León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor zacarias el 07 Mar 2016, 01:02
@rojas , no tendras pensado en un futuro próximo pasarte por la costa del sol ya sea de vacaciones o algo?? :avergonzado: :avergonzado:
se podría llegar a un acuerdo.... :rey: :rey:
o algun otro forero.... :mrgreen: :mrgreen:
zacarias
Agradecido: 201 veces
Notapor Zarkis el 07 Mar 2016, 20:06
rocketboy escribió:Bueno, pues ya está cámara instalada y operativa!
Lo único que no me gusta es que cuando no hay luz no se ve nada hasta que el obstaculo está a 30 cm... por ejemplo en el parking. De dia se ve muy bien, pero la imagen va como a impulsos y la corriente la tengo del mechero!
Y para los compis de ST ahi va la foto de por donde he pasado el cable. No he visto mas opción. Es por donde van los cables de las luces de la matricula y procurar que no pase muy cerca del tubo de escape!
Hola rocket o si alguno mas lo sabe. Estoy liado con el tema de la camara y no consigo desmontar la moqueta y el portaobjetos que la sujeta para liarme con los cables al parachoques y al maletero. Alguien me puede explicar como desmontarlo como ha hecho rocket? Del portaobjetos hay un tapon que sujeta a un tornillo pero el resto va como clavado a la moqueta y no se por donde tirar sin que parezca qUe vaya a romperse
Zarkis
Notapor Albertcbr el 08 Mar 2016, 19:20
Hola buenas!
A ver si alguien me puede echar una mano, me he hecho con una cámara original de Seat para el Leon ST y me falta una pieza muy importante dwl rompecabezas.
Me han servido la cámara con el conector de imagen y el de alimentación de logitud aprox. 20 cms, entiendo que al ser la original le correspondería que el mazo de cables que la "espera" en el coche ya tenga estos dos conectores.
Sin embargo no es así (normal al no venir la cámara de serie) lo curioso en que en ETKA ni yo ni dos concesionarios hemos sido capaces de identificar ni el cable de la cámara en solitario ni tampoco el mazo de cables general de la parte trasera para coches con cámara, encontrando sólo una referencia para todos los modelos.
Alguien sabe la referencia de el cable para la cámara original? He buscado en foros en diversos idiomas y en todos los casos el retrofit se ha basado en lo mismo que se curró el forero @rojas ,es decir, una cámara aftermarket con un cable artesanalmente elaborado.
Saludos y gracias!
Albertcbr
Agradecido: 80 veces
Notapor Caanpulo el 08 Mar 2016, 20:56
Nadie sabe porque me ocurre esto?? Cuando meto marcha atras me sale la imagen pero al quitar la marcha me sale un aviso de "park pilot no disponible"y ya no se ve nada al volver a meter la marcha atras. Para que no me salga dicho aviso y por lo tanto se vea la imagen al vover a meter la marcha atras tengo que darle a "atras" antes de desengranar macha atras :enfurecido: . Es un leon del 2016 y el compañero que me lo codifico dice que quizas sea que al ser nuevo hay que codificar otra cosa mas. Alguien sabe la solucion?? O alguen a codificado la camara en un leon del 2016? :neutral:
Caanpulo
Agradecido: 42 veces
Notapor tsgarcia33 el 09 Mar 2016, 16:32
Albertcbr escribió:Hola buenas!
Saludos y gracias!
Igual te doy una pista falsa, pero mira a ver si podría ser alguno de estos cables:
https://www.kufatec.de/shop/en/retrofits/assistance-systems/cable-set-front-camera-mqb
este cable que aunque es de un Golf podría valer:
https://www.kufatec.de/shop/en/volkswagen/golf/golf-7-5q/cable-set-rearview-vw-golf-7-vii
tsgarcia33
Coche: Leon MK3 1.5 TGI 130cv
Notapor Albertcbr el 09 Mar 2016, 22:48
tsgarcia33 escribió:Hola,
Muchas gracias compañero por tu respuesta, el segundo tiene los dos conectores que lleva la cámara original a parte de los que supongo utiliza el Golf para mover el logo pero por precio se me va de las manos utilizar ese cable, tendré que recurrir a inventos con toda la info que hay por aquí.
El forero @borjajose consiguió el cableado original pero la verdad es que no sé como se las maravillaría, pues me han confirmado que en la instalación original el cable va metido dentro del mazo de cables de la parte trasera a pesar de que en ETKA no aparece esa referencia.
He estado observando la cámara y he visto lo siguiente:
El conector para la imagen de la cámara es referencia VW 420035575A y referencia FAKRA 59Z078 -AU 0- B:
He encontrado esta especie de "data sheet" de este conector:
Y por lo que he visto en un catálogo de conectores FAKRA del fabricante Rosenberger cualquier conector hembra de la serie RF será válido, además en ebay venden adaptadores FAKRA -> JACK RCA por 4 chavos así que la imagen la tendría solucionada comprando un latiguillo adaptador y haciéndome un cable casero hasta la unidad 5F :ok:
El problema lo tengo en el segundo conector que lleva la cámara, referencia 4H0973712A:
Del cual he encontrado su correspondiente macho en referencia original (no la pongo porque aún dudo entre dos que compraré para utilizar el que me sirva) y creo que no tendría mucho problema en encontrar los pines para crimparlos y salir de este conector con el macho original y los cables crimpados pero... OH NO! hay tres cables en vez de dos :plas:
El pin-out del conector es:
1 -> Rojo
2 -> Marrón
3 -> Vacío
4 -> Amarillo
Por tanto lo único que doy por hecho por código de colores es quizá que el Marrón es el negativo que rojas saca del mazo de cable de los faros en el tutorial.
