León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor Qarl el 14 Sep 2015, 07:19
@MORKAS cuando tengas todo montado podrías pasar una foto desde atrás para ver la diferencia entre la luz original de la matrícula y la que trae la cámara?? Es lo único que me echa para atrás, que haya diferente tonalidad.
Y si ya pones el link donde la has comprado pues mejor que mejor jejeje.
Qarl
Agradecido: 83 veces
Notapor difrafotard el 14 Sep 2015, 08:29
difrafotard escribió:Hola, por fin este verano tuve tiempo para montarla en mi st, y eso que tengo la cámara en mi poder desde octubre.
Mi cámara es de las que van en el plafón de la matrícula y es un poco mojón, en general cumple pero en la oscuridad no se ve prácticamente nada y con muchísima luz, que sea da en pocas ocasiones, parpadea porque debe llevar un ajuste de exposición malo malo. Como ya tengo la instalación, ya compraré otra.
Por cierto, con este tipo de cámara, para no "pinchar" el cable de luz de la matrícula compré el conector 1j0973802 [ Imagen ]
Hola, me autocito para lo del conector.
difrafotard
Agradecido: 23 veces
Notapor Eluryh el 14 Sep 2015, 08:40
Ninguna novedad sobre si se puede montar la oficial de SAT a posteriori no?
Eluryh
Agradecido: 107 veces
Notapor arlot el 14 Sep 2015, 09:09
rojas escribió:.... y si ... si hay un conector para el de luz de matricula
@rojas a ver si me pones el sitio para conseguir ese conector, por aquello de quitar los robacorrientes y dejarlo más limpio y pulido.
Vamoooooooooooooos
arlot
Agradecido: 977 veces
Notapor MORKAS el 14 Sep 2015, 11:52
rojas escribió:Me gusta mucho ... con esto te ahorras todo el lio del condensador ; y si ... si hay un conector para el de luz de matricula.
El cable azul es solo para las radios chinas ... tu no tienes q conectarlo
Es decir..podria evitar el rele?..probare en cuanto tenga tiempo
MORKAS
Agradecido: 369 veces
Notapor MORKAS el 14 Sep 2015, 11:53
Si..eso..donde podemos comprar el conector. Ebay?...
MORKAS
Notapor MORKAS el 14 Sep 2015, 11:56
MORKAS
Notapor MORKAS el 14 Sep 2015, 12:21
Qarl escribió:@MORKAS cuando tengas todo montado podrías pasar una foto desde atrás para ver la diferencia entre la luz original de la matrícula y la que trae la cámara?? Es lo único que me echa para atrás, que haya diferente tonalidad.
Cuando me ponga con ello hago fotos de todo..tipo @rojas..
MORKAS
Notapor MORKAS el 14 Sep 2015, 13:51
MORKAS
Notapor difrafotard el 14 Sep 2015, 14:28
Ya lo he puesto arriba, pero ha pasado desapercibido
El conector que yo puse, 1j0973802:
difrafotard
Notapor arlot el 14 Sep 2015, 14:33
Mañana me voy al conce a pedirlo
Vamoooooooooooooos
arlot
Notapor yours3lf el 16 Sep 2015, 10:39
arlot escribió:
yours3lf escribió:
arlot escribió:
yours3lf escribió:Esta me sirve, verdad?
http://vi.raptor.ebaydesc.com/ws/eBayIS ... 1117452660
@yours3lf esa es la que compramos la gran mayoria
Este en menos de 2 semanas la tienes en casa: http://www.ebay.es/itm/360771665975?_tr ... EBIDX%3AIT
Un par de preguntas a ver si me puedes echar una mano (o quien sea!)
- Los pines 000979009 son especificos de SEAT / VAG o los venden en tiendas de electrónica?
- Hace falta montar condensador? Algunos hablan de él y otros no :\ en ese caso, de cuánto debería ser?
Mil gracias!
Los pines se los compré al pollo este de ebay:
http://www.ebay.es/itm/260907168545?_tr ... EBIDX%3AIT
Yo no he montado condensador ni relé, y se ve perfectamente. el negativo lo he tomado del cierre del portón, y el positivo lo he sacado directamente de la caja de fusibles mediante esto:
Si tienes prisa (1-2 semanas), este: http://www.ebay.es/itm/400782802815?_tr ... EBIDX%3AIT
Si no tienes prisa (más de 1 mes), este: http://www.ebay.es/itm/381074897854?_tr ... EBIDX%3AIT
Buenas!
He recibido el conector del fusible y tengo un par de dudas, a ver si me puedes echar una mano (al cuello no! Sé que soy pesado...)
1) el conector nuevo de fusible tiene dos hembras. Entiendo que deberé poner el fusible de mechero actual + otro nuevo para la nueva salida de corriente. Cierto?
2) el empalme de la corriente como se hace? es decir, he visto que encaja el cable de 1mm de corriente. Imagino que deberé empalmar allí pero...ese plastiquillo azul que hace? Lo tengo que apretar con alicates? Lo pelo mucho o poco?
Gracias, cuando lo tenga montado quedamos un día y te invito a una cervecita fría Lo prometo!!!
yours3lf
Agradecido: 26 veces
Notapor arlot el 16 Sep 2015, 13:06
yours3lf escribió:Buenas!
Te respondo en orden:
1-Una entrada es para el fusible de 20A que lleva el choche ahora, y el otro es para ponerle el fusible a la cámara. Si no se lo pones, la cámare no irá.
2-El plastico azul lo has apretar con unos alicates una vez que hagas el empalme, metes el cable pelado ahí dentro y de das a los alicates. Yo lo que hice es poner un macho-hembra por si queria sacar el cacharro de la caja de fusibles; así cuando lleves el coche a revisión, lo desconectas y la camara no funcionará.
Vamoooooooooooooos
arlot
Notapor yours3lf el 16 Sep 2015, 13:10
Entiendo, gracias!!
Sólo me falta recibir la cámara fuuu
yours3lf
Notapor arlot el 16 Sep 2015, 13:28
@yours3lf un detalle, cuando pongas el portafusibles verás que la tapa no cierra, y le vas a dar recuerdos a toloquesemenea, pero que no cunda el pánico; con un cutex le quitas lo marcado en rojo, y problema resuelto
Vamoooooooooooooos
arlot
