León Mk3 - BRICO - Como instalar la cámara de parking
Favoritos: JaviCG, Vampiro, J@VY, BADS, Daruma, cstrol, JorgeAnteloC, ipenalosa, MONTY DAKA, pirly, josele887, xurox, Nanox23, Carbono79, vallter, norchugo, Efremvidal, @turbina@, blankiblau, jorgee76, jliriz, Vilo, cuenxis, victir, Aras, Korath, Rasekfighter, Carrl, jdieztec, J-Frass, Tarzan, zacarias, Frannisesabe, Xperience, bronce702, sbarri, javieret69, Carlos Chea, Lotar, Alleya, miguelorly, craken, chemazz, xico, eMi1, Maverick.es
Seguidores: Linker89, car212121, franrx, davidalba, TRIBO, danieleon, Panchorin, Hecson.27, jmfcoto, aironsam14, JOTTA, MORKAS, Unaited, trekam, xandis, Jorge75016, Platanot, davidbj, Achehmg, marc.domenech.90, sadanyac, seat leon blanco, Marc.22, Peuero, er_trompe, GTI35, JoseCa, JaviCG, vigimuertos, rabazas, B.Fox, msmdraven, Tomcat7733, Txutxiysilvia, xabidh, cstrol, Carrl, El3ndil, yorky, bolche, LeoST, Diegokero, Rasekfighter, Budoka, IronTor21, marlop, xico, vanscampa, Tarzan, jorgee76, josemag, aigort, LuichiFR, SLon34, clavelstreet, nani_san, nyro, IVANIN9, rober1095, ivan0909, jose.jjg307, csabafr2013, P.carrizo.leonstfr, dookky, Edu1589, Dconnect, D83, Jeii90, inamarlo, Israel-FR, Herrdoktor, el_padrino, Kipu, aguscalderon, lebowski, juanmaroger, bailyibz, naikon_paul, Valerofr150, JAL, kennit0, Mramos1985, bronce702, kijute, juanmik, osjamil, Tonivn, Lotar, Tunnig, JaviMarquez, nitro_g4074, sergi303, ivan2017, Chema_Alvarez, ilargiman, jaumotix, sbarri, javierferriz, alcoleazgz, lecupra280, Colomer, Maikermx, luigi323, rents_80, jdiego75, Pedrost, damsolu, lead, Franr50, Dani2025, Leon pucelano, nachomart, castronight, victor david, bertoco, juan7777, Josep20, jakobitto, rr7mo, a.cuadros71, iNFeCTeD, Gendos22, VapaV, Chrohu, Ganyula, snowpluralism, victor_leon_FR, luaiabou96, Drovniak, Guillen222, leonfrrojito, justics, lopezm0, Romera, pedrorossello92, AlvaroRamlo
Re: BRICO como instalar la Camara de parking en Seat leon MK
Notapor fvgarcia el 20 May 2016, 17:06
He sacado la tele al coche( si un show y conectando el
Cable del video a la tele y poniendo marcha atras la camara se ve, con lo cual me queda por descartar la codificacion por mi cable ( que creo que es por lo que no me va) o que haya hecho mal el adaptador de video, porque están metidos hasta el fondo y en el
Pin 6 positivo y 12 negativo @rojas @cvillajos gracias!!
fvgarcia
Agradecido: 92 veces
Notapor fvgarcia el 20 May 2016, 17:07
repetdo por tapatalk sorry
fvgarcia
Notapor leonfrrojito el 21 May 2016, 03:15
fvgarcia el vag com lo que te esta diciendo esque no te esta reconociendo el error se ve que no tendra las labels actualizadas con la ultima actualizacion de vag com alomejor te saldria un saludo
leonfrrojito
Agradecido: 178 veces
Notapor cvillajos el 21 May 2016, 03:59
leonfrrojito escribió:fvgarcia el vag com lo que te esta diciendo esque no te esta reconociendo el error se ve que no tendra las labels actualizadas con la ultima actualizacion de vag com alomejor te saldria un saludo
No es de labels.... Es de fichero ROD. Que seguramente el 12.12 nonlo tiene y versiones superiores sí. Sin él no sabemos a qué se debe el error.
A lo largo de la mañana lo busco y te lo paso de mi instalación (15.7) a ver si es compatible con la tuya y nos da más información.
P.D.: tendrá que ser el lunes, que me he dejado el portátil en el curro :plas: .
P.D.II: O si quieres, también te puedes instalar la 15.7.4 en otro PC diferente al que utilizas con el cable y extraer el fichero .ROD que se corresponda con el error de la carpeta: "C:/Ross-Tech/VCDS/EDS_EV/"
cvillajos
Agradecido: 3613 veces
Notapor kurtastur el 21 May 2016, 16:03
lupen escribió:
javigody escribió:
lupen escribió:Hola despues de hacer la instalacion y comprobar que todo esta correcto varias veces(camara cableado quadlock pines etc.) el resultado despues de codificar con vagcom 15.7.0 en una pantalla 6,5 mirrorlink y park pilot funcionando bien es imagen borrosa al accionar marcha atras ya me ha comentado el autor del brico que solo podre activar la camara en esta pantalla con el VCP pero ahora parece ser que tambien se podria con las nuevas versiones vagcom 15.7.3 y 15.7.4 si esto es asi hay alguien que lo pueda confirmar y como seria la codif.? dejo la imagen de como me sale la pantalla haber si creeis que esto ya es tema de codificacion...
