León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor zamapo el 22 Mar 2016, 00:59
guajarenho escribió:
lupen escribió:Hola yo intentare dar corriente a la camara con robacorrientes al cable de marcha atras y masa tal y como hizo @rojas al principio o si se puede del faro trasero que esta mas cerca del plafon de la luz matricula en vez de la manguera de goma superior del porton sin condensador ni rele y con el mod de aumentando intensidad de luz de marcha atras como creo que ya hizo @guajarenho haber que tal va...
Así lo hice yo. Todo me funciona perfectamente y la instalación es más limpia (menos paso de cables y rele innecesario).
Yo tb lo llevo así y perfect :ok:
zamapo
Coche: Otro modelo SEAT
Agradecido: 27 veces
Notapor xaacra el 22 Mar 2016, 11:58
Hola te puedes explicar mejor como hiciste para no tener que usar reles ni condensador
xaacra
Agradecido: 9 veces
Notapor Caanpulo el 22 Mar 2016, 15:14
@xaacra el compañero se refiere a subir la intensidad de la luz de marcha atras con el vagcom para que no tenga corriente por impulsos y conectar la camara a esta, asi no necesitaras ni rele ni condensador.
Caanpulo
Agradecido: 42 veces
Notapor Caanpulo el 22 Mar 2016, 15:17
Mi duda es si lo codificamos asi se fundiran las bombillas de marcha atras con frecuencia??
Caanpulo
Caanpulo
Notapor kossel el 22 Mar 2016, 16:14
iba a preguntar exactamente lo mismo. Me uno a la duda sobre la vida útil de la bombilla de marcha atrás en ese caso.
kossel
Coche: Leon MK3 1.2 TSI 86cv
Agradecido: 56 veces
Notapor zamapo el 22 Mar 2016, 20:29
Caanpulo escribió:Mi duda es si lo codificamos asi se fundiran las bombillas de marcha atras con frecuencia??
Yo lo llevo así desde mayo y cero problems ;)
zamapo
Notapor xaacra el 22 Mar 2016, 21:08
Tus pilotos son normales o leds
xaacra
Agradecido: 9 veces
Notapor kossel el 22 Mar 2016, 21:11
en los pilotos Led la marcha atrás lleva bombilla halógena, no?
kossel
Notapor zamapo el 24 Mar 2016, 02:32
Normales
zamapo
kossel escribió:en los pilotos Led la marcha atrás lleva bombilla halógena, no?
Si
zamapo
Notapor Eluryh el 24 Mar 2016, 12:37
Bueno pues ya tengo la cámara instalada en mi Leon.
Tanto la instalación como la cámara ha sido a cargo de AutoRadio America de Barcelona.
En un par de horas lo han tenido hecho y todo perfecto.
@sonxav todo de coña :)
Eluryh
Agradecido: 107 veces
Notapor kossel el 24 Mar 2016, 12:38
Eluryh escribió:Bueno pues ya tengo la cámara instalada en mi Leon.
si no es mucha indiscreción, cuánto te han cobrado? Gracias!
kossel
Notapor Eluryh el 24 Mar 2016, 16:53
para nada!!! cobran 130€ por todo, cámara e instalación. Te dan 2 años de garantía para ambas cosas.
Yo que soy 0 manitas con los coches, me ha ido de fábula.
Por cierto, instalan la perforada en el centro de las dos luces de matrícula, es decir, queda colocada igual que la oficial de Seat.
Eluryh
Notapor sonxav el 24 Mar 2016, 21:21
Gracias por la info @Eluryh , en breve intentare montarla..... :ok:
sonxav
Agradecido: 526 veces
