subwoofer en la pantalla? Pagando claro esta
Conn79
Notapor aprietatuercas1974 el 07 Ene 2020, 06:21
Conn79 escribió:Buenas, llevo siguiendo el foro desde hace tiempo, y este post en especial, he montado el sss, pero me faltaría codificar con el vcp, tengo el vag com y el Odis, pero veo que hay que cargar unos archivos para que funcione, y con Odis y vag com no veo la opción.
Buenas ,te escribo privado
aprietatuercas1974
Agradecido: 358 veces
Notapor Conn79 el 11 Ene 2020, 23:04
Codificado y funcionando, muchas gracias! Brutal el cambio de sonido
Conn79
Notapor Dani_rs el 12 Ene 2020, 13:39
Hola, tengo un problema para realizar el brico en un leon cupra de junio del 2019.El coche estaba configurado con beats audio y buckets, pero antes de empezar a fabricarlo nos indicaron que habia una incompatibilidad entre los buckets y el amplificador del beats audio... y al final lo compramos con buckets pero sin equipo de audio (contando con poder reinstalar a posteriori el seat sound system como tiene mi cupra st del 2016).
Despues de comprar todo lo necesario, de pasar los cables, cuando me dispongo a recolocar los pines, me he llevado la sorpresa de que no coinciden los colores del cableado con ningun esquema de los que habeis aportado.
https://ibb.co/S6MNY6T
https://ibb.co/k590ZdD
https://ibb.co/RYCG6Qq
https://ibb.co/n0d534v
https://ibb.co/rshWM21
https://ibb.co/9gG4jK0
Dani_rs
Re: BRICO Como Instalar el "Seat sound system " a posteriori
Notapor OSCAR77 el 12 Ene 2020, 21:57
arlot escribió:Los precios deben ser aproximados
Tienes el desglose del altavoz central con cable etc etc.
Sabeis si es esto, pero el croquis con el desgloce me ayudaria.
necesitaremos :
1 conectores de 2 pines para el central , un extractor de pines , cinta aislante , cinta de tela ,1 metro de marron y 1 metro de negro de 0,5 mm ( para el central )
5F0035397 Altavoz central
1J0971972 Conector altavoz
000979131EA Pines aixo no ser
5Q0803899 Tornillo
N90698803 grapa/pestaña para tornillo de altavoz central x2
N10666302 tornillo para altavoz central x2
Oscar
OSCAR77
Agradecido: 15 veces
Notapor OSCAR77 el 12 Ene 2020, 21:58
rojas escribió:
arlot escribió:Gracias rojas, ya he pedido las herramientas para sacar el lector.
En cuanto a mi pregunta, que no me he explicado bien, es cuales son los pasos a seguir, si sólo quiero montar el altavoz central. Con tanto cable me hago un lio.
Y solo me gustaria montar el central porque tengo la rueda de recambio de 16"
El conector cogeré el Toledo MK2, el de la luz del maletero, espero que me sirva ese mismo.
Pd. siento agobiarte con tantas dudas.
no hay agobio , tranquilo :ok:
el caso es que si solo quieres montar el central ... te vas a encontrar con los pines ocupados en el conector , ya que van en los pines 10 y 14
en el 10 pondrias el cable negro de 0,5 y en el 14 el cable marron de 0,5
esta es la ubicacion del central y el subwoofer :
lo que dudo es si la unidad reconoceria esa configuracion como tal al no tener el subwoofer conectado.
y si , el conector que comentas te vale perfectamente
yo ya he pedido el conector original a audi , que estoy a un 90% seguro que es el mismo que usa seat para conectar el subwoofer , cuando lo reciba y verifique que sea el suyo ...os pongo la referencia , cuesta 1,78 €+ iva
Hola Rojas,
Me podrias solucionar la duda si pongo solo el central me valdria?
Oscar
OSCAR77
