Yo lo tengo actualizado y funciona bien solo tienes que tener cuidado
León Mk3 - Actualización infotainment
- Seguidores: 188
- Favoritos: 42
- Vistas: 654.356
Favoritos: BADS, Daruma, ositoerik, dmesanun, YeSL, pocososinos, jasoriab, JaviMarquez, crujipoyo, Arkan7, Cristianibias, pepeiyo69, Angel J, Xaggy, edumachuca, abollao, -alberto-, Rickymax, ferre7, Pedritoleon, Rivesgti, Alleya, davidalba, Xiguito_Corito, craken, JDCLEONFR, nemura, danihd, cenkkaya, Kisszabo, castell_lkpg, pistoleromtb, Raulportela, Martelinko, albert_naga, Adrian Anton, Gravilhas75, chaiser, popez, ruli68, denniisg2000, LeonFR80bsv
Seguidores: kenny_fonseca, ncx, Lavadora, barris31, juancete, ivantxe, jesusFR, Hysteria, MaximusRoco, Manu1986, Jorge75016, davidbj, bIxu, miyobe, MORKAS, gorkansr, aironsam14, jramis, kimudj, Maikermx, Javizormo, gogua, Melonkid, Kikote8, danirodrigueze30, maxinew, aigort, carlosgzlez, corderazo, Lionxp, jande, Edu1589, msmdraven, Arkan7, inamarlo, edumachuca, Josepo79, lead, camamaleon, davidmd, carrasco13, clavelstreet, mikomiko, josele77, car212121, itz18, golf_1990, LeidenSpain, vecnte, Andy_G, csabafr2013, leonfr76, Trimmer, genialsoft, Enerts, leonfrrojito, Horus, paco_22_22, ruben88, Valerofr150, molvi_mabad, Pekee69, Dav2k6, IbiFR, il_munyo, craken, ruben91mad, papo-182, el_padrino, zeratul, kaiserssosse, lytry32.hc, sbarri, ghitus, DesmoSimon, ruli68, Mramos1985, tonielfilas, braulioT, davidalba, JaviMarquez, osjamil, egarense69, fexposru, Pedrost, Illan, chetelopez, juanacho21, cuenka16, pepeiyo69, VapaV, AlvaroPM13, balbu, juan7777, mams69, Helrique, Kike77, volkov, jluis, loeches, Tom70, Dconnect, Trivi83, MilleMiglia, linxes, sergi303, hector37, D83, quiquito30lv, ElFon, DALOFER17, davidap13, kigua, JOTTA, Senuto, jd_zuri, Alvi, damsolu, Leon pucelano, javi_archi, danihd, alcoleazgz, miguel23and, xarlio, jdieztec, mitxuni, Kisszabo, Gendos22, xexpir, canijo82, Brandenor, cenkkaya, kennit0, Chelazo, bertoco, benitogomez, carlosVACA, Peje, NOECUBI1, AAAJDA, trazas, martija, borjiguez, JoseXS, ferbarroso14, Wespa, Cloud_ganora, Berbe15, Valengti, Chrohu, Atajunen, Victorzabal, jrm82, carlo13, iNFeCTeD, paralaxon, ateopoeta, pepo55, ribasxisco, Raulribarroja, ivanti, Jansel, lopezm0, Rubén Flp, Warelio, Vagabundo, Rekoba, Octacon, matiaso, Alianma, Raulportela, Éugen91, Rivesgti, Mcm90, DaniR86, Gravilhas75, JuanNur78, el_Asturiano, Mr.Chuflas, albert_naga, juanfrancia, Seket, algabe, pistoleromtb, ebcuatro, [GuErRa], Mario Leon, tito68
csabafr2013 - Asidu@ en la selva
- Agradecido: 13 veces
Re: Actualización infotainment
No hay más actualizaciones para la H24 S0346?
lafu1988 - Leoner@ mayor del reino
- Agradecido: 217 veces
la ultima valida que se puede instalar es la 0346 para hw24
aprietatuercas1974 - Aqui + que con la novi@
- Coche: Leon MK1 2.8 Cupra 4 V6 204cv
- Agradecido: 358 veces
Alguien puede decirme que modelo de radio es este y si tiene actualizacion, porfavor? Ando como loco buscando pero no encuentro nada...
