León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor tom101 el 10 Ene 2016, 16:15
arlot escribió:
tom101 escribió:por favor alguien me podría indicar que hay que buscar en ebay para dar con esa cámara? los enlaces han caducado
muchas gracias
http://www.ebay.es/itm/361193591908?_tr ... EBIDX%3AIT
Muchas gracias, le di vueltas a ebay buscando algo compatible con golf 7, no vi esa porque indica hasta el 6.
Leon 1.6 tdi
A5 3.0 tdi stage 3 +800nm
tom101
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 20 veces
Notapor Unaited el 10 Ene 2016, 16:36
tom101 escribió:
Unaited escribió:Yo por ejemplo, puse la camara (no tengo sensores originales) y cada vez que meto marcha atras se activa, pero cuando meto 1a, se queda la pantalla en negro (porque cogi la alimentacion de la marcha atras). Hay algun modo de que se vea algo en vez de la pantalla en negro? Yo que se, el coche del ops aunque no funcione, o algo...gracias!
cuantos segundos de "retardo" necesitarias?
Veo dos opciones, o meterle un condensador gordo (que solo te daría algún segundo), o un circuito de corte con retardo que no se lo que costará.
O la más facil, meterle positivo directo de contacto y que valla siempre encendida. Aunque se le acortará la vida, el coste de la camara es poco.
Ya bueno, esas opciones ya las habia pensado pero por no rehacer la instalacion...pense que con vagcom podria activarle algo del ops o asi en ese momento
SEAT LEON MK3 ITECH 1.6 TDI CR 105cv ==> viewtopic.php?t=109489
Unaited
Agradecido: 104 veces
Notapor Qarl el 10 Ene 2016, 23:31
reiyavik escribió:Yo tengo un problemilla, tengo codificado el módulo 5F y el 10 como dijo @rojas, pero a mi los sensores OPS se me ven con el fondo negro y tengo que darle para apartarlos. Me he equivocado en algo???
@Dasi568 y yo estamos en las mismas... en que año se fabricó tu coche compañero??
Qarl
Agradecido: 83 veces
Notapor reiyavik el 10 Ene 2016, 23:45
Yo lo compre en marzo de 2014, y creó k se fabricó en agosto o septiembre de 2013.
reiyavik
Agradecido: 10 veces
Notapor Qarl el 10 Ene 2016, 23:49
reiyavik escribió:Yo lo compre en marzo de 2014, y creó k se fabricó en agosto o septiembre de 2013.
Mmm el mío también es de esa fecha y el de Dasi por ahi rondará, no se que pasaría en esos meses de fabricación...
Qarl
Notapor reiyavik el 10 Ene 2016, 23:52
Y no existe forma de poder actualiza el software del navegador, para poder cambiar eso?????
reiyavik
Notapor jliriz el 11 Ene 2016, 01:09
Yo seleccionè esta opción de camara y comencé a verlo sin fondo negro.
Seat Leon Sc 1.6 TDI 105cv DSG Style-Itech con Faros Full Led, Techo Panorámico, Navegador, Control de velocidad con radar y asistente de frenada, Safety Pack, Alarma Volumétrica, Sensores de aparcamiento delanteros y traseros + OPS + Cámara, Cristales tintados y Rueda repuesto minimizada 16".
Febrero'15.
jliriz
Agradecido: 113 veces
Notapor reiyavik el 11 Ene 2016, 06:57
Así lo tengo yo también, pero se me ve con el fondo negro. Pero ahora me surge una duda tonta, cuando modificas esa opción con el VCDS, hay que apagar y encender el coche?, resetear o desconectar la radio para que acepte los nuevos valores?
reiyavik
Notapor jliriz el 11 Ene 2016, 07:51
No hay que hacer nada. Con que te te coja los cambios es suficiente. A veces parece que los ha cogido pero no es así. Repite la operación.
Febrero'15.
jliriz
Notapor reiyavik el 11 Ene 2016, 17:14
Voy a repetir el proceso pero esta vez con el 15.7 que me acaba de llegar.
reiyavik
Notapor IvanMc2 el 11 Ene 2016, 17:19
Borjajose escribió:Hola a todos.
Lo primero agradecer a Rojas por este brico.
Pues ya tengo la cámara original de Seat y el cableado completo, mi pregunta es dónde va conectado el cable verde y el marrón.
Por los conectores que tienen al final, pinta que el marron va a una tuerca cualquiera de masa y el verde directo a la caja de fusibles, en cualquier hueco libre deverias de poder ponerlo y ponerle un fusible de 10, o eso o cortar y poner un "roba fusibles" al del mechero
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2
Agradecido: 129 veces
Notapor IvanMc2 el 11 Ene 2016, 17:21
Ponle la alimentacion del mechero y se te mantendra la camara, yo fabrique un conmutador que cambiaba de camara asiq cuando ibas marcha tras salia la camara trasera y al poner 1 la delantera, pero nunca llegue a montarlo
IvanMc2
Notapor reiyavik el 11 Ene 2016, 18:20
Esa es la versión de mi radio, no se si tendrá algo que ver. Pero ni con la 15.7 lo consigo.
reiyavik
Notapor tsgarcia33 el 13 Ene 2016, 11:20
Soy nuevo en el foro y este es el primer brico que quiero hacer, así que espero poder llevarlo a cabo. Ya he instalado una de estas en otro coche de mi propiedad, un Audi A4 pero a través de un GPS chino que tenía directamente entrada de video, por lo que veo aquí va directamente al QuadLock.
Me quedan algunas dudas de la cámara después de leer buena parte del post y es sobre el sistema de la cámara NTSC o PAL. Hay mensajes contradictorios, os agradecería si alguien lo puede aclarar o por lo menos asegurar que la suya es de uno u otro sistema y le funciona.
Había pensado en pedir esta, aunque no pone Leon Mk3 o 5F, solo pone LEON:
http://es.aliexpress.com/store/product/CCD-Car-Reverse-Camera-for-VW-Bora-Magotan-Jetta-Beetle-Passat-SCIROCCO-POLO-Golf-Seat-Leon/238053_32371921159.html?spm=2114.04020208.3.35.tUbFOL&ws_ab_test=searchweb201556_1,searchweb201644_5_10001_10002_10005_10006_10003_10004_62,searchweb201560_1,searchweb1451318400_6151
¿Sabéis si también serviría para un Golf 7? Es que quizás pida dos para montarlo en un futuro en el coche de mi mujer.
Pues lo dicho, nos leemos por aquí y espero que os quede tan bien como a vosotros que se ve de lujo.
Salduos
tsgarcia33
Notapor IvanMc2 el 13 Ene 2016, 14:59
tsgarcia33 escribió:Hola,
Salduos
Todo quedo en que las camaras pal se veian en blanco y negro y las ntsc en color, con respecto a aliexpress, buscala en ebay que con la caida de la bolsa china hay problemas con los envios, y la diferencia de precio es minima
IvanMc2
