León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor javigody el 10 Abr 2016, 11:33
zacarias escribió:aquí teneis mi cámara en funcionamiento gracias a @javigody (perdón por la suciedad de la pantalla)
[ Video ]
y una foto del pasado lunes...
Para los que os haya pasado que la luz de la cámara es distinta a la que trae de serie el coche en el plafón, deciros que hay solución. Por 80 céntimos compráis un par de leds smd blanco frío y los cambiáis.
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody
Agradecido: 274 veces
Re: Faros Full-led delanteros y Halogenos
Notapor IvanMc2 el 10 Abr 2016, 19:40
kossel escribió:Muchas gracias por tu recopilación! Creo que falta solamente el conector a la centralita de regulación, no?
7L6 972 726
Yo tengo uno que compre en añixpress pero no esactamente el mismo y pasa que va al reves, por lo tanto el pin 26 del conector coincide con el pin 1 de la centralita, asiq recomiendo ir a la sest a por ese conector, @leoncitorojo tiene la referencia
https://youtu.be/87b4ICrxWls
Con que has codificado compañero?
Enviado desde mi SM-N910F mediante Tapatalk
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2
Agradecido: 129 veces
Notapor javigody el 10 Abr 2016, 19:52
7L6 972 726
Se codificó con vagcom 15.7.1
javigody
Notapor IvanMc2 el 10 Abr 2016, 20:17
7L6 972 726
javigody escribió:
7L6 972 726
Y si no me confundo, segun las fotos, es en pantalla 6,5 no?
De ser asi, la codificacion es byte 19, activar bit 4 y ya esta?
IvanMc2
Notapor SLon34 el 11 Abr 2016, 10:45
Hola a todos!
Alguien me podría recomendar un taller por el baix Llobregat para instalarla? Soy un negado para el tema :zoquete: .
Muchas gracias!!
SLon34
Coche: Leon MK3 1.5 TGI 130cv
Notapor fjlux el 13 Abr 2016, 18:01
fjlux escribió:Hola, estoy intentando activar por vagcom cámara trasera para pantalla media system touch color 5"
el conector trasero de la pantalla es idéntico al de la unidad de cd de la guantera que yo no tengo, es un seat león st style MY16, no lleva CD ni en la pantalla.
el foro turco donde dicen lo han conseguido no esta accesible, asi que intentare codificar por mi cuenta, necesito saber el código acceso para modulo 5F apartado 10 adaptation ya que no sirve el código 31347, creo que por ahí se podría mirar algo, lo de bytes 18 y 19 como haceis ya esta hecho y no funciona y no llevo radar ni sensores parking, un saludo y buenos bricos.
os paso pantallazos al intentar codificar a ver que solución tienen
fjlux
Notapor fjlux el 13 Abr 2016, 18:05
otro pantallazo de errores al codificar
fjlux
Notapor SLon34 el 13 Abr 2016, 19:52
SLon34 escribió:Hola a todos!
Muchas gracias!!
Rojas! MP recibido! :ok: Muchas gracias! Eres un crack!!!
Te contesto por aqui porqué aún no puedo enviar mensajes privados
SLon34
Notapor leonfrrojito el 14 Abr 2016, 08:13
Si necesitáis montarla por la zona de Andalucía aquí me tenéis para ayudaros
leonfrrojito
Agradecido: 178 veces
Notapor javigody el 14 Abr 2016, 11:18
7L6 972 726
javigody escribió:
7L6 972 726
La codificacion depende de si llevas sensores de parking o no
javigody
Notapor kiketo77 el 16 Abr 2016, 21:11
Buenas compis, despues de subsanar los fallos que me daba la Put.... cámara y que eran:
- El portafusible que se coloca el la posicíon del fusible del mechero de 20A, resulta que tiene posición. Parecerá una pijada pero yo me volví loco buscando el fallo de no tiene señal. Así que cuidadín. El cable que salga hacia la parte de arriba para que te den 12V bajo llave continuos.
- Los pines del Quadlock que les falta una pequeña pestaña en la entrada y es la que hace contacto.
Ahora a disfrutarla junto con el Park Assist instalado a la vez desde cero.
kiketo77
Notapor fjlux el 16 Abr 2016, 21:38
Alguien sabe a que se debe este error?
fjlux
Notapor Caanpulo el 16 Abr 2016, 23:12
kiketo77 escribió:Buenas compis, despues de subsanar los fallos que me daba la Put.... cámara y que eran:
Compañero lo de que tiene posicion el porta fusibles a que te refieres?? Que si lo pones alrevez no da los 12v continuos??
Caanpulo
Agradecido: 42 veces
Notapor Davido2790 el 17 Abr 2016, 02:40
IvanMc2 escribió:Ola q aseee a todos, yo le puse la camara a un compañero de bcn, con pantalla de 6,5 y sin park pilot.
Cuando codifique sin instalar nada, me salia el fallo del park pilot no disponible y descodifique.
Monte la camara y volvi a codificar, cuando mi sorpresa, resulta que funciona perfectamente, probamos y probamos y 0 fallos.
Se vuelve el compañero a bcm y al cabo de unos dias me dice que le ha saltado el fallo de park piot no disponible, un dia si y 2 no, yeva como un mes y medio y el fallo es muy aleatorio.
-Codificado con 12.12.3, bit 4 del byte 19, solo.
-Corriente positiva con portafusible desde caja de fusibles.
-Corriente negativa directa pilar derecho trasero tornillo conector de masas.
Me pasa exactamente lo mismo a mi, llevo la cámara en la pantalla 6,5" mirror link, eso si yo llevo sensores, y fuancona bien hasta que le entra el venazo y se empieza a ver mal o se pone negra y sale park piloto no disponible, apagas el coche lo vuelves a encender y todo vuelve a funcionar... no se que será...
Davido2790
Agradecido: 81 veces
Notapor yours3lf el 22 Abr 2016, 11:40
Chicos una pregunta, que hay demasiadas páginas en el hilo y no encuentro la solución...
Instalé hace tiempo la cámara y funciona perfectamente (pantalla 5,8" + sensores OPS de serie), pero cuando meto marcha atrás y se enciende, que también sale el recuadro con los sensores, esta parte sale con el fondo negro. Es al cabo de unos segundos que se vuelve 'transparente' y veo toda la pantalla con la cámara incluido el sensor de aparcamiento.
Mi pregunta es, ¿eso se puede codificar para que sean 0 segundos y desaparezca el fondo negro?
Gracias,
yours3lf
Agradecido: 26 veces
Usuarios navegando por este Foro: AhrefsBot, Anthropic y 6 invitados