A partir de aquí me encomiendo a la sabiduría de @rojas para intentar descifrar si:
Rojo -> +12V permanente (por ejemplo toma de mechero)
Amarillo -> +12V Marcha atrás (lo cual no me cuadra con el cable azul/negro del cual se saca la tensión en el tutorial)
Y todo sea dicho ya de paso rojas, si por lo que sea esta cámara sólo puede funcionar con la centralita original te agradezco de antebrazo un MP si es que aún dispones de uno de los dos módulos que vendías, pues ya estoy embarcado con esta cámara y me gustaría rematar la instalación con ella sin cambiar a una aftermarket.
Cualquier ayuda es bienvenida, prometo documentar la conclusión de todo esto siempre y cuando no acabe en fracaso.
Albertcbr
Notapor Borjajose el 09 Mar 2016, 23:54
Hola.
Yo la cámara y el cableado se lo compre a uno que trabajaba en seat.
1 -> Rojo
2 -> Marrón
3 -> Vacío
4 -> Amarillo
Borjajose
Notapor rojas el 10 Mar 2016, 00:01
Hola.
1 -> Rojo
2 -> Marrón
3 -> Vacío
4 -> Amarillo
Hola compañero , tengo el módulo 5Q0907441A . Si te interesa te lo dejo en 185 eur
Te dejo mi tlfno 697203287
rojas
Agradecido: 1889 veces
Notapor loken el 10 Mar 2016, 14:03
Hola Zarkis,
Solo queria decirte que yo no necesité desmontar todo el moquetado que muestras en las imagenes. Tal y como te pasa a ti yo tampoco sabía como desmontar los portaobjetos del maletero. Estan durisimos y tenía miedo de romper algo. Al final instalé la camara sin necesidad de desmontarlos. ¿Como?
1. El cable de alimentacion lo tiré por la derecha (por la goma del maletero hacia la derecha y despues lo saqué al maletero en el lado de la luz del maletero).
2. Para coger la luz del maletero basta con desmontarla y ponerle un robacorrientes.
3. Para empalmar los cables con levantar minimamente el guarnecido derecho es suficiente para empalmar cables y esconder ahí el relé y el condensador.
Pasaba de desmontar medio maletero asi que lo hice asi... ademas que luego se doblan los guarnecidos y no queda luego bien.
loken
Notapor Zarkis el 12 Mar 2016, 12:17
Hola al final desmonté el maletero entero. No me he cargado nada pero ha sido una odisea...
Por cierto ayer lo acabé y lo probé durante un rato y todo iba genial!
El problema ha sido esta mañana cuando al volver a usarlo me ha empezado a zumbar el relé hasta el punto que suena como freír, como si fuera a quemarse con un ruido muy electrónico.
El relé se activa con la luz de marcha atrás. Podría ser que al ser una corriente por impulsos por el Canbus me haga un efecto como a corriente alterna o algo parecido? Aclaro que con el contacto puesto funciona bien, es cuando el coche está arrancado que hace ese zumbido como si el relé hiciera microaperturas muy rápido
Zarkis
Notapor moucho el 18 Mar 2016, 14:05
Pero.... A raíz de estos últimos comentarios hay que montar algún tipo de componente electrónico para el montaje de la camara?
Relés? Condensadores?
Galiza terra de rallys
moucho
Coche: Leon MK1 1.6 16v 105cv
Agradecido: 9 veces
Notapor cvillajos el 19 Mar 2016, 16:17
moucho escribió:Pero.... A raíz de estos últimos comentarios hay que montar algún tipo de componente electrónico para el montaje de la camara?
@moucho , dependerá de dónde cojas la corriente tendrás que montar o no esos relés / condensadores... Me explico: Si cojes 12v limpios (mechero, toma 12v maletero si tienes un ST, etc.) no necesitas esos componentes. Si lo cojes de las luces del coche (freno, marcha atrás, etc.) como en el brico original sí necesitas esos componentes.
cvillajos
Agradecido: 3613 veces
Notapor moucho el 19 Mar 2016, 16:29
Muchas gracias
Aprovecharé a poner una toma de 12v en el maletero lo que si la camara queda funcionando permanentemente aunque no se muestre en pantalla
Y al ser chinas.....
moucho
Agradecido: 9 veces
Notapor lupen el 19 Mar 2016, 18:05
Hola yo intentare dar corriente a la camara con robacorrientes al cable de marcha atras y masa tal y como hizo @rojas al principio o si se puede del faro trasero que esta mas cerca del plafon de la luz matricula en vez de la manguera de goma superior del porton sin condensador ni rele y con el mod de aumentando intensidad de luz de marcha atras como creo que ya hizo @guajarenho haber que tal va...
lupen
Notapor guajarenho el 19 Mar 2016, 21:15
lupen escribió:Hola yo intentare dar corriente a la camara con robacorrientes al cable de marcha atras y masa tal y como hizo @rojas al principio o si se puede del faro trasero que esta mas cerca del plafon de la luz matricula en vez de la manguera de goma superior del porton sin condensador ni rele y con el mod de aumentando intensidad de luz de marcha atras como creo que ya hizo @guajarenho haber que tal va...
Así lo hice yo. Todo me funciona perfectamente y la instalación es más limpia (menos paso de cables y rele innecesario).
Si todo está bajo control es que no vas lo suficientemente rápido
R135
_246
guajarenho
Coche: Leon MK3 1.2 TSI 110cv
Agradecido: 36 veces