(la imagen es borrosa y entrecortada pero no por que hay ningun cable flojo)
saludosss
Le has puesto condensador?
No aunque no creo que sea ese el problema ya que he probado en parado y corriente directa y hace lo mismo tengo aumentada intensidad de marcha atras y me da 12v continuos
Hola @lupen que valor de intensidad de la luz de marcha atras has puesto?
Los bit iniciales d los byte 19 y 18 los has dejado o solo has dejado activados los bit 4?
kurtastur
Notapor alexdaoe el 21 May 2016, 23:20
Hola, yo tengo toda la camara instalada, pero me molesta la resolución de la camara, es penosa la imagen que da, sirve para ver la parte trasera, pero vamos la imagen es peor que las camaras de los moviles ladrillos de hace 10 años... Las caracteristicas de mi camara es esta:
1. Pixels: 656 (H) * 492 (V)
2. Power: DC 12 V
3. View Ángulo: 170 grados
Sensor 4. Image: 1/4 " CMOS
5. sistema de TV: NTSC
Resolución 6. Horizontal: 420 líneas de TV
7. Lens: 18.5mm
Alguien ha instalado una camara que de una imagen decente y a una resolución superior ? La imagen ademas esta como desenfocada... Es un poco bastante cutre, pero bueno para enterarte de lo que hay detras sirve.
alexdaoe
Coche: Leon MK3 1.5 TGI 130cv
Agradecido: 48 veces
Notapor cvillajos el 23 May 2016, 08:35
Mi cámara tiene las siguientes especificaciones @alexdaoe , y tampoco es una maravilla:
- Angular: 170º
- Sensor: OV7950, color CMOS
- Sistema de TV: NTSC
- Resolución: 420 líneas de TV
- Píxeles efectivos: 704 x 576
- Iluminación mínima: 0,1 lux
- Clasificación IP: IP68 ¿?
Diseño único con funciones de línea de referencia
cvillajos
Notapor Stealnick el 23 May 2016, 09:58
Buenas, las cámaras con mayor resolución que he visto tienen 520 líneas, es lo máximo que he visto.
Stealnick
Agradecido: 269 veces
Notapor kurtastur el 23 May 2016, 13:55
alexdaoe escribió:Hola, yo tengo toda la camara instalada, pero me molesta la resolución de la camara, es penosa la imagen que da, sirve para ver la parte trasera, pero vamos la imagen es peor que las camaras de los moviles ladrillos de hace 10 años... Las caracteristicas de mi camara es esta:
2. Power: DC 12 V
7. Lens: 18.5mm
La mia es d 520 lineas y por lo que costo se ve de sobra para lo que es.
kurtastur
Notapor genialsoft el 23 May 2016, 17:35
cámara de 10€ en Aliexpress
Enviado desde mi S6-Edge
genialsoft
Agradecido: 346 veces
Notapor IvanMc2 el 26 May 2016, 01:38
Buscar en la medida de lo posible camaras ccd en vez de cmos y de 170° a poder ser
Enviado desde mi SM-N910F mediante Tapatalk
Cuando pienses que estas al limite, estaras a un 50% de llegar al mismo.
IvanMc2
Agradecido: 129 veces
Notapor freedom2co el 26 May 2016, 22:22
pues yo me he pillado esta que opinan..
CCD Car Reverse Camera for VW Bora Magotan Jetta Beetle Passat SCIROCCO POLO Golf Seat Leon Altea Skoda Superb Auto Backup Kit
http://s.aliexpress.com/aUvM3uuy
(from AliExpress Android)
en cuanto me llegue pues al lío..
por cierto que cable y versión me recomiendan he visto por aliexpress me valdrá.?
2015 VAG COM 15.7.0 VAGCOM 15.7 VCDS HEX CAN USB Interface VAG 15.7 with ATMEGA162 16V8B FT232RL Chip
http://s.aliexpress.com/iMzumEFf
freedom2co
Notapor seat leon fr 46 el 27 May 2016, 10:07
Uno mas con la camarita trasera gracias a Javigody!
seat leon fr 46
Agradecido: 94 veces
Notapor jony83 el 31 May 2016, 21:37
una pregunta, los que teneis un st. como habeis pasado el cable desde la luz de matricula hasta el maletero ??
jony83
Agradecido: 20 veces
Notapor cvillajos el 31 May 2016, 21:48
jony83 escribió:una pregunta, los que teneis un st. como habeis pasado el cable desde la luz de matricula hasta el maletero ??
Con una guía, primero abajo a la derecha te encuentras una trampilla a desmontar, segundo arriba recto te encuentras el agujero con los cables que dan al maletero.
cvillajos
