León Mk3 - MIB1 navegador 5.8" - Modelo, mapas, etc
Favoritos: RLesma, elivanito, vallter, dukaty, Agonza86, crickro, cvillajos, Banchel, GremBack, SusoP, lubumbax, Jonathanstleon, curt580, pablitosuizo
Seguidores: Platanot, david_gz, marlop, coolboy1973, curt580, satrapas, JoseCa, KoToRRo, Leon_CAT_FR, ivan0909, hectorcanu, Jorge75016, msmdraven, Jota79, Aegnorazo, jose150cv, josele77, lazandury_sur, easyridergs, jalf, javinho10, davidbj, maxinew, champinet, santibaz, Garfu, davidmd, Txutxiysilvia, Malcadon, jordimv, inamarlo, elivanito, dukaty, Efremvidal, indi69, dghlb, JMR666, oldaqgonzalez04, genialsoft, Pictorinho, MORKAS, mananipons, cgomis, aironsam14, alpau99, zenkun, Kikote8, Tomcat7733, GremBack, Edu1589, LuichiFR, artek90, ferranbe, ncx, Montydaka, lead, Illan, Triple R, sergi303, snowborde, tecnoyito, ElFon, xexpir, Er_Poya, bird4, Maikermx, Atajunen, Nelson Pirez
Re: Leon Mk3 - MIB1 navegador 5.8" - Modelo, mapas, etc
Notapor cvillajos el 29 Oct 2019, 14:08
cobrax3 escribió:
cvillajos escribió:
cvillajos escribió:
i will try this
but what if i want to update to 2019?
thank you again!
Not posible. SWAP/FEC code on your unit only accepts until 0072 version.
Regards!!
tried with 72, didn't work :(
checked again, looks like i am blind, i only have v4!
so same question, how can i update further?
with another cid?
or with a diagnose cable? i have odis
thank you very much!
CID is only one layer of protection. Check the digital signature of the cartography in .PSF files is another one.
Without a SWAP/FEC code equal or bigger than the versión you want to upgrade it is not possible on MIB gen1 (also on MIB gen2 high) to pass through this layer.
Buying a new SD on a dealer also includes a new SWAP/FEC code to be loaded on your unit.
You need this one to gets the v12, for example:
07200014 for v14, and so on...
Regards!!
cvillajos
Agradecido: 3611 veces
Notapor cobrax3 el 29 Oct 2019, 14:19
cvillajos escribió:
cobrax3 escribió:
cvillajos escribió:
cvillajos escribió:
i will try this
thank you again!
Regards!!
with another cid?
Regards!!
so i can use this code from the pictures? to insert where?
cobrax3
Notapor cvillajos el 29 Oct 2019, 15:23
cobrax3 escribió:
cvillajos escribió:
cobrax3 escribió:
cvillajos escribió:
cvillajos escribió:
i will try this
thank you again!
Regards!!
with another cid?
Regards!!
SWAP/FEC codes are not simple "codes" that you can change when you want... It is needed a connection with a central host in order to create a new one for your VIN.
What you see in the image is the "ID" of the SWAP/FEC I have loaded into my unit.
Regards!!
cvillajos
Notapor cobrax3 el 29 Oct 2019, 15:29
Regards!!
thank you, i have researched more about those codes, and indeed, there is nothing i can do about it :(
so i guess my car will stay at 2017...
cobrax3
Notapor cvillajos el 29 Oct 2019, 17:30
Regards!!
Or you can buy an update at your dealer... But $$$
Regards!!
cvillajos
Notapor Fenoll el 17 Ene 2020, 09:36
HOla, soy un negado para todo esto a ver si algun entendido me puede ayudar:
Mi seat Leon es mk3 de principios de 2013 con la pantalla de 5'8" (de las que no se pueden actualizar a full link)y supongo que serà MIB1 también pero como os digo esto no es lo mio. Os adjuntos datos del sistema multimedia y los datos del GPS. Mi pregunta es: esta tarjeta de mapas actualizados a 2019 versión 15 ¿funcionaria en mi coche?
https://www.seataccesoriescatalogue.net ... /1978/4406
Un Saludo!
