León Mk3 - Actualización infotainment
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
Re: Actualización infotainment
Notapor cvillajos el 07 Mar 2017, 09:28
david06 escribió:
Henno escribió:
david06 escribió:
cvillajos escribió:
david06 escribió:
cvillajos escribió:For 5F (1555 error) read or translate "installation post" (and later comments) on page 41.
Regards!!
th23autolink_encode_start_97mjxd15W2ltZzo5N21qeGQxNV1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMS81bkZuM3EmIzQ2O2pwZ1svaW1nOjk3bWp4ZDE1XQ==th23autolink_encode_end_97mjxd15
Le code ne va pas
el código no lo hará
Insert a white space between 'F3' and 'B9'. Just like this "F3 B9" with VagCom interface.
Regards!!
th23autolink_encode_start_26l0x7utW2ltZzoyNmwweDd1dF1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMy9pRDF1YzEmIzQ2O2pwZ1svaW1nOjI2bDB4N3V0XQ==th23autolink_encode_end_26l0x7ut
th23autolink_encode_start_26l0x7utW2ltZzoyNmwweDd1dF1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMy8wc2lRSGsmIzQ2O2pwZ1svaW1nOjI2bDB4N3V0XQ==th23autolink_encode_end_26l0x7ut
Creo que el código se pasa, pero la pantalla permanece en negro un poco de luz
la bomba de la batería
je pense que le code est passé mais mon ecran reste noir un peu allumer
sa pompe sur la batterie
@david06
If I got your postings right, your Radio is not booting after flash?
Only Black screen with some backlight?
I have the same problem after flashing my MY16 MIB2
Could you fix this problem?
Anyone else know this problem and know how to this??
no, no se resuelve mi problema sigue ahí
Sí me gusta ser desagradable para ella
Did you try to flash again?
Regards!!
cvillajos
Agradecido: 3613 veces
Notapor david06 el 07 Mar 2017, 10:02
cvillajos escribió:
david06 escribió:
Henno escribió:
david06 escribió:
cvillajos escribió:
Regards!!
Le code ne va pas
Regards!!
th23autolink_encode_start_3qgmb8g4W2ltZzozcWdtYjhnNF1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMy9pRDF1YzEmIzQ2O2pwZ1svaW1nOjNxZ21iOGc0XQ==th23autolink_encode_end_3qgmb8g4
th23autolink_encode_start_3qgmb8g4W2ltZzozcWdtYjhnNF1odHRwJiM1ODsvL2ltYWdpemVyJiM0NjtpbWFnZXNoYWNrJiM0Njt1cy92Mi8xNTB4MTAwcTkwLzkyMy8wc2lRSGsmIzQ2O2pwZ1svaW1nOjNxZ21iOGc0XQ==th23autolink_encode_end_3qgmb8g4
@david06
Regards!!
¿qué quiere decir eso?
la forma de hacerlo de nuevo si la función de radio más?
david06
Coche: Leon MK3 1.5 TGI 130cv
Notapor ruben91mad el 08 Mar 2017, 13:49
acr_89 escribió:hola, muy buenas.
tengo mi leon 5f desde el 2013 y me interesaria saber de donde descargar la actualizacion del software ( no el del gps sino el de la pantalla) y saber si hay manera de meterle el sistema android... muchas gracias de antemano
cvillajos escribió:
dasapi28 escribió:yo acabo de adquirir un cupra 20 años tiene
refErencia de dispositivo 5QA
HARDWARE H30
SOFWARE 0351
pero no se en donde puedo descargar los mapas para le navi y por lo que vi tiene le mismo sistema que la ateca por la foto que subieron al principio ayuda porfavor
¿20 años? :shock: (creo que te han bailado los números).
Este hilo es para actualizar el software de la radio. Para actualización de mapas ya tienes otros donde hay mucha información y enlace a las descargas de las actualizaciones:
- 6,5": http://www.clubseatleon.net/viewtopic.php?f=9&t=119775
- 5,8": http://www.clubseatleon.net/viewtopic.php?f=9&t=94691
que version tienes de hardware?
ruben91mad
Coche: Leon MK3 1.2 TSI 105cv
Notapor ruben91mad el 08 Mar 2017, 13:55
hola, soy nuevo aqui y no tengo mucha idea. Me compre en agosto el reference connect con la pantalla de 6 y me trae la version h24 0245 y un amigo a la vez que yo el style connect y el trae la versión h30 0351. ¿es normal esto? a mi amigo le sale el menu del ateca.
ruben91mad
Notapor david06 el 09 Mar 2017, 11:01
sin manipulación para iniciar la radio?
david06
Notapor kossel el 12 Mar 2017, 16:14
Hola de nuevo, a pesar de que nadie contestó a mi anterior duda, no le di mayor importancia y me lancé a actualizar. Por suerte todo correcto.
Un detalle sólo. No sé qué pasó cuando todavía estaba en la versión 0330 que el táctil dejó de funcionar y ya no podía hacer la siguiente actualización. De casualidad tenía la unidad de guantera fuera de la guantera y pude desconectarla físicamente del quadlock y volverla a conectar. El táctil volvió a funcionar y pude continuar con la actualización a la 0346. Lo digo por si a alguien más le pasa, aunque supongo que tendrá una solución menos drástica. No tengo ruleta derecha porque es una pantalla de 8", por eso no tenía control alternativo al táctil.