Chadz - Nuev@ por aqui
Chadz escribió:Alguien puede decirme que modelo de radio es este y si tiene actualizacion, porfavor? Ando como loco buscando pero no encuentro nada...
[ Video ]
Es el modelo de 5" y por aquí no tenemos nada para esa unidad. Tampoco creo que mejore mucho actualizándola.
SEAT León MK3 FR 1.4 TSI 150CV ACT
Instalador en Málaga -> VIM, bricos MK3, tempomat MK1 y más
--- ¡Colabora con nosotros y con la comunidad con tus backups de OBDeleven/Vagcom/VCDS en el siguiente enlace!: viewtopic.php?f=8&t=120732 ¡Gracias!---
javigody - Aqui + que con la novi@
- Agradecido: 274 veces
@aprietatuercas1974 te quería hacer una pregunta.
Llevo el navi sistem plus (5F0035043) y versión de SW 0319. Para pasar a la versión 0674 habría que pasar por alguna versión intermedia? ¿o se puede pasar directamente? Te agradecería mucho que me sacaras de esta duda existencial que tengo jajajja.
Gracias de antemano y un saludo
- Agradecido: 465 veces
Creo que lo puedes hacer directamente,si encuentras los archivos claro
y para la H42 software 0319 hay algo? tambien tengo el sistem plus
Mantaray - Aqui + que con la novi@
- Agradecido: 93 veces
Buenas envió la versión de un toledo diciembre 2015 con 6,5" y gen 2 se podrá actualizar???
SEAT TOLEDO MK4 1.6 TDI
flotter - Asidu@ en la selva
- Agradecido: 8 veces
Si, a la 346.flotter escribió:[ Imagen ]
Enviado desde mi SM-G950F mediante Tapatalk
javigody escribió:Si, a la 346.flotter escribió:[ Imagen ]
Buenas
Ya he visto que se hace a través de la sd cual son los archivos o donde los puedo descargar???
Pagina 61 (tapatalk, 41 del foro)flotter escribió:javigody escribió:Si, a la 346.flotter escribió:[ Imagen ]
Buenas
javigody escribió:Pagina 61 (tapatalk, 41 del foro)flotter escribió:javigody escribió:Si, a la 346.flotter escribió:[ Imagen ]
Buenas
Muchas gracias ya he estado leyendo voy a bajarme los archivos y actualizar ya os contaré
Al actualizar cabe la posibilidad que funcione el desbloquear el VIM ?? Ya que hasta hora por ser gen2 no se podía hacer nada??? Sería una alegría muy grande
flotter escribió:Al actualizar cabe la posibilidad que funcione el desbloquear el VIM ?? Ya que hasta hora por ser gen2 no se podía hacer nada??? Sería una alegría muy grande
No entiendo tu pregunta (del todo...) El desbloqueo del VIM en las gen2 ha funcionado siempre... Para MirrorLink que es lo que bloqueaba en movimiento...
Pero si te refieres a reproducir archivos de video desde USB o SD eso no tiene nada que ver con el VIM, es una funcionalidad que tienes o no tienes (según el modelo de Infotaiment), y que yo sepa los nuevos firmwares no incorporan la misma en aquellos que no la tenían antes.
- Agradecido: 3612 veces
Problema con aire acondicionado León fr mk1 Foro: Leon I - Mecánica / Electricidad / Electrónica Autor: Paranohia Respuestas: 8 |
Cambiar batería seat leon 3 Foro: Leon III - Mecánica / Electricidad / Electrónica Autor: frangzmr Respuestas: 259 |