Fenoll
Notapor cvillajos el 17 Ene 2020, 09:43
Fenoll escribió:HOla, soy un negado para todo esto a ver si algun entendido me puede ayudar:
Un Saludo!
Tienes una MIB gen1 sí... Y de las primeritas (no había visto yo hasta ahora una H039 con un S0132)
Sí, la actualización que enlazas te vale, ya que (aunque no lo incluyen en el precio, pero luego cobrarán...) En el taller te tienen que instalar el SWAP/FEC de activación de dicha versión.
cvillajos
Notapor Fenoll el 17 Ene 2020, 09:51
Un Saludo!
Muchas gracias, miedo (por no decir vergüenza ya) tengo de ir a mi taller puesto que siempre que he ido (no pocas) a buscar una solución para actualizar el GPS siempre me han dicho que era imposible.
Entonces no es solo comprar la tarjeta y ponerla, sino que hay que activarla también con coste claro.
si consigo que me lo hagan, cosa que no creeré hasta que lo vea ¿luego podré actualizar los mapas desde casa descargéndolos y tendré que pasar por caja y comprar otra tarjeta cada vez que quiera actualizar?
Fenoll
Notapor cvillajos el 17 Ene 2020, 10:35
Un Saludo!
Poder pueden hacerlo, claro... y deben tener los procedimientos para la carga del SWAP/FEC que incluye la compra de la actualización de la cartografía... Si no saben (o no quieren) búscate otro taller.
Un matiz: No se activa la tarjeta en sí, lo que se activa es un código en tu Infotainment. Y es solo válido para la v15 (tendrá un ID parecido a 07200015). No podrás actualizar más allá de la v15 con él porque no te están vendiendo un MapCare de 3 años (cuyo ID sería algo como 07200021).
cvillajos
Notapor Fenoll el 17 Ene 2020, 12:28
Un Saludo!
Muchas gracias por la aclaración y la información. El lunes me paso por alli a ver si saco algo en concreto, en mi zona no hay mucho concesionario donde elegir.
Desde el total desconocimiento ¿se puede contratar un mapcare despues de tantos años?
Fenoll
Notapor cvillajos el 17 Ene 2020, 13:37
Fenoll escribió:
Un Saludo!
No hay Nº de referencia conocida en recambios...
Hace un tiempo, para MIB gen2 High, sí llegué a ver un MapCare en la web de accesorios por 3 años, pero desapareció... Su coste -> 400 y pico € :rayback:
cvillajos
Notapor bird4 el 17 Ene 2020, 15:58
Perdona @cvillajos , yo tb tengo un mib1, pero si compra la de 2019 no podría actualizar hasta 2022 al incluir suscripción a mapcare 3 años?
O no he entendido bien?
Uno que le lleva tb dando vueltas a este asunto
bird4
Agradecido: 18 veces
Notapor cvillajos el 17 Ene 2020, 19:46
bird4 escribió:Perdona @cvillajos , yo tb tengo un mib1, pero si compra la de 2019 no podría actualizar hasta 2022 al incluir suscripción a mapcare 3 años?
No, si compras una actualización concreta el código que te cargan en el Infotainment es válido sólo para esa versión.
No estás comprando un MapCare, sino una sola versión.
cvillajos
Notapor bird4 el 18 Ene 2020, 17:21
Pues vaya chasco, pues ese precio pensaba que al menos podrías actualizar hasta 3 años más....
Si ya me parecía caro si fuera como pensaba, ahora viendo que sólo vale para ese año me parece una sobrada
Gracias por las aclaraciones de cualquier modo
bird4
Notapor Fenoll el 20 Ene 2020, 11:52
gracias por la informacion. Un saludo!
Fenoll
