León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor larax el 13 Nov 2015, 17:53
genialsoft escribió:Solo para que lo tengas en cuenta la tv digital DVB-T son otros 95€, aunque en cualquier caso que guapos hacen los aparatos estos los chinos, yo tenía uno OEM chino en mi anterior coche y quedaba espectacular y este tiene muy buena pinta, además puedes mostrar a la vez la cámara trasera y delantera!
Si, eso me he dado cuenta, gracias por el dato.
Intentaré ponerme en contacto con el chino para ver si los botones del volante quedan inútiles o pueden seguir funcionando igual
larax
Coche: Leon MK3 1.2 TSI 86cv
Agradecido: 16 veces
Notapor midlink el 13 Nov 2015, 21:28
Buenas, alguien me ayuda? Estoy haciendolo y no me deja entrar en el modulo 10 Park/seter assist el vagcom...
Me pone que no hay respuesta, a nadie mas le ha pasado?
midlink
Notapor ays11 el 14 Nov 2015, 08:46
Chicos, al final el formato de la cámara en PAL o NTSC??
No vaya ser que la lie!!
Gracias!!!
Saludooosss
ays11
Notapor midlink el 14 Nov 2015, 10:55
ays11 escribió:Chicos, al final el formato de la cámara en PAL o NTSC??
Gracias!!!
Saludooosss
Ambas sirven para el leon!
Oye chicos, yo no consigo entrar al modulo 10 de park assist
midlink
Notapor midlink el 14 Nov 2015, 13:26
despues de hacer el test me sale esto... ero por ejemplo el 5F si que me ha funcionado... y nose el Instruments también me funciona, si he hecho varios bricos ya con vag com..
No entiendo nada chicos... Si alguien es de Barcelona y tiene vag com y podemos quedar para ver si con el suyo... me haria un favor inhumano.
midlink
Notapor Qarl el 15 Nov 2015, 16:17
Alguno que haya puesto la camara de parking ha sabido como quitar el fondo negro que sale con los sensores traseros??
Es lo único que me falta, pero no doy con ello...
Qarl
Agradecido: 83 veces
Notapor Stealnick el 16 Nov 2015, 09:36
midlink escribió:[ Imagen ]
Ya somos 2 :cry: :cry: !!!! Alguien nos hecha una mano, cómo se quitan los errores????
Stealnick
Agradecido: 269 veces
Notapor midlink el 16 Nov 2015, 17:32
Bueno yo los errores se supone que ya no los tengo.. pero no me aparece el modulo 10...a los demás les aparecen más modulos..
midlink
Notapor midlink el 17 Nov 2015, 20:37
He probado con el Vagcom de un colega, que es el 12.12.0 y nada... me aparecen los mismo modulos (nose si a él le aparece el modulo 10...) a ver no tengo la camara instalada, pero entiendo que la ECU debería de aparecer como instalada igual...
aclarar que no tengo sensores de aparcamiento...
Seguí los siguientes pasos... conecté los cables del conector amarillo (positivo y negativo) al conector correspondiente... y alimente los leds y el positivo y negativo de alimentacion de la camara con una fuente de alimentación externa de 12V. (más que nada para no hacer toda la instalación en vano, antes de nada). Y entonces me puse a codificar... codifiqué el modulo 5F sin problemas..y claro, el 10 pues ya no me aparece...
a ver si alguien me puede echar una mano... gracias!
midlink
Notapor rojas el 17 Nov 2015, 20:54
midlink escribió:He probado con el Vagcom de un colega, que es el 12.12.0 y nada... me aparecen los mismo modulos (nose si a él le aparece el modulo 10...) a ver no tengo la camara instalada, pero entiendo que la ECU debería de aparecer como instalada igual...
si no tienes sensores de aparcamiento es imposible que te salga el modulo 10 .
rojas
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 1889 veces
Notapor rojas el 17 Nov 2015, 20:56
rojas
Notapor rojas el 17 Nov 2015, 20:58
cual es el problema??
rojas
Notapor midlink el 17 Nov 2015, 22:06
rojas escribió:cual es el problema??
Me sale la pantalla negra al poner la marcha atrás :( (comentar que he alimentado con 12V de fuente externa los cables de tensión).
Es necesario configurar el modulo 10 para poder ver la camara en la pantalla?
Comentarte que al cortar el conector amarillo y ponerlos en el pin 6 y 12. Cuando corté me aparecieron 3 cables, uno amarillo, uno rojo y uno negro y únicamente puse el 6 y el 12 con el negro y el rojo. El amarillo no lo conecté a ningún sitio..
Muchas gracias rojas, como siempre, es increible, lo sabes todo!
midlink
Notapor rojas el 17 Nov 2015, 23:01
La pantalla en negro no es x el módulo 10 ... algo tienes mal en instalación o codificacion.
El rca solo tiene 2 ... la malla q es masa y el positivo . Al pin 12 y 6
Revisa la instalación y alimenta la camara desde el mechero para probar
rojas
Notapor midlink el 17 Nov 2015, 23:01
Solucionado Rojas!!!! Era que el cable amarillo debe de estar con el cable rojo! Como ya no los podia crimpar los he juntado a medio cable! Gracias rojas!!
midlink