Conseguí poner el modelo que quería de coche en la pantalla de estado (casi, porque me sale un Cupra ST y no corto como yo quiero) y saqué el gráfico del clima siguiendo las instrucciones, pero nadie tiene un 5 puertas corto? Todos ST? Nadie sabe qué bits hay que activar en el Coding de la 5F, en car derivative, y en el de la 08 para que aparezca un Cupra corto? Sí, el mío no es Cupra pero me gusta ese gráfico más que el del Style. Es posible hacerlo? Todo el mundo busca poner un ST, yo al contrario. A ver si ahora tengo más suerte...
kossel
Coche: Leon MK3 1.2 TSI 86cv
Agradecido: 56 veces
Notapor miceor el 12 Mar 2017, 18:56
No sé como lo tienes ahora mismo puesto.
En el mio con las pruebas realizadas esto es lo que muestra:
Por ejemplo. Combinaciones de los tres ultimos parámetros:
- Byte 1 Car Class ------------ 3
- Byte 1 Car Generation ----- 7
- Byte 2 Car Derivate -------- 3
Da un resultado de un Seat León ST
- Byte 2 Car Derivate -------- 2
Da un resultado de un Seat León corto 5 puertas
- Byte 1 Car Class ------------ 2
- Byte 1 Car Generation ----- 5
- Byte 2 Car Derivate -------- 0
Da un resultado de un Ibiza corto 5 puertas
- Byte 2 Car Derivate -------- 4
Da un resultado de un Ibiza corto 3 puertas
Da un resultado de un Ibiza ST
- Byte 2 Car Derivate -------- 1
Da un resultado de un Toledo
miceor
Agradecido: 1259 veces
Notapor kossel el 12 Mar 2017, 19:07
Muchas gracias, Miceor. A mí se me empeña en poner un ST Cupra con la combinación
Unidad 5F Coding:
- Byte 18 Screenings -------- 2
Unidad 08 (clima) coding:
Car variant
OFFROAD
Roof
Panoramic roof
Con el resto de combinaciones que he probado saca un Style 5 puertas corto con llantas de 17".
Car variant
Short rear (multivan)
Roof
Standard
Como estaba originalmente
Por más que pruebo otros valores de car derivate esos son los dos únicos gráficos que he conseguido sacar. Me quedo en el Cupra de momento porque es con el que me sale el gráfico del clima. Con el Style no sale. Reseteo Vehículo y Sistema y reinicio, como indicas, cada vez que hago un cambio. Hay que esperar un par de minutos que arranque del todo la 5F antes de realizar cambios en su codificación con el OBDeleven?
kossel
Notapor Cherno01 el 13 Mar 2017, 18:00
Una pregunta, si actualizo una H24 - 245 a la versión 346, si en algún momento la Seat saca una versión más moderna (por ejemplo una 350) se podrá actualizar o sólo se podrá desde la 245?
Es por hacerlo o mejor dejarlo de momento a ver si en julio sacan algo.
Cherno01
Notapor Trimmer el 14 Mar 2017, 01:40
Nose si va aqui la pregunta... Pero... Cada vez mas moviles nuevos utilizan usb tipo C, conectandolos con el cable original al coche, ¿funcionarian igual? Me refiero android auto y mirrorlink.
Trimmer
Notapor fermr el 14 Mar 2017, 01:50
Trimmer escribió:Nose si va aqui la pregunta... Pero... Cada vez mas moviles nuevos utilizan usb tipo C, conectandolos con el cable original al coche, ¿funcionarian igual? Me refiero android auto y mirrorlink.
Yo tengo un htc con usb tipo c y funciona muy bien con mirrorlink
fermr
Notapor Trimmer el 14 Mar 2017, 01:53
El cable es "igual" digamos usb tipo c por el lado del movil, USB normal por el lado "del coche" o tienes adaptador?? Carga mas lento imagino.
Trimmer
Notapor fermr el 14 Mar 2017, 01:58
Es el original y no no uso adaptador. Del lado del cel es usb tipo c y del otro lado usb normal (el que se conecta al carro). Y carga bastante rápido. Saludos
fermr
Notapor ruben91mad el 15 Mar 2017, 11:19
hola, en la revisión de mantenimiento deben actualizarme la versión de la pantalla del h24 a la 46? ya que dicen que las anteriores dan problemillas deberían hacerlo no ?
ruben91mad
Notapor fordol el 15 Mar 2017, 16:59
Buenas tardes, una pregunta, quiero actualizar el equipo pero lo que he leído en el foro casi seguro q dan diferentes tipo de errores, yo tengo el de 6.5 full link sin nav. pero la duda que tengo es que como no tengo el vag ni el otro programa, pues ya no se que hacer, si actualizo o no, pq si no tengo los programas para quitar los errores vaya que sea peor el remedio que la enfermedad. que me recomendáis pq me gustaría actualizarlo la verdad.
fordol
