León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor IvanMc2 el 05 Sep 2015, 17:33
yours3lf escribió:
IvanMc2 escribió:
yours3lf escribió:
IvanMc2 escribió:
yours3lf escribió:
IvanMc2 escribió:
Desde la ignorancia...vale cualquier relé?
Como resumen, entiendo que quedaría así:
- luz de portamatriculas empalmado al portamatricula actual
Imagen:
- rca a la guantera
Entrada al relé:
- positivo «constante» de la caja de fusibles o bien de la luz del maletero.
- positivo de marcha atrás para activar la cámara
- negativo
Salida del relé:
- alimentación de la cámara
Gracias y siento haberos dado la lata!!
Correcto, tener en cuenta que el negativo de la camara puede ser el mismo que el del rele.
El rele que yo use en un principio es de coche y creo que si son todos iguales o la gran mayoria (en el dibujo del rele tiene que salir un diagrama igual o muy parecido al de la imagen que subi)
Luego compre uno em una tienda de electronica para ponerlo en una placa con 2 condensadores, pero ese es otro tema.
Vale, me acercaré a preguntar a una tienda de electrónica.
Por curiosidad, para que necesitas los condensadores? Ahora que ya lo tengo claro...metes más cosas
En este caso se usa c1 para mantener una corriente de 12 para activar el rele, aunque creo que no es muy necesario.
C2 si es mas importante ya que evita picos de tension y mantiene de la misma forma 12v mas constantes.
C1 no sabria decirte el valor de carga, 3l de voltage entre 16v y 25v.
C2 entre 1600uf y 2200uf e igual 16v o 25v.
Yo he puesto 2 de 2200uf a 16v.
Entiendo.
Lo montaré sin C1 y tirando de fusible.
Perfet
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2
Agradecido: 129 veces
Notapor XoXe el 09 Sep 2015, 12:30
Bueno he preguntado en la Seat por curiosidad a ver cuanto cuesta que la instalen ellos y esta ha sido la respuesta:
Buenos días.
Tras consultar con recambios, me informan que no se vende como accesorio original con lo que no podemos instalarla.
XoXe
Agradecido: 59 veces
Notapor Rasekfighter el 09 Sep 2015, 12:49
Jajaja me parto con la seat....
Rasekfighter
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 64 veces
Notapor rojas el 09 Sep 2015, 15:28
:lol: :lol: :lol: :lol: :lol: :lol: os sorprende??????
rojas
Agradecido: 1887 veces
Notapor Rasekfighter el 09 Sep 2015, 15:29
rojas escribió: os sorprende??????
No mucho la verdad... Parece de chiste
Rasekfighter
Notapor XoXe el 09 Sep 2015, 19:55
Meeecachis, y en una tienda me cobran 570 lereles, incluido el "interfaz". No si al final todavía me animaré yo...
XoXe
Notapor sonxav el 10 Sep 2015, 16:04
XoXe escribió:Meeecachis, y en una tienda me cobran 570 lereles, incluido el "interfaz". No si al final todavía me animaré yo...
es para flipar, aqui en Barna por 140€ te la montan.... :plas: , eso si, no en seat.
sonxav
Agradecido: 526 veces
Notapor dangerzone el 10 Sep 2015, 16:12
@xoxe tranqui que a mi me dieron un presupuesto de 650 boniatos... :mosqueao: ( no en la seat, así que miedo me da ir al conce).
No obstante si puedo y paso por el conce hoy, os digo cuanto canta.
dangerzone
Agradecido: 198 veces
Notapor XoXe el 10 Sep 2015, 17:14
Ya te digo que a mi me dijeron que no la ponían.
XoXe
Notapor arlot el 10 Sep 2015, 18:33
@XoXe Joer si estuvieramos cerca nos liariamos los 2 a montarla, como hizo @rojas conmigo (yo hacia de pinche, y el todo el trabajo, pero eso que quede entre nosotros) :marley:
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor XoXe el 10 Sep 2015, 19:10
Se agradece , lo que mas miedo me da es pasar el cable hasta alante o "robar" la corriente
XoXe
Notapor Marc.22 el 12 Sep 2015, 00:40
Buenas!
Hoy me he puesto a montar la camara trasera después de 6 meses :marley: he tenido muchos problemas con el pasamuros así que finalmente he decidido desmontar el paragolpes entero para ver que pasaba. Pues bien, el pasa,uros esta cubierto con masilla!! Suerte que lo he desmontado si no me habría sido imposible verlo. Mi leon es un FR matrícula JDY (abril 2015), he adjuntado dos fotos, en una se puede ver el pasamuros despues de darle con el destornillador y en la siguiente vereis el único sitio por donde poder pasar los cables, se encuentra en la parte izq del maletero, quitando la moqueta. A alguien mas le ha pasado???
Marc.22
Notapor MORKAS el 14 Sep 2015, 01:25
Saludos..tras haberme llegado la camara que he pedido...voy a ir poco a poco .planenado el trabajo..jeje..gracia s alas indicaciones de @juanba...mas o menos ya voy con la idea hecha..pero me surgen ciertas dudas..acerca de la camara que he recibido....pues segun el tutorial de @rojas....habeis tenido que poner un filtro basado en un rele y un condensador....y mi camara trae con ella una cajita que pone FILTER FUSE....voy a adjuntaros unas fotos de la camara que me ha llegado...y despues os expongo com haria yo la instalacion..usando ese "filtro" que me trae...y me gustaria vuestras opiniones acerca de si fuese viable...
LA CAMARA:
EL FILTRO O CAJITA:
No se si esta cajita podria sustituir al montaje del rele y condensador...seria probar..si no valiese..con dejar esa cajota desconectada..haria el montaje como @rojas..
El caso es que el esquema que pienso que podria servirme es de esta manera.:
Que opinais?..@rojas..crees que podria servirme?..lo unico que veo un poco latoso..es que del cable de la luz de marcha atras..tendria que llevar un cable hasta casi donde la radio..para darle corriente a la cajita ...no se...creo que voy a intentarlo...y hacer pruebas..con paciencia.jeje
Por cierto..aprovecho para preguntaros si existen conectores hembra o macho (no se que tipo de conector lleva hasta que lo mire)...del plafon de matricula..es decir..quisiera un conectorque acople con el original de la luz de matricula.para no andar con robacorrientes..y si algun dia he de quitar la camara que sea desconectando el enchufe..me refiero a este tipo de conectores:
Gracias y a ver si podeis echarme una mano..jeje
MORKAS
Agradecido: 369 veces
Notapor rojas el 14 Sep 2015, 06:32
Me gusta mucho ... con esto te ahorras todo el lio del condensador ; y si ... si hay un conector para el de luz de matricula
rojas
Notapor rojas el 14 Sep 2015, 06:35
Me gusta mucho ... con esto te ahorras todo el lio del condensador ; y si ... si hay un conector para el de luz de matricula.
El cable azul es solo para las radios chinas ... tu no tienes q conectarlo
rojas
